• Support PF! Buy your school textbooks, materials and every day products Here!
Proof f(x) = x is continuous
  • Thread starter Moogie
Hi
I'm new to calculus and I'm teaching myself so please be kind to me :)
How do you prove that f(x) = x is continuous at all points? I know a little bit about deltas and epsilons. I know that for a positive epsilon it is possible to get a delta such that
|(fx) - L| < epsilon for all x that satisfy 0 < |x-a| < delta
but i don't know if that can be applied here
I know that for f(x) = x then if it is continuous then you have to prove
lim (x->a) (fx) = f(a) for all x (i know the definition is more precise)
You can rewrite
as
lim (x->a) x= a
but this makes sense intuitively but is it a proof? How could you show this with deltas and epsilons.
I hope this isn't asking too much as I don't think its a hard answer for someone who knows what they are talking about
thanks
Answers and Replies
Office_Shredder
Staff Emeritus
99
This is one of those problems where the answer comes so fast from the definition that it's hard to see that you actually found it
The basic definition: For some value a, given [tex]\epsilon[/tex], we need to prove there exists [tex]\delta[/tex] such that if [tex]|x-a|<\delta[/tex], then [tex]|f(x)-f(a)|<\epsilon[/tex]. The first step is to substitute f(x) into this: f(x) is just x, and f(a) is just a.
For some value a, given [tex]\epsilon[/tex], we need to prove there exists [tex]\delta[/tex] such that if [tex]|x-a|<\delta[/tex], then [tex]|x-a|<\epsilon[/tex]
So if I tell you that [tex]|x-a|<\epsilon[/tex] is required, what value of [tex] \delta[/tex] should you pick?
I think this is where i got stuck when i tried to get the answer myself...
Why did you write |f(x) - f(a)| instead of |f(x) - L|
I get the feeling i'm not seeing the wood for the trees here. Is it because if
f(x) is continuous, then f(x) goes to f(a) as x goes to a, so the limit at a is f(a)?
But how can you say the limit at a is f(a)? Isn't that what you are trying to prove?
Or are you going to assert it and then prove it by saying you can get a delta to satisfy the epsilon for it, if that makes sense
Good question. You are trying to prove that the limit of f(x) as x goes to a is f(a), because that is the condition for continuity. The actual definition says that L is a limit if ... epsilons and deltas .... If you substitute f(a) (which exists independent of what the limit is) for L, you get that f(a) is a limit if ... epsilons and deltas ..., which is what you want to show.
Is that how you prove a limit then? Or at least one way to prove a limit.
You assert what the limit is and if you can show that for every positive epsilon there is a delta such that |f(x)-L| < epsilon for |x -a| < delta?
That seems backwards to me, or perhaps that is the way mathematical proofs are done i.e. you state the answer first and show it is true rather than 'deriving' the answer at the end from a series of steos.
5,288
Yes, that's right.
It's not really backward if you think about it. When you prove that the limit of a function is L, you have to already know what the limit is. You can think of this as being two parts: determining the limit, and then proving beyond doubt that the value you found is correct.
@officeshredder (or anyone)
so we assert that the limit is f(a). For this to be true we have to show that for every positive epsilon there is a delta such that |f(x)-L| < epsilon for |x -a| < delta?
so |f(x) - f(a)| < epsilon for all |x-a| < delta
or |x-a| < epsilon for |x-a| < delta
How do i start picking deltas and epsilons? This is my thought process:
Lets say i pick an epsilon greater than 0. This means the output of the function lies in the range (a-epsilon, a + epsilon). This means i have to pick a delta such that if |x-a| < delta, the outputs lie in that range.
I have no idea how to show this or test this
You are looking for a way to choose delta based on what epsilon is. For example, suppose that δ = g(ε). Then, if your choice of g(ε) is appropriate, you would have |x-a| < ε whenever |x-a| < g(ε).
If delta is less than epsilon then every input in the range (a-delta, a+delta) gives and output less than (a-epsilon, a+epsilon)?
Yes, that's right. Common practice is to do the least amount of work as possible, so people will often just choose one delta from the range of possible deltas you mentioned, e.g. δ = ε/2. But this problem is simple enough that your answer is perfectly all right, even better.
It's delta less than or equal to epsilon?
My brain keeps confusing me and saying to me 'how do i know |x-a| < epsilon and then i get muddled.
Is this a common source of confusion? Presumbaly the answer is because i set epsilon such that |x-a| < epsilon but that's where i keep wandering off track and losing focus
5,288
For this function, you can take delta to be equal to epsilon.
A delta epsilon proof can be thought of as a dialog between someone who doubts that L is the limit and someone who intends to prove that L is the limit.
The doubter says, "Well can you get f(x) within .05 of L?"
You say, "Sure, if x is within delta of a, then f(x) will be within .05 of L.
The doubter then says, "But can you get f(x) within .001 of L?"
You say, "Sure, I'll just choose a smaller delta, then f(x) will be within .001 of L.
and so on. Eventually, the doubter realizes that no matter how small an epsilon he tells you, you are able to find a number delta so that for any x within delta of a, f(x) will be within epsilon of L. On making this realization, the doubter gives up, and cedes the argument to you.
The real power of this technique is that it can be used even when the function isn't defined at a; i.e., f(a) doesn't exist.
Oh, I confused myself there. You can set delta less than or equal to epsilon (so actually δ = ε works just fine even though δ = ε/2 works as well).
