Projectile Trajectory
  1. Aug 30, 2015 #1
    An artillery shell is fired at an angle of 23.9◦ above the horizontal ground with an initial speed of 1530 m/s.
    The acceleration of gravity is 9.8 m/s2 .
    Find the total time of flight of the shell, neglecting air resistance.
    Answer in units of min.
    2. Relevant equations
    Vf^2=Vi^2+2ad
    d=Vit+1/2at^2
    3. The attempt at a solution
    I tried using the first equation above with the givens to find distance, however, I don't know final velocity. Once finding the distance I would have plugged it into the second equation above to find the time. I would have then converted the time in seconds to find the time in minutes.
    However, none of this was possible because I didn't know the final velocity.
  3. Aug 30, 2015 #2
    Bystander
  4. Aug 30, 2015 #3
    I understand this, however how can you calculate final velocity with just the angle and initial velocity?
  5. Aug 30, 2015 #4
    Bystander
    No idea how to find components of a vector?
  6. Aug 30, 2015 #5
    SteamKing
    Staff Emeritus
    Since you are firing the projectile at an elevated angle above the horizontal, what happens to the projectile once it's fired? You can draw a picture of the trajectory if that will help you to visualize what's going on.
    Remember, since you are dealing with gravity, what goes up must come back down. :wink:
  7. Aug 31, 2015 #6
    Thank you! So I understand what the projectile looks like. I have drawn a picture and tried a different attempt to what I was doing before. I found the x and y components of the angle. I then used the y component of this answer as the initial vertical velocity, used 0 as the final vertical velocity, and used-9.8 as the vertical acceleration. I then plugged these values into the Vy=Viy+at to find the time in seconds. I got 63.25s. I then converted this to 1.054 minutes. However, this answer was wrong.
    I still don't understand what I am doing wrong. Any ideas?
  8. Aug 31, 2015 #7
    Yes, I used the y component of the vector as explained in my reply to "SteamKing" However, I still got the answer wrong.
    Any ideas on where I went wrong?
  9. Aug 31, 2015 #8
    SteamKing
    Staff Emeritus
    Did you remember what I told you about gravity? What goes up must come back down?
  10. Aug 31, 2015 #9
    Oh right, okay so my time is half of the time that it takes the shell to fly. So I must double my time?
  11. Aug 31, 2015 #10
    SteamKing
    Staff Emeritus
    Yes.
  12. Aug 31, 2015 #11
    Thank you!
Have something to add?
Draft saved Draft deleted
Similar Discussions: Projectile Trajectory
  1. Projectile trajectory (Replies: 2)
  2. Projectile trajectories (Replies: 21)
  3. Projectile Trajectory (Replies: 2)
Loading...
