Proof involving sums
signalcarries
Prove that [tex]\sum_{k=0}^{l} \binom{n}{k} \binom{m}{l-k} = \binom{n+m}{l}[/tex]
If [tex]a[/tex] and [tex]b[/tex] are any numbers and [tex]n[/tex] is a natural number, then [tex](a+b)^{n}=\sum_{j=0}^{n} \binom{n}{j} a^{n-j}b^{j}[/tex]
I know that [tex](1+x)^{n}(1+x)^{m}=(1+x)^{n+m}[/tex] so that [tex]\sum_{k=0}^{n} \binom{n}{k}x^{k} \cdot \sum_{j=0}^{m} \binom{m}{j}x^{j} = \sum_{l=0}^{n+m} \binom{n+m}{l}x^{n+m}[/tex]
If I let [tex]j=l-k[/tex], then I get [tex]\sum_{k=0}^{n} \binom{n}{k}x^{k} \cdot \sum_{l=k}^{m+k} \binom{m}{l-k}x^{l-k} = \sum_{l=0}^{n+m} \binom{n+m}{l}x^{n+m}[/tex]
I can see that I'm close to the desired result--I'm just having trouble understanding how to get to it.
Answers and Replies
Dick
26,263
621
You have some index problems. In your final solution l is a dummy index (twice). In your original problem it's not. If you fix this I think you will see the solution. You aren't as close as you think, nor are you as far away as you think.
Dick
26,263
621
The dummy problem is coming because when you set l=j+k you are actually saying 'pick the x^l term' from the right side (where the power of x should have been x^l, not x^(n+m)). Since you are selecting a specific l, the sum goes away on the right. The constrain l=j+k will also get rid of one of the sums on the left.
signalcarries
OK, so I am picking a specific value for l by choosing l=j+k, although this still seems a little strange to me, since I am summing over j and k on the LHS. Is it kind of like a function where I input two values (some j and some k) on the LHS, giving me a value on the RHS?
I can see that two of the sums will disappear. I think this leaves me with:
[tex]\sum_{k=0}^{n} \binom{n}{k} \binom{m}{l-k} x^{l} = \binom{n+m}{l}x^{l}[/tex]
I'm still having trouble seeing why my final sum runs from 0 to l.
Dick
26,263
621
What you are really doing is picking off the x^l term on both sides. If two polynomials in x are equal for all x, then coefficients of each power of x are equal on both sides. If k>l in the first sum, then it doesn't contribute.
Suggested for: Proof involving sums
  • Last Post
  • Last Post
