Is n4 - 1 divisible by 5 when n is not divisible by 5?
  • Thread starter GP35
  • Tags
    Proof
In summary, the solution to the problem of showing n4 - 1 is divisible by 5 when n is not divisible by 5 involves using proof by cases. One case considers n being of the form n= 5k+ 1, n= 5k+ 2, n= 5k+ 3, or n= 5k+ 4, while the other case considers n= 5k- 2, n= 5k- 1, n= 5k+ 1, and n= 5k+ 2. By applying the binomial theorem and considering the values of m that satisfy m^{4}\equiv 1 (mod5), we can determine
GP35
Show n4 - 1 is divisible by 5 when n is not divisible by 5.
My thought here is proof by cases, one case being where n is divisible by 5 and the other case saying n is not divisible by 5. I am just not totally sure how to implement this strategy.
If you split your second case a bit more that will do fine.
If n is not divisible by 5, then it is of the form n= 5k+ 1, n= 5k+ 2, n= 5k+ 3, or n= 5k+ 4.
Or you can consider n= 5k- 2, n= 5k- 1, n= 5k+ 1, and n= 5k+ 2 if that makes the calculations simpler.
If we would to spent a little more time to think through , we will realize that the determining factor will then lies in [tex]5k \pm m[/tex] such the [tex]m^{4}\equiv 1 (mod5)[/tex] with application with binomial theorem.
What is divisibility?
Divisibility is the property of a number being evenly divisible by another number without leaving a remainder. In other words, when one number is divided by another, the result is a whole number.
How do I prove divisibility?
There are a few different methods for proving divisibility depending on the specific situation. Some common techniques include using the division algorithm, testing for divisibility by specific numbers (such as 2, 3, 5, etc.), and using mathematical induction.
What is the division algorithm?
The division algorithm is a mathematical procedure used to divide two numbers and obtain a quotient and remainder. It is often used to prove divisibility, as the remainder can reveal whether or not the two numbers are evenly divisible.
How can I use mathematical induction to prove divisibility?
Mathematical induction is a technique used to prove statements about natural numbers. To use it to prove divisibility, you would first show that the statement is true for a specific number (usually 1). Then, you would assume it is true for a particular number (k), and use that assumption to prove it is also true for the next number (k+1). If you can show that the statement is true for both 1 and k+1, then it must be true for all natural numbers.
Why is proving divisibility important in mathematics?
Proving divisibility is important in mathematics because it allows us to understand the relationships between numbers and identify patterns. It also helps us to solve more complex problems and make generalizations about numbers. Additionally, divisibility is a fundamental concept in number theory, which has many applications in fields such as cryptography and computer science.
