Propability Questions
1.In the ``game'' of Russian roulette, the player inserts a single cartridge into the drum of a revolver, leaving the other five chambers of the drum empty. The player then spins the drum, aims at his/her head, and pulls the trigger. 1.What is the probability of the player still being alive after playing the game [tex]N[/tex] times?
2.What is the probability of the player surviving [tex]N-1[/tex] turns in this game, and then being shot the [tex]Nth[/tex] time he/she pulls the trigger?
3.What is the mean number of times the player gets to pull the trigger?
(I'm in the process of learning LaTex, but for now....)
1. The chances of the person still being with 5 chambers is
[tex]\sum_{n=zero}^4 \frac{1}{5-n}[/tex]
series from n=0 to n=4 (1/(5-n)
right? This would equate to 1/(5-0) + 1/(5-1) + 1/(5-2) etc etc...
i'm a bit stumped at question #2 however.
Answers and Replies
statdad
1,495
36
First write out the chance that when the trigger is pulled the bullet is not under the hammer: this will also give you the chance the bullet is under the hammer.
Now for the first question: if the player is still alive after N trigger pulls, the bullet was not under the hammer any of those times (not the first AND not the second AND ... AND not the Nth): how would you find the probability of that joint event?
For the second: if the player is not shot until trigger pull N, that means the first N-1 tries did not have the bullet under the trigger AND the Nth trigger pull did: find the probability of that joint event.
As a start to see what happens, you might try working out each solution in the very special case N = 3, just to see how the numbers work out.
Related Threads on Propability Questions
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
