Proof of Integral: $\int_0^{\infty}\frac{dx x^2}{e^x - 1} = 2\zeta(3)$
In summary, the integral \int_0^{\infty}\frac{dx x^2}{e^x - 1} can be proven to be equal to 2\zeta(3) by using a contour integral in the complex plane and utilizing the residue theorem. This can be further simplified by expressing the integral as a sum from n = 1 to infinity, and interchanging the summation and integration. The result is 2\zeta(3), which can be found using the Riemann zeta function.
nicksauce
1,271
An integral that seems to come up a lot in stat mech is
[tex]
[/tex]
Does anyone know how to prove this?
Hmm..the denominator looks, perhaps amenable to make some contour integral in the complex plane, and then utilize the residue theorem?
I'm not at all sure..years since I've done that sort of thing.
x^2/[exp(x) - 1] =
x^2 exp(-x)/[1 - exp(-x)] =
Sum from n = 1 to infinity of x^2 exp(-nx)
Integrate this from zero to infinity and interchange summation and integration:
Sum from n = 1 to infinity Integral from zero to infinity
x^2 exp(-nx)dx =
1/n^3 t^2 exp(-t)dt =
2 Zeta(3)
F***ing brilliant! Thanks!
1. What is the proof of the integral: $\int_0^{\infty}\frac{dx x^2}{e^x - 1}$?
The proof of this integral is a mathematical derivation that involves using the properties of complex numbers and the Riemann zeta function to evaluate the integral. It was first discovered by the mathematician Leonard Euler in the 1700s.
2. Why is the proof of this integral significant?
The proof of this integral is significant because it provides a solution to a previously unsolved mathematical problem known as the Basel problem. This problem involves finding the sum of the reciprocals of the squares of all natural numbers, and the proof of this integral is able to provide an exact solution for this sum.
3. What are the practical applications of this integral?
This integral is used in many areas of mathematics and physics, particularly in the study of heat transfer and blackbody radiation. It also has applications in number theory and is used to solve various types of mathematical problems.
4. How does the proof of this integral relate to the Riemann zeta function?
The proof of this integral is closely related to the Riemann zeta function, as it involves using the properties of this function to evaluate the integral. The Riemann zeta function is a mathematical function that is defined as the infinite sum of the reciprocals of all natural numbers raised to a given power.
5. Are there other proofs of this integral?
Yes, there are other proofs of this integral that use different mathematical techniques and concepts. Some may be simpler or more complex than the original proof, but they all ultimately lead to the same result of 2 times the value of the Riemann zeta function at a specific point.
  • Calculus
