How Do You Calculate Projectile Motion from a Cliff?
In summary, the projectile is fired from the top of a 10m high cliff and has a range of 152m. Determine the time of flight.
fcb
50
A projectile is fired from the top of a 10m high cliff. It has a range of 152m and reaches a maximum height of 8.2m above the cliff top. Determine the time of flight
Is Delta Y =18.2?
Is Uy=10
Delta Y = Uyt + 0.5 ayt
18.2=10t-4.9t2
4.9t2-10t+18.2
Using the quadratic equation
10+-21.37/9.8
t=3.2
Does that seem right
I believe delta y would be 18.2, and your work seems right.
Thank you Drelt
You have not used the range of the projectile any where.
Where would range play a part in the question? Doesn't range (delta)x only matter on horizontal motion?
I mean if you can find time the you can find Ux but I didn't know you needed to use it to find time
Since range is given, the projectile is fired with some angle with the horizontal line.
In the problem they have not given uy = 10 m/s.
So is the time not 3.2 since I assumed Uy was 10m/s?
Wouldn't I need to know U to be able to find Uy then. And Ux would be range over time. But how would you find time without finding Uy
Could you make Vy=0 and use the equation
Vy^2 = Uy^2 + 2a (delta) Y
Yes. You are right.
Uy = (2*g*y')^1/2.
Ux*t = 152. So t = 152/Ux.
Now -y = Uy*t - 1/2*g*t^2
-y = (2*g*y')^1/2.*152/Ux - 1/2*g*(152/Ux)^2
Solve the quadratic to find Ux, and then find t.
I got t= 3.18
Is that right. Maybe I screwed up somewhere along the line.
I'll double check in the morning as I am in Australia and it's getting late
all looks good, just double check the quadratic work in a calculator on n the computer to make sure you didnt make any mistakes.
Nah I think there was a mistake. Can Someone confirm with me that t=~1.903
Im not sure if I am correct or not, but when I did the problem i got t= 4.642s
I used the equation (deltax)= v(initial)t + (.5)(9.8)t^2
Step One) 152=10t+4.9t^2
Step One rearranged for quadratic formula) 4.9t^2+10t-152=0
Got answers 4.62s and -6.683s, but time cannot be negative so i ruled out the second answer
hello :)
Let the projectile is projected with velocity 'u' making an angle A with horizontal.
Let us break the motion in 2 parts :-
<1> From point of projection to maximum height of 8.2m above the cliff top :-
{...For a projectile, projected with an angle A and velocity u,time of flight when the projectile fall back to same horizontal is t =(2usinA)/g
Time to reach max height, tm= (usinA)/g
Maximum height attained H = (usinA)tm - (1/2)g[tm]2
........= (1/2)(usinA)2/g
...} Using this for Case 1 :-
8.2 = (1/2)(usinA)2/g
=>(usinA)2 =16.4g
Thus,time to complete this part of motion, t1 =(usinA)/g = (16.4/g)1/2
<2> From maximum height of 8.2m above the cliff top to end of flight :-
At max height, only horizontal comp of velocity is there.
Thus initial velocity is ucosA in horizontal direction.
Displacement in vertical height = -(8.2+10) = -18.2m
Thus, -18.2 = 0*t2 - (1/2)g[t2]2
=> t2 = (36.4/g)1/2
Thus, time of complete flight = t1 + t2
.......=3.22 s (approx)
Hope this helps :)
Briliant Vissh. Answer seems consistent with fellow class mates. You're an absolute legend
I think they're different component of x and y and thus you can't use them without linking time
Hehe no problem buddy ^.^
[But Please don't over praise xD When u will continue practising , you will also be able to think of different ways of approach :) And solve problems quickly :)]
What is a projectile?
A projectile is an object that is launched into the air and follows a curved path due to the influence of gravity.
How do projectiles from a cliff differ from other types of projectiles?
Projectiles from a cliff are launched from a higher elevation and have an initial horizontal velocity component, in addition to the vertical velocity component caused by gravity. This results in a curved path known as a parabola.
What factors affect the trajectory of projectiles from a cliff?
The initial velocity, angle of launch, and air resistance all affect the trajectory of projectiles from a cliff. Other factors such as wind speed and direction can also have an impact.
What is the maximum height reached by a projectile from a cliff?
The maximum height reached by a projectile from a cliff is known as the apex or the highest point on the parabola. It is achieved when the vertical velocity component becomes zero.
How can we calculate the range of a projectile from a cliff?
The range of a projectile from a cliff can be calculated using the equation R = (v0^2 * sin2θ) / g, where R is the range, v0 is the initial velocity, θ is the angle of launch, and g is the acceleration due to gravity. This assumes no air resistance and a level landing surface.
