Proving by Induction: Solving for f(n) Using a Hypothesis
In summary, the Proof by Induction Hypothesis is a mathematical proof technique used to prove that a statement holds true for all natural numbers. It involves three steps: the base case, the inductive hypothesis, and the inductive step. The base case is the first step and involves showing that the statement holds true for the first natural number. The inductive hypothesis assumes the statement holds true for some natural number and uses this assumption to prove it for the next natural number. The inductive step uses the inductive hypothesis to show that if the statement holds true for some natural number, it also holds true for the next natural number. Some common mistakes to avoid when using Proof by Induction Hypothesis include not clearly stating the base case
Gear2d
51
I am not sure if this is the right spot to post this, but how would I go about proving this by induction:
f(n) = { 6, n=1
5n+1, otherwise
Base case:
n=1, 5(1) + 1 = 6
Induction Hypothesis:
6 + 11 + 16 + ... + k = 5k + 1
now put k+1 in for k and get 5(k+1) +1 = 5k + 6
after this I am lost.
? I don't understand what you're trying to prove. What is f(n) supposed to be such that you can write it in such a manner?
1. What is the basic concept of Proof by Induction Hypothesis?
The Proof by Induction Hypothesis is a mathematical proof technique used to prove that a statement holds true for all natural numbers. It involves three steps: the base case, the inductive hypothesis, and the inductive step.
2. How does the base case work in Proof by Induction Hypothesis?
The base case is the first step in the proof by induction. It involves showing that the statement holds true for the first natural number, typically 0 or 1. This serves as the starting point for the proof.
3. What is the role of the inductive hypothesis in Proof by Induction Hypothesis?
The inductive hypothesis is the second step in the proof by induction. It assumes that the statement holds true for some natural number k, and then uses this assumption to prove that it also holds true for the next natural number, k+1. This is the key step in the proof by induction.
4. What is the inductive step in Proof by Induction Hypothesis?
The inductive step is the final step in the proof by induction. It involves using the inductive hypothesis to show that if the statement holds true for some natural number k, then it also holds true for the next natural number, k+1. This completes the proof by showing that the statement holds true for all natural numbers.
5. What are some common mistakes to avoid when using Proof by Induction Hypothesis?
Some common mistakes to avoid when using Proof by Induction Hypothesis include: not clearly stating the base case, assuming that the statement holds true for all natural numbers without proving it, and using circular reasoning. It is important to carefully follow the steps of the proof by induction and clearly explain each step to avoid these mistakes.
