Proof help
  1. Nov 5, 2006 #1
    If G is a group and x, y are in G. Show that o(x) = o(y^-1xy), where o(x) means order of x.
    thanks
  3. Nov 5, 2006 #2
    radou
    Which is your group operation?
  4. Nov 5, 2006 #3
    0rthodontist
    Why not try computing a few powers of y-1xy and see if that gives you any clues?
  5. Nov 6, 2006 #4
    isn't y-1xy=x since y-1y=e. so o(y-1xy)=o(x).
  6. Nov 6, 2006 #5
    0rthodontist
    Why would you think that? Not all groups are commutative.
    What is (y-1xy)2 equal to?
  7. Nov 6, 2006 #6
    matt grime
    Do not assume your group is commutative unless expressly told it is. yxy^-1 is most definitely not the same as x in general, and rule number 1 is that you should never assume otherwise unless told you may. I'm sure this was hammered home in your first lesson (and if not it should have been).
    Now, please try to follow the hint given. What is (yxy^-1)^2? (yxy^-1)^n?
    Remember that the order of z is the least positive n with z^n=1, so it obviously suffices to show that the order of z is less than the order of x, since by symmetry the order of x is then less than the order of z, so they are equal.
    You should go through that argument a couple of times to see why it is true, as well.
  8. Nov 6, 2006 #7
    (y-1xy)2 =y-2x2y2 =y-2+2x2=x2
  9. Nov 6, 2006 #8
    0rthodontist
    I don't think you're getting it. Could you provide what you think the justification is for each of those steps? This means working directly from the group axioms. You have three equal signs, which means you'll need three justifications.
    There's more than one problem here. First you say that (y-1xy)2 =y-2x2y2. That isn't necessarily true. Then you say that y-2x2y2 =y-2+2x2, which again is not necessarily true.
    To get you started,
    (y-1xy)2 = (y-1xy)(y-1xy). What does that equal? You can use the associative law and the definition of inverses.
  10. Nov 6, 2006 #9
    matt grime
    For the fourth (?) time: groups are not to be presumed commutative, you cannot do this. xy=/=yx. You cannot just swap round the order of x and y at will.
  11. Nov 6, 2006 #10
    i see. how about this..
    (y-1xy)(y-1xy) = y-1xyy-1xy = y-1x2y
  12. Nov 6, 2006 #11
    matt grime
    Yes. Now what about (yxy^-1) raised to the n'th power?
  13. Nov 6, 2006 #12
    that will be...
    (y-1xy)n = y-1xny
  14. Nov 6, 2006 #13
    NateTG
    And, now what happens when [itex]n=o(x)[/itex]?
  15. Nov 6, 2006 #14
    mathwonk
    1) conjugation is an isomorphism.
    2) isomorphisms preserve order of elements.
  16. Nov 7, 2006 #15
    xn= e.what are the next steps in this proof?
  17. Nov 7, 2006 #16
    matt grime
    Can you please try and put two and two together? You're asked to raise something to the power n, and then asked to consider what happens when n is the order of x. Now, please, try to think what that might mean.
  18. Nov 7, 2006 #17
    thanks. that was easy.
  19. Nov 7, 2006 #18
    0rthodontist
    You're not done yet, though, because you also must show that no smaller positive power of y-1xy equals e. Pick the smallest power (y-1xy)k that equals e, and show that k = |x|. (the order of x)
  20. Nov 8, 2006 #19
    HallsofIvy
    You just said "xn= e". Use that in your formula (y-1xy)n= y-1xny!
    However, o(x) is defined as the smallest n such that xn= e. Just showing that (y-1xy)n= e is not enough to say that the order of y-1xy is n.
