Proof by induction
  • Thread starter johann1301
[itex]\sum_{n=1}^{m+1} \frac 1{\sqrt{n}} = ( \sum_{n=1}^{m} \frac 1{\sqrt{n}}) + \frac 1{\sqrt{m+1}} [/itex]
Your problem is to show that
[tex] 2 \sqrt{n+1}-2 + \frac{1}{\sqrt{n+1}} \geq 2 \sqrt{n+2} - 2,\\
\text{or}\\
\sqrt{n+2} - \sqrt{n+1} \leq \frac{1}{2 \sqrt{n+1}}[/tex]
This inequality implies that 9>8. And that is certainly true, therefore the inequality that you posted must be true.
\text{or}\\
if i multiply by √n+1 on both sides, i get..
√((n+2)(n+1)) - (n+1) < 1/2
√(n2+3n+2) < (1/2) + (n+1)
√(n2+3n+2) < n+(3/2)
n2+3n+2 < (n+(3/2))2
n2+3n+2 < n2+3n+(9/4)
2 < (9/4)
(8/4) < (9/4)
8 < 9
We've invested a lot of time helping you out, so we would like to see you get the right answer. Could you post how you came to this conclusion?
You have been a great helper! Both of you have :) I believe I've learned some new tricks because of this :)
HallsofIvy
41,847
965
No, this is incorrect "logic". The fact that "A implies B" and "B is true" does NOT mean "A is true".
  • #31
vela
Staff Emeritus
Education Advisor
15,093
1,674
You know that
$$\sum_{k=1}^{n+1} \frac{1}{\sqrt k} > 2(\sqrt{n+1}-1) + \frac {1}{\sqrt{n+1}}.$$ Starting from there, you have to find a chain of true implications that eventually ends with
$$\sum_{k=1}^{n+1} \frac{1}{\sqrt k} > 2(\sqrt{n+2}-1).$$ A few posts back you said that you found
$$2(\sqrt{n+1}-1) + \frac {1}{\sqrt{n+1}} = \frac{2n+3-2\sqrt{n+1}}{\sqrt{n+1}}.$$ First, do a little algebra and show that this means
$$\sum_{k=1}^{n+1} \frac{1}{\sqrt k} > 2\left[\frac{n+\frac 32}{\sqrt{n+1}} - 1\right].$$ If you can now show that
$$2\left[\frac{n+\frac 32}{\sqrt{n+1}} - 1\right] > 2(\sqrt{n+2}-1),$$ you can use the transitive property of > to get the result you want. It's clear that this inequality holds if you can show that
$$\frac{n+\frac 32}{\sqrt{n+1}} > \sqrt{n+2}.$$ To prove this last inequality holds, you have to start with a statement that's undeniably true and go from there. What you can't do is start by assuming the inequality is true because that's what you're trying to prove.
What I suggest is that you start with
$$\sqrt{n+2} = \sqrt{n+2}\frac{\sqrt{n+1}}{\sqrt{n+1}}.$$ The goal is to use the rules of algebra to continue to manipulate the righthand side that so that's it's readily apparent that it's less than ##\frac{n+\frac 32}{\sqrt{n+1}}##.
You've already done most of the work. It's just putting everything in the right order to make a valid logical argument.
  • #32
Ray Vickson
Dearly Missed
10,706
1,722
So how do you show that the inequality is true?
The argument you gave above can be made to work: start with the fact that 8 < 9 and work backwards (going through your steps in the opposite order).
Alternatively, use the fact that ##\sqrt{1+x} \leq 1 + x/2## for ##|x| < 1##, with strict inequality if ##x \neq 0##. You can see this in two ways:
Method (1) look at the graph of ##y = \sqrt{z}##; it lies below its tangent line through the point (1,1). The tangent line has slope 1/2, so we have ##\sqrt{z} \leq 1 + (1/2)(z-1)##, with equality at ##z = 1## and a strict inequality otherwise.
Method (2): ##1 +x \leq 1 + x + x^2/4 = (1 +\: x/2)^2##, so ##\sqrt{1+x} \leq 1 + (x/2).##
Anyway, we have
[tex] \sqrt{n+2} = \sqrt{n+1}\sqrt{\left(1+\frac{1}{n+1} \right)}\\
\leq \sqrt{n+1} \left( 1 + \frac{1}{2} \frac{1}{n+1} \right) = \sqrt{n+1}
+ \frac{1}{2\sqrt{n+1}}[/tex]
  • #33
217
I have to get back to this problem at a later point, have some other things i have to go through before next lectures! But thank you all so much for your help!
Related Threads on Proof by induction
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
