Homework Help: Projectile motion
  1. Jan 21, 2009 #1
    i'm launching a small ball from a launcher (on a table) at 55 degrees into rings (at .25, .50, .75, 1) and to a target on the floor.
    height from the floor to the launcher: 1.015m
    angle: 55
    velocity: 6.62 m.s
    i have to find how far each ring will have to be from the launcher, how high the ring stands need to be, and how far the target on the ground has to be (to go from the launcher through each ring, and then it the target.)
    http://img168.imageshack.us/img168/1156/img005na3.jpg [Broken] <-- it was a bit big to put in as an image
    2. Relevant equations
    y=(Vy)(t)+1/2gt^2
    x=(Vx)(t)
    3. The attempt at a solution
    http://img135.imageshack.us/img135/544/img006fp1.jpg [Broken] <-- too big to put in as an image
    for the distance the rings have to be i used x=(Vx)(t).
    i don't think i set this up right though.
    how i did it:
    first ring
    x=(Vx)(t)
    x=(.25)t
    x=(.25)(1.107s)
    x=0.277m
    second
    x=(.50)(1.107s)
    x=.5535
    the rest are in the picture.
    and to find the height of the ring stands i used max height.
    center ring (second one)
    t=1.107s/2
    t=.5525s
    y=(Vy)(t)+1/2gt^(2)
    y=(5.423 m/s)(.5535s) + 1/2(-9.8 m/s)(.5535s)^2
    first ring height
    t=.5535s/2
    t=.27675
    then i put it in the equation and got 1.13m.
    would this be the height from the table or the ground? i'm pretty lost and this is a major grade so any help would be appreciated. :smile: i need some guidance in the right direction.
  3. Jan 21, 2009 #2
    It appears you are inserting the relative postition of the ring into Vx, the velocity of the ball in the horizontal directions. Clarify what the .25, .5, .75 and 1 values represent.
  4. Jan 21, 2009 #3
    LowlyPion
    What exactly are you trying to do?
    Place the rings at 25%, 50%, 75% and 100% of flight time?
    Or .25m, .5m, .75m, 1m ?
    I don't understand your answer in times at all.
    Neither do I see you using the horizontal velocity component 3.79 m/s to determine the horizontal spacing.
