Proof of unitarity of time evolution in Susskind's book
In summary: O6AQAAQBAJ&printsec=frontcover&dq=Quantum%20mechanics%20The%20Theoretical%20Minimum&hl=en&sa=X&ved=0ahUKEwj5hrev7OHMAhUCgj4KHd0jAcoQ6AEIHDAA#v=onepage&q=Quantum%20mechanics%20The%20Theoretical%20Minimum&f=falseUnfortunately the pictures are out of focus......
entropy1
1,230
71
In "The Theoretical Minimum" of Susskind (p.98) it says that if we take any two basisvectors [itex]|i \rangle[/itex] and [itex]|j \rangle[/itex] of any orthonormal basis, and we take any linear time-development operator [itex]U[/itex], that the inner product between [itex]U(t)|i \rangle[/itex] and [itex]U(t)|j \rangle[/itex] should be 1 if [itex]|i \rangle=|j \rangle[/itex]. Why is this so? (Why is the product normalized?) I can see how it is demonstrated that the inner product of [itex]U(t)|i \rangle[/itex] and [itex]U(t)|j \rangle[/itex] is 0 if [itex]|i \rangle \neq |j \rangle[/itex] (in fact, he assumes it). The reasoning is aimed to show that time evolution is unitary.
A. Neumaier said:
<##Ux|Uy##>=<##x|U^*Uy##>=<##x|y##> since U is unitary.
No, no, the reasoning is aimed to prove unitarity of U.
Unitarity of ##U(t) =e^{-itH}## is trivial since ##U(t)^*=e^{-i^*tH^*}=e^{itH}=U(t)^{-1}##.
Does this hold for any linear time-development operator [itex]U[/itex]? Are they all expressed as ##U(t) =e^{-itH}##?
Yes, in units where ##\hbar=1##. Without this restriction, the Schroedinger equation
##i \hbar \dot\psi(t)= H\psi(t)## has the solution ##\psi(t)=e^{-itH/\hbar}\psi(0)=U(t)\psi(0)##
where ##U(t):=e^{-itH/\hbar}##.
If the Hamiltonian depends on time, the formula is more complicated (with Texp), and unitarity is easier to see by differentiating ##\langle \phi(t)|\psi(t)\rangle##, showing that it is constant.
Likes entropy1
Thank you. But still I don't get the proof Susskind is trying to give, so if anyone understands his line of reasoning on this, my question still stands! (peruse my OP!) :biggrin:
I'm guessing that you're muddling the argument somehow. Unitary matrices preserve preserve the inner product / perpendicularity (i.e. ##\langle a | b \rangle = \langle Ua | Ub \rangle##). Knowing that the linear time-development is unitary would allow you conclude length-preserving, and vice versa knowing the time-development was length-preserving would be important to showing unitarity, but from your quote it's not clear which is being proved from the other.
The postulate of U=unitary is not made! U=unitary is to follow from the postulates he gave in his book, which I tried to describe in my OP. (That is: it is to be proven that U=unitary)
The core of my question is:
entropy1 said:
[..]the inner product between [itex]U(t)|i \rangle[/itex] and [itex]U(t)|j \rangle[/itex] should be 1 if [itex]|i \rangle=|j \rangle[/itex]. Why is this so? (Why is the product normalized?)
Then you missed some of the postulates. Does the book give a definition for "linear time development operator"?
No, none at all...
Since ##U(t)|i\rangle## and ##U(t)|j\rangle## are the same state, the condition imposed is simply conservation of the norm.
Exactly! :biggrin: But why is the norm conserved?! (it doesn't follow from the proof)
entropy1 said:
No, none at all...
I'm not sure I believe you. Can you take a picture of the page?
Likes entropy1
Because of the Born rule. You want probabilities to stay probabilities.
Likes Demystifier and bhobba
Unfortunately the pictures are out of focus... :frown:
But the form [itex]\langle i|M|j \rangle[/itex] isn't a probability, is it? :wideeyed: At this point in the book, probabilities are formulated as the product of the inproduct of the eigenvector with the state and the the conjugate of the inproduct of the eigenvector with the state.
No, but the evolution operator returns a state.
Take a quantum system in state ##|\psi\rangle = |i\rangle##. What is the probability that it is in state ##|j\rangle##?
##\langle j | \psi \rangle = \langle j | i \rangle = \delta_{ij}##.
Now, after some time ##t##, what is the probability that the system is in state ##| \phi\rangle \equiv U(t)|j\rangle##?
