• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Projectile Motions
  • Thread starter halo9909
1. Homework Statement
1)A basketball player tries to make a half-court jump-shot, releasing the ball at the height of the basket. Assuming the ball is launched at 53.0°, 13.5 m from the basket, what velocity must the player give the ball?
2)A baseball is hit at 32.0 m/s at an angle of 52.0° with the horizontal. Immediately an outfielder runs 5.00 m/s toward the infield and catches the ball at the same height it was hit. What was the original distance between the batter and the outfielder?
2. Homework Equations
D=.5at^2
t/9.8=Vy
D=Vt
3. The Attempt at a Solution
I tried solving the first one by using those equationswith some sin/cosine to get the height and horizontal distance but from there I got it wrong, by doing so I got 8.18m/s but is incorrect
2) I basically did the same as aboe but since there is a second part I am not sure what to do with it
If there are any other webistes with guides or examples with these types of problems please post
LowlyPion
3,079
D=.5at^2
t/9.8=Vy
D=Vt
Show how you arrived at 8.18m/s. I got a different answer. Perhaps I can see where your method differs?
for the second problem, solve for time (which will be how long the ball is in the air for), and distance (how far the ball goes). finding time will allow you to figure out how far the outfielder moves to catch it. then just do some simple addition of distances and that is your answer (make sure the distance the ball goes u solve for the X distance)
37
for the 1st one with the basketball I did
tan(53)=y/13.5m
which lead me to 18.7m
then i took 187.7m used it in D=.5at^2
which lead the "t" to be 1.912
Since i want the "horizonatal verlocity" i would be d=vt I have the d which is 13.5 now I have the time, but it is multipled by 2 to make it 3.82sec
so
13.5=V3.82
V=3.53, guess this is what I got this time.
For th 2nd one
I did 32sin53 = 25.216 yvelocity
and 32cos53 = 19.701 xvelocity
to find time I took 25.216/9.8=2.573sec then multiplied by 2 and got 5.146sec for the Horizontal
since I know the xvelocity, I did 19.701 x 5.146 and got 101.38m which is the range, the runner @ 5m/s im still unsure of
LowlyPion
3,079
tan(53)=y/13.5m
That's just not correct.
The Tangent of the angle of launch is not equal to the max height times the range. I would suggest that you forget that equation.
Vy = g*t
Vx = X/t
Total time = 2*Vy/g = X/Vx
Vy = g*t
Vx = X/t
Total time = 2*Vy/g = Vx/X
so are my "t" correct?
LowlyPion
3,079
You don't need t. I didn't bother to calculate it.
Note: I made a typo in the earlier post. It should read
37
Dont you need the "t" to get the Vy and Vx?
LowlyPion
3,079
you're also forgetting:
range= vx(time total)
if that helps any.
13.5 m would be the range...right?
To use cos, sin or tan you'd have to have a velocity (i think)...where you would get a velocity i have no idea lol.
and lowly, how would velocity be found? I mean, there's no initial velocity...only final (which would be 0 for up) ...and there's no time.
There's only range and an angle measurement...
then how would I get the Vx /Vy
if possible could someone please show the steps, as this is getting quite confusing
27
vx=cos53
vy=sin53
13.5/2 = 6.75m
6.75 going up, 6.75 going down.
t=d/v
t=6.75/cos53v
Timeup=vf-vi/a
=sin53v/9.8
6.75m/cos53v=sin53v/9.8
cross multiply and it's just algebra from there. :)
2)
sin52=y/32
cos52=x-5/32
vy/9.8=time
time(2)=total
total(x m/s) = Range :)
You just have to use a little algebra, that's all.
LowlyPion
3,079
These are the components of initial velocity. Specifically
Vx = V*Cosθ
Vy = V*Sinθ
Putting that in the equation 2*Vy/g = X/Vx yields:
V2 = g*X/(2*Sinθ*Cosθ)
Recognizing the identity 2*Sinθ*Cosθ = Sin2θ this can be simplified to:
V = (g*X/Sin2θ)1/2
Related Threads for: Projectile Motions
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
