Ray Serway's Physics For Scientists & Engineers 4th Ed. Vol. 1 Ch. 4 Review Problem #1
In summary, the conversation discusses a physics problem involving the trajectory of a ball thrown with an initial speed and angle. The conversation covers various equations and calculations to find the time the ball is in motion, its speed at the peak of its path, the initial vertical component of its velocity, its initial speed, the angle at which it was thrown, the maximum height and range that can be reached, and the distance between two rocks thrown simultaneously.
Gyro
49
Could someone please check my work and provide insight on what I may be missing to complete the problem.
The question's from Ray Serway's Physics For Scientists & Engineers 4th Ed. Vol. 1. Chapter 4. Review Problem #1. Page 95.
A ball is thrown with an initial speed [tex]v_0[/tex] at an angle [tex]\theta_0[/tex] with the horizontal. The range of the ball is [tex]R[/tex]
and the ball reaches a maximum height of [tex]R/6[/tex]. In terms of [tex]R[/tex] and [tex]g[/tex], find
a) the time the ball is in motion,
b) the ball's speed at the peak of its path,
c) the initial vertical component of its velocity,
d) its initial speed,
e) the angle [tex]\theta_0[/tex],
f) the maximum height that can be reached if the ball is thrown at the appropriate angle and at the speed found in d),
g) the maximum range that can be reached if the ball is thrown at the appropriate angle and at the speed found in d).
h) Suppose two rocks are thrown from the same point at the same moment as shown in the figure. Find the distance between them as a function of time. Assume [tex]v_0[/tex] and [tex]\theta_0[/tex] are given.
2. Homework Equations
[tex]y_{peak} = R/6[/tex]
[tex]y = v_0_yt - 1/2gt^2 = R/6------>(1)[/tex]
[tex]v_y_{peak} = 0 = v_0_y - gt ==>v_0_y = gt-->(2)[/tex]
[tex] (2) -> (1): R/6 = (gt)t - 1/2gt^2 = 1/2gt^2[/tex]
[tex]t = \sqrt\frac{R}{3g}[/tex]
Quickly checking dimensions,
[tex]\sqrt\frac{L}{LT^-2} = T[/tex]
a) The time of flight is twice the time it takes to get to its peak.
[tex]T_{total} = 2t = \sqrt\frac{4R}{3g}[/tex]
b) At the ball's peak [tex]v_y = 0[/tex], so the speed is all horizontal.
We also know that at its peak, the ball has traveled half its range.
[tex]R/2 = v_0_xt[/tex]
[tex]v_0_x = \frac{R}{2\sqrt\frac{R}{3g}} = \frac{R}{2} * \sqrt\frac{3g}{R} = \sqrt\frac{3Rg}{4}[/tex]
[tex]\sqrt(L*LT^-2) = LT^-1[/tex]
c)
[tex](2): v_0_y = gt = g\sqrt\frac{R}{3g} = \sqrt\frac{Rg}{3}[/tex]
d)
[tex]v_0 = \sqrt(v_0_x^2 + v_0_y^2)[/tex]
[tex]= \sqrt(3/4Rg + 1/3Rg) = \sqrt(\frac{9Rg + 4Rg}{12}) = \sqrt(13/12Rg)[/tex]
e)
[tex]\tan\theta = \frac{v_0_y}{v_0_x} = \frac{\sqrt(\frac{Rg}{3})}{\sqrt(\frac{3Rg}{4})} = \sqrt\frac{Rg}{3}*\sqrt\frac{4}{3Rg} = \sqrt\frac{4}{9} = \frac{2}{3}[/tex]
[tex]\theta_0 = 33.69^o[/tex]
f) What is the question asking, exactly? By the way the question is worded, it sounds like they're asking what max height can the ball reach given the initial speed found above. That happens when the ball is thrown straight up. In that case [tex]\theta_0 = 90^o[/tex]
Projectile Height Eq'n:
[tex] y_{max} = \frac{v_0^2\sin^2\theta_0}{2g}[/tex]
[tex] = \frac{(13/12Rg)(\sin^2(90^o))}{2g} = (\frac{13Rg}{12}*\frac{1}{2g}) = \frac{13R}{24}[/tex]
How do I interpret that answer? Does it say the ball would vertically travel (13/24*100 =) 54.2% of the Range it would travel horizontally if it is thrown with the same speed but at an angle of [tex]33.69^o[/tex] instead?
g) The maximum range occurs when [tex]\theta_0 = 45^o[/tex]
Projectile Range Eq'n:
[tex] x_{max} = \frac{v_0^2\sin2\theta_0}{g} = \frac{(13/12Rg)(\sin90^o)}{g} = \frac{13/12Rg}{g} = \frac{13R}{12}[/tex]
This makes some sense to me. If the ball were thrown at [tex]45^o[/tex] rather than [tex]33.69^o[/tex], it would horizontally travel farther by 1/12R.
h) My thinking here is that since the rocks take mirrored projectile paths, the distance between them will always be a horizontal line, the length being twice the horizontal distance of one rock from the origin.
[tex] D = 2*v_0\cos\theta_0 *t [/tex]
That seems too a simple an answer. Am I missing something?
All help appreciated.
Thanks in advance. :smile:
EDIT: Maybe this question should be in the Intro category. Sorry if so.
f) g) h) seem ok ... i haven't checked the rest though.
Thanks for checking f, g, and h, Lok. Those were the questions I was concerned about. Cheers.
1. What is the main topic covered in Ray Serway's Physics For Scientists & Engineers 4th Ed. Vol. 1 Ch. 4?
The main topic covered in this chapter is motion in one dimension, including displacement, velocity, acceleration, and the equations of motion.
2. What is the purpose of Review Problem #1 in Ch. 4?
The purpose of Review Problem #1 is to assess the reader's understanding of the key concepts and equations related to motion in one dimension.
3. What are the steps to solve Review Problem #1 in Ch. 4?
The steps to solve Review Problem #1 are as follows:
1. Identify the given values and variables
2. Determine which equation(s) of motion to use
3. Substitute the given values into the equation(s)
4. Solve for the unknown variable
5. Check the solution by plugging it back into the original equation(s)
4. Is it necessary to show all work for Review Problem #1 in Ch. 4?
Yes, it is important to show all work and steps when solving Review Problem #1 in Ch. 4. This allows for a clear understanding of the problem-solving process and helps to avoid mistakes.
5. Are there any additional resources available to help understand Review Problem #1 in Ch. 4?
Yes, there are additional resources available such as online tutorials, practice problems, and study guides that can assist in understanding and solving Review Problem #1 in Ch. 4.
