Why Does Initial Velocity Not Affect Vertical Distance Travelled?
In summary, the vertical distance traveled by a projectile under the action of gravity alone, below the straight line it would follow in the absence of gravity, does not depend on the angle of projection. This is because, even though the projectile is initially projected with a certain vertical velocity, the effect of gravity causes it to fall the same vertical distance it would if it were released from rest. This can be explained by changing the reference frame and looking at the projectile as if it was being dropped from rest. Additionally, the maximum distance can be achieved by firing the projectile at a 45-degree angle.
Pranav Jha
141
why doesn't the vertical distance traveled in the given time ,under the action of gravity alone, below the straight line it would follow in the absence of gravity, depend upon the angle of projection of a projectile?
With no gravity, the projectile, which is projected at an angle at certain initial velocity, would follow a straight-line path (dashed line). But, because of gravity, the projectile falls beneath this line the same vertical distance it would fall if it were released from rest.
I am confused about the "rest" part. why is the formula 1/2(gt^2) but not (ut+1/2(gt^2)). Why is the vertical component of initial velocity not included?
Because if you fire projectile horizontally, its initial vertical velocity is zero. Same as if you simply release it from rest.
If the projectile is fired at an angle, yes, you must include initial velocity.
this part explicitly refers to using the condition for rest in spite of having initial velocity in the upward direction. So, is it wrong?
Oh, I misread it slightly.
It's still not wrong. The dashed line is y0 = ut. What it would move like if there was no gravity. (You can plot x or t on the x-axis, since it will only alter the scale.) The actual trajectory is y1 = ut - (1/2)gt², as you point out. The difference between the two is y1-y0 = -(1/2)gt². So relative to dashed line it's moving as if it was released from rest.
Basically, it's a change of coordinate system. Instead of looking at it from perspective of someone at rest, they are looking at it from perspective of a hypothetical bullet that's unaffected by gravity. Relative to it, the fired bullet is just free falling "from rest".
hmmm... so from the reference frame of someone going up at the an initial velocity but unaffected by gravity, the other person who has the same initial velocity but is affected by gravity appears to be falling from rest.
Newton's 2nd law is very useful for this type of problems. Also, remember that this law is written in a vector form (x,y,z-direction), and what happens in one direction does not affect the others (unless you have air-friction or other complicated phenomena happening).
Thus, for the x-direction you have
dvx/dt=0 (no force) (1)
and for the z-direction you have
dvz/dz=-g (only gravity) (2)
The first eqn gives vx=constant => x=vx*t+c1
whereas the second eqn gives vz=-g*t+c2 => z=-(1/2)g*t^2+c2*t+c3
If there was no gravity, the second eqn would have given z=c2*t+c3, a straight line
You may fire a projectile with only horizontal velocity, but, you need to fire it from a certain height, otherwise it won't go far away.
Also, if you solve the above system of eqns for the maximum distance, you will find that you need to fire the projectile at an angle of 45o.
1. Why does initial velocity not affect vertical distance travelled?
Initial velocity does not affect vertical distance travelled because the force of gravity acts on all objects equally, regardless of their initial velocity. This is known as the principle of universal gravitation.
2. How does gravity affect the motion of an object?
Gravity causes an object to accelerate downwards at a constant rate of 9.8 meters per second squared. This means that the object's velocity increases by 9.8 m/s every second.
3. Can initial velocity affect horizontal distance travelled?
Yes, initial velocity can affect horizontal distance travelled because it determines the object's speed and direction. However, it does not affect vertical distance travelled due to the constant acceleration of gravity acting vertically.
4. Does air resistance play a role in this principle?
Yes, air resistance can affect the motion of an object in the vertical direction. However, it is often negligible compared to the force of gravity, so it does not significantly impact the vertical distance travelled.
5. How can we calculate the vertical distance travelled of an object?
The vertical distance travelled by an object can be calculated using the equation d = vit + 1/2at2, where d is the vertical distance, vi is the initial velocity, t is the time, and a is the acceleration due to gravity. Alternatively, it can also be calculated using the equation d = (vf2 - vi2)/2a, where vf is the final velocity.
  • Classical Physics
  • Mechanics
