Proof by Induction
dirtybiscuit
The fibonacci numbers are defined by F0 = 0 F1 = 1 and Fn = n-1 + Fn-2 for n >= 2.
Use induction the prove the following:
Fn-1Fn+1 - Fn = (-1)n
The attempt at a solution
Let P(n) = Fn-1Fn+1 - Fn2 = (-1)n where n>= 1
Show it holds for first natural number:
P(1) = F0 + F2 - F12 = -(1) = -1. So it is true
Now assume it works for some k and prove it works for k+1
This is where I'm really not sure what to do. I have tried putting
F(k+1)-1F(k+1)+1 - F(k+1)2 but it ultimately gets me no where.
Usually when I have done inductive proofs I start with some sequence of numbers 1,2,3,4.....,n and show n+1 is there but this one seems slightly different and I'm not sure how to proceed.
Any help is appreciated.
Answers and Replies
vela
Staff Emeritus
Education Advisor
15,584
2,221
The fibonacci numbers are defined by F0 = 0 F1 = 1 and Fn = Fn-1 + Fn-2 for n >= 2.
F(k+1)-1F(k+1)+1 - F(k+1)2 but it ultimately gets me nowhere.
You want terms involving ##F_k##, ##F_{k+1}##, and ##F_{k-1}##, so use the defining relation to rewrite ##F_{k+2}##.
dirtybiscuit
You want terms involving FkF_k, Fk+1F_{k+1}, and Fk−1F_{k-1}, so use the defining relation to rewrite Fk+2F_{k+2}.
Thank you for your reply.
With that I get:
FkFk+2 - F2k+1
Fk(Fk+1 + Fk) - F2k+1
FkFk+1 + F2k - F2k+1
Fk+1(Fk - Fk+1) + F2k
I'm not really sure where to go from this point.
Just to verify that I am thinking of this the right way.
I am trying to find a spot that I can use the assumption made about k where (Fk-1Fk+1 - F2k) and link that to k+1 correct?
vela
Staff Emeritus
Education Advisor
15,584
2,221
With that I get:
FkFk+2 - F2k+1
Yes, that's what you're trying to do. You need to play around with it a bit. The ##F_{k+1}^2## term isn't one you want around, right? What can you do with it?
dirtybiscuit
Okay so this is what I got:
Fk+1(Fk - Fk-1) + F2k
Fk+1(Fk - Fk - Fk - 1) + F2k
-Fk+1Fk-1 + F2k
Multiply by -1 and get:
Fk+1Fk-1 - F2k = -(-1)k+1
So P(k) = -(-1)k+1
The part about the -1 on the right hand side threw me off at the end but I think it makes sense.
It seems unusual that this is proving k+1 though because it ends with P(k)
And again thank you for your help I have been looking at this problem for longer than I would care to admit.
vela
Staff Emeritus
Education Advisor
15,584
2,221
I'm not sure what you did here. It looks like you introduced a term out of thin air.
dirtybiscuit
I made a mistake when I was typing. It should have said Fk+1(Fk - Fk+1) + F2k
Then I used the defining relation on Fk+1 to get the next line.
Suggested for: Proof by Induction
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
