Proving the Impossibility of Odd Pythagorean Triples
  • Thread starter saadsarfraz
  • Tags
    Proof
In summary, the conversation discusses a proof for showing that in a Pythagorean triple, a and b cannot both be odd. This is because when both a and b are odd, their sum squared cannot be a perfect square in modular arithmetic. This proof applies to any odd numbers, not just 1.
saadsarfraz
86
If we have a pythagorean triple a^2 + b^2 = c^2 and we need to show that a and b both cannot be odd. I found a proof from a website:
if a and b both odd, then we must have c[tex]^{2}[/tex][tex]\equiv[/tex]a[tex]^{2}[/tex]+b[tex]^{2}[/tex][tex]\equiv[/tex]1+1[tex]\equiv[/tex]2 (mod4), which is a contradiction, since 2 is not a square mod 4. Hence at least one of a and b must be even.
I didnt quite understand the proof as this is just when a and b are 1? what about other odd numbers.
If a is odd then [tex] a^2=[1] [/tex] in [tex]\mathbb{Z}_4[/tex] (The only odds in there are 1 and 3, both give 1 when squared).
What is the Pythagorean Theorem?
The Pythagorean Theorem is a mathematical principle that states that in a right triangle, the square of the length of the hypotenuse (the side opposite the right angle) is equal to the sum of the squares of the other two sides.
What is a Pythagorean Triple?
A Pythagorean Triple is a set of three positive integers that satisfy the Pythagorean Theorem. In other words, when the three numbers are used as the lengths of the sides of a right triangle, the theorem holds true.
How do you prove a Pythagorean Triple?
To prove a Pythagorean Triple, you must show that the three numbers satisfy the Pythagorean Theorem. This can be done by squaring each number and then checking if the sum of the squares of the two smaller numbers equals the square of the largest number.
What are some examples of Pythagorean Triples?
Some examples of Pythagorean Triples include (3, 4, 5), (5, 12, 13), and (8, 15, 17). These numbers can be easily verified as Pythagorean Triples by using the Pythagorean Theorem.
Why is the Pythagorean Theorem important?
The Pythagorean Theorem is important because it has many real-world applications, such as in construction and engineering. It also helps us understand the relationship between the sides of a right triangle and can be used to solve various mathematical problems.
  • General Math
