- 153
- 6
Does anyone know a proof of taylor formula (actually I am looking for proof for maclaurin series but guess it is the same) without using derivation rules for polynomials?
I belive this explains taylor theorem
http://bildr.no/view/1030479
but it uses the rule I mentioned above
I don't know of any proof where that fact doesn't play some role. I glanced at a proof in a book that began by using an integration by parts, but that required knowing how to integrate [itex] (x-t)^n [/itex], which involves knowledge of how to differentiate.
I guess the same problem goes for binomial theorem?
You should polish your writing skills, georg! Are you asking whether there is a proof of Taylor's formula that does not rely on binomial theorem? Or are you asking whether there is a proof of the binomial theorm that does not rely on the differentiation rules for polynomials? I think the binomial theorem can be proven without using derivatives.
I don't know where I am not being clear :(
Ok I will try to explain it as clear as possible:)
Purpose:
Prove that
[tex](e^x)^y=e^{xy}[/tex]
As I understand your goal, you wish to prove:
Theorem 1: If [itex] x [/itex] is a real number and [itex] r [/itex] is a rational number then [itex](e^x)^r = e^{xr} [/itex].
Is that correct? Or do you want [itex] x [/itex] to also be a rational number?
So it is the problem with how to differentiate polynomials in link two (II) that I can't prove here
But I had to use the elementary power rule. But why do you not want to use it? You can easily prove it.
[tex]y=x^n[/tex]
[tex]\mbox{ln}y=n\mbox{ln}x[/tex]
[tex]\frac{1}{y}\frac{\mbox{d}y}{\mbox{d}x}=\frac{n}{x}[/tex]
[tex]\frac{\mbox{d}y}{\mbox{d}x}=\frac{nx^n}{n}[/tex]
[tex]\frac{\mbox{d}y}{\mbox{d}x}=n{x}^{n-1}[/tex]
You use the rule for log with any base:
[tex]log_x a^x=x log_x a[/tex]
I wanted to prove 4 in link here
http://bildr.no/view/1031000 (t)
there i used the log rule you used so I had to prove that one as well. I tried proving it with derivation:
http://bildr.no/view/1031585
but it relies on among others rules rule for differntiation of polynomials. The other rules I can prove but the proof for power rule relies on log rule and then I can't prove the log rule this way.
I have tried to explain it more clear in post number 12 on the first page of this thread
Someone said earlier in this thread that it was a proof for 4 (4 is in the first link (t) in this post) that used among other things dedekinds cut to prove it for all real numbers if someone know where I could find it or buy it online I would be very thankful!
[tex]\mbox{We know that } e=\lim_{n\rightarrow\infty}{\left(1+\frac{1}{n} \right)}
^{n}=\lim_{h \rightarrow 0}\left(1+h\right)^\frac{1}{h}[/tex]
I need to prove lhopitals I am working on it