##\langle \phi | U(t) | \psi \rangle = \langle \phi | U(t) | i \rangle = \langle j | U^\dagger(t) U(t) | i \rangle##
Now, if ##| i \rangle = | j \rangle##, then ##U(t) | \psi \rangle = | \phi \rangle##, so setting
##\langle \phi | U(t) | \psi \rangle = \langle \phi | \phi \rangle = 1##
is the same as taking ##U(t)## to be unitary.
Likes Jilang and entropy1
Susskind writes:
Susskind said:
The state at time t is given by some operation that we call ##U(t)##, acting on the state at time zero. Without further specifying the properties of ##U(t)##, this tells tells us very little except that ##|ψ(t) \rangle## is determined by ##|ψ(0) \rangle##. Let's express this relation with the equation ##|ψ(t) \rangle = U(t)|ψ(0) \rangle##. The operation U is called the time-development operator for the system.
And then:
Susskind said:
Conventional quantum mechanics places a couple of requirements on ##U(t)##. First, it requires ##U(t)## to be a linear operator.
Then he mentions ##U(t)## requires to obey the conservation of distinctions, which is that ##U(t)## operating on orthogonal states remains orthogonal. He illustrates this by taking two different vectors ##|i \rangle## and ##|j \rangle## of an arbitrary orthonormal basis.
He writes:
Susskind said:
On the other hand, if i and j are the same, then so are the output vectors ##U(t)|i \rangle## and ##U(t)|j \rangle##. In that case, the inner product between them should be 1.
Take note of the "should be 1" part!
I fail to see why ##\langle \phi | \phi \rangle = 1## if ##| \phi\rangle = U(t)|j\rangle##. Why is the norm conserved? For instance: ##U(t)|j \rangle## could be twice as long as ##|j \rangle##!
The choice of normalizaton is arbitrary, but we should expect that once that choice is made, the equations are consistent and that the norm doesn't change (especially since the norm is related to probabilities).
If the norm is conserved, I can see why ##U## is unitary. It seems to me Susskind hasn't made that conclusive. I have to take your word on that it is necesary to preserve probabilities (perhaps it should be a postulate then?). Thanks for your replies! (and the others :wink: )
To make the math easier so the Born rule can be used it is desirable that states of unit length remain unit length. This implies it must be unitary.
There is a deep theorem associated with this Susskind doesn't mention because its advanced (you will learn of it in Ballentine) called Wigners Theroem:
https://en.wikipedia.org/wiki/Wigner's_theorem
But don't worry about it for now. As I often say in QM the full story sometimes isn't told at the start - you need to build up to it.
Thanks
Bill
Likes entropy1 and DrClaude
In an earlier chapter on quantum states (p.40),
Susskind said:
$$ \langle A|A \rangle = 1 $$
This is a very general principle of quantum mechanics that extends to all quantum systems: the state of a system is represented by a unit (normalized) vector in a vector space of states. Moreover, the squared magnitudes of the components of the state-vector, along particular basis vectors, represent probabilities for various experimental outcomes.
Likes entropy1, Demystifier and DrClaude
As others told you, unitarity follows from the requirement that ##|\psi|^2## is probability and the fact that sum of all probabilities (of mutually exclusive events) must be equal to 1.
For such technical trivialities explained in a beginner-friendly way I highly recommend "Quantum Mechanics Demystified" by McMahon. (See also https://www.physicsforums.com/threads/the-ultimate-demystifier.871588/#post-5472646 )
Likes entropy1 and bhobba
What does "unitarity of time evolution" refer to?
"Unitarity of time evolution" refers to the principle that the total probability of all possible outcomes of a system's evolution must always equal 1. In other words, the sum of the squared magnitudes of all possible state vectors of a system must always equal 1.
What is the significance of unitarity of time evolution in Susskind's book?
Susskind discusses the unitarity of time evolution in his book as a fundamental principle of quantum mechanics. It is essential for maintaining the consistency and predictability of the quantum world.
How is unitarity of time evolution related to the Schrödinger equation?
The Schrödinger equation is the mathematical representation of the unitary time evolution of a quantum system. It describes how the state of a system changes with time and ensures that the total probability of all possible outcomes remains 1.
What evidence supports the unitarity of time evolution in quantum mechanics?
Empirical evidence, such as the results of experiments, supports the unitarity of time evolution in quantum mechanics. The consistency and predictability of quantum systems, as well as the agreement between theoretical predictions and experimental observations, provide evidence for the validity of this principle.
Are there any exceptions to the unitarity of time evolution?
In specific scenarios, such as when a system interacts with an external environment, the unitarity of time evolution may appear to be violated. However, this is only an apparent violation and can be explained by considering the entire system, including the environment. Ultimately, the unitarity of time evolution remains a fundamental principle in quantum mechanics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