This is a common point of confusion. Think about what it means to set δ = ε. We want to ascertain that for every ε > 0 there exists δ such that ... So, is this true if we set δ = ε? Yes, since setting δ = ε we get whenever |x - a| < δ = ε, |x - a| < ε.
This made a lot of sense to me - thank you
But the bit that kept confusing me when I was trying to work this out was
"how do i know |x-a| < epsilon. I don't even know what epsilon is so how do I know |x-a| is less than is"
Does that make sense? That's where i kept losing focus and going round in circles. If you could share some gem of wisdom that would stop me thinking that annoying thought it would be much appreciated
5,288
Somebody gives you epsilon, and says they want |f(x) - f(a)| < epsilon. Your job is to find a delta so that for any x such that |x - a| < delta, then |f(x) - f(a)| < epsilon.
This is especially easy to do for this function, since f(x) = x and f(a) = a. The only simpler problem is f(x) = c, a constant. Any delta will work, no matter how small epsilon is chosen.
Is it because I've got so much freedom i don't know what to do with it?
In other words, it's up to me what epsilon and x and a are. But if i pick a value of epsilon then I can pick a value for x and a such that |x-a| < epsilon. Doesn't matter what they are. But then if delta is less than or equal to epsilon, keeping the same values for x and a, |x-a| < delta <= epsilon?
In other words a and x are arbitary?
5,288
I don't think you get it yet.
a is fixed, and f(a) is fixed. Somebody else challenges you by picking an epsilon. You pick a delta based on that epsilon.
Now, any x you choose has to be within delta of a (i.e., 0 < |x - a| < delta) and if you have chosen delta correctly, f(x) will be within epsilon of L = f(a) (i.e., |f(x) - L| < epsilon.
Think about it in terms of a bow and arrow and the bull's eye on an archery target. Under ideal conditions you could hold the bow just right and the arrow would fly to the exact center of the bull's eye, which is analogous to L.
If you only need to get within, say, a circle of radius epsilon around the exact center, you have some freedom in how you point the arrow when you release the bowstring (analogous to delta). The smaller the target circle, the more precise you have to be on the initial position of the arrow.
I think you now have the right idea, although I'm not sure what you mean by a and x arbitrary.
Let's try to break this problem down a little more. A function is continuous by definition at a point a if the limit as x tends to a of f(x) is f(a). To prove a function is continuous at all points, you need to prove it for all a. So yes, to do this, we pick an arbitrary a, prove it is true for this a. Convince yourself that this proves it for all a.
Once we have chosen this arbitrary a, we can begin to look at the ε-δ limit definition. We need to show that for all ε > 0, there exists δ > 0, perhaps dependent on ε, such that (insert the rest). To prove this for every ε, we choose an arbitrary ε and prove it for this arbitrary ε. Convince yourself as above that this proves it for all ε.
In the end, what we want to show is that, given some fixed (but arbitrary) a and ε > 0, there exists this δ we have both been talking about such that whenever x is within some δ range of a, f(x) is within some ε range of f(a). In this part, to find δ, thinking in terms of a conversation as Mark44 suggested might help.
Does this clarify things a little more? There are a lot of variables in the limit definition, which can be confusing.
Isn't it a bit easier to just apply the definition for continuity? Delta epsilon is a lot more work and it's quite arbitrary/subjective since you can "manipulate" it. I find delta epsilon more useful for proving continuity at a particular given point
5,288
The OP had some questions specifically about delta-epsilon proofs. The definition of continuity at a point is a limit, so underlying it is the whole delta-epsilon business.
What makes it seem arbitrary or subjective?
Ah I see, my apologies. I never really enjoyed delta-epsilon proofs when I did them. The way my prof taught it, he basically said to pick a delta that works and if it doesn't, change the delta so that it works. I never really liked the concept of how we manipulate the proof just to get what we want but that's just my opinion.
Hi
I don't think I worded my last comment very well. I need to be more precise.
I should have said that variable a is arbitary but once you have chosen it, it is fixed. The same applies to x.
By this I mean, providing delta is not zero, then you can be sure than there exists numbers between a and a+delta (or a-delta) as you could always take the average of a and a+delta between them to get a number in the middle. Any of the numbers in this range could be x. Providing that delta is less than or equal to epsilon then the absolute value of the difference between any of the x's you pick in this range and this a will always be less than epsilon.
And this relationship would hold for any variable a you started with.
Or in other words I know that the interval of x is |x-a| < delta because that's part of the definition and if delta is less than or equal to epsilon then any x in this interval is also less than or equal to epsilon
5,288
Hi
No, the same does not apply to x. To show that f is continuous at a number a in its domain, you have to show that for any positive number epsilon that someone else gives you, there is a positive number delta such that, for any x in (a - delta, a + delta), f(a) - epsilon < f(x) < f(a) + epsilon.
Using somewhat more mathematical notation, you can say
[tex]\forall \epsilon > 0, \exists \delta > 0 \ni |x - a| < \delta \Rightarrow |f(x) - f(a)| < \epsilon[/tex]
Isn't that what i said? So long as x is in that interval?
I didn't say x could be anywhere, so long as it is in the interval defined
Related Threads on Proof f(x) = x is continuous
22K
  • Last Post
29K
  • Last Post
  • Last Post
  • Last Post
