Homework Help: Proof of differentiation
  1. Sep 12, 2014 #1
    Angular momentum of a particle is: L = (dr/dt) x mr
    Show that (dL/dt) = (d2r/dt2) x mr
    2. Relevant equations
    3. The attempt at a solution
    My atempt is that I tried writing it in the form y = mx + c but I don't think that would be relevant.
    Next I tried straight forward rule application derivision (it was wrong to try that)
    Basically, my knowledge on differentiation isn't up to par and so far I haven't tried integrating it but I seriously doubt it'd lead to the answer and I don't know how to apply an intergral of (dL/dt) to the mr term.
    Thanks in advance
    I've also considered writing r = irx + iry + irz but again, no idea how to apply it in equation.
  3. Sep 12, 2014 #2
    Matterwave
    Do you know the product rule of differentiation? You can apply it to a cross product too. For example, would you be able to do this:
    $$\frac{d}{dt}(\vec{A}\times\vec{B})$$
  4. Sep 12, 2014 #3
    vela
    Staff Emeritus
    Education Advisor
    Are you sure this is correct? Angular momentum is usually defined as ##\vec{L} = \vec{r}\times\vec{p}##, where ##\vec{p}=m\vec{v}## is the momentum. It differs from your definition by a sign.
    Tried writing what? What's "it" supposed to be?
    What rule? What's "derivision"? I'd guess you mean differentiation, but you used the word differentiation correctly below so perhaps not.
    Good, you identified a problem. Now you need to do something to fill the gap in your knowledge. Did you check your book for a similar example? Perhaps there's an appendix that covers or reviews some math. You could try googling "differentiating a cross product".
    Yeah, you're trying to calculate a derivative, so integrating likely isn't going to help.
  5. Sep 14, 2014 #4
    Actually, going over some notes, I can see where errors were made, sorry about that.
Have something to add?
Draft saved Draft deleted
