Homework Help: Projectile motion
  1. Sep 23, 2009 #1
    a track is inclined in such way that the velocity of the metal ball is 60 cm/s at 25 degree below the horizontal. mathematically determine the total x displacement of the metal ball.
    weight of ball: 65grams
    height from floor to the end of the track: 76.15cm
    velocity of the ball is 60.cm/s at 25 degree
    2. Relevant equations
    [tex]\Delta[/tex]y =Vo*t - .5 1/2gt^2
    Vx = Vox + .5at^2
    3. The attempt at a solution
    I used the first equation to find time.
    -76.15 = .5*-9.8t^2
    t=.394s
    deltaX = .6m/s*cos(-25).3942 + .5(-9.8).3942^2
    i got delta X to be -54.7cm
    is it suppose to be negative?
    Could someone help me set this up right?
  3. Sep 23, 2009 #2
    rl.bhat
    Hi goodz, welcome to Pf.
    In the y direction the initial velocity is not equal to zero.
    And in the x direction there is no acceleration.
  4. Sep 23, 2009 #3
    I think i got it.
    first i needed to get the velocity using v^2 = VoSin(-25)^2 - 2(-9.8).7615
    v = 3.87m/s
    then to get time,
    3.87 = .6Sin(-25)-(-9.8)t
    t=.4207
  5. Sep 23, 2009 #4
    rl.bhat
    If you take down as negative v, vi and g are all negative. So check the value of t.
  6. Sep 23, 2009 #5
    are you saying .6m should be negative?
  7. Sep 23, 2009 #6
    rl.bhat
    Allare positive or negative.
    The equation should be
    v = vosin(25) + gt.
  8. Sep 23, 2009 #7
    3.87 = .6(sin25)+9.8t
    t=.369s
    x= voCos25t
    x=.6cos25(.369)
    x=.20m
