Propagaton of errors
  1. Sep 8, 2007 #1
    the mass of a particular sample of rock retrived from Mars is m=772.2+or-0.2g. The sample is in the shape of cylinder of height h=10+or-0.1 cm and base radius r=2.5 +or-0.1cm. calculate the density of the rock sample in units of kg/m^3. You must state your result in the correct units with its associated uncertainty. The volume of a cylinder is V=pir^2h.
    2. Relevant equations
    3. The attempt at a solution
    I can get the density but I cannot get the correct uncertainty.
    The density I get is
    (772.2g/196.35cm^3)((1 kg/m^3)/10^-3g/cm^3)=3932.77 kg/m^3
    I believe the uncertainty is supposed to be +or-400 but I end up with four.
    (delta p)/(3.9g/cm^3) = .2/772.2 + .14/196.35
    delta p = .004 g/cm^3
    .004 g/cm^3 ((1kg/m^3)/(10^-3 g/cm^3) = 4 kg/m^3
    Im new to this propagation of errors stuff. Using sig figs other people in my class got either 4000 +or- 400(or +or- 100) I cant remember.
  3. Sep 8, 2007 #2
    The uncertainty for your volume seems off... can you show how you got it?
  4. Sep 8, 2007 #3
    Dr Transport
    Start with the formula for the density......Take the derivatives with respect to the variables etc.... try it and we will hepl along.
  5. Sep 9, 2007 #4
    I tried to find the uncertainty for volume again. I am probably calculating the error wrong.
    (delta v/196.35) = 2pi(.1/2.5)+(.1/10)
    delta v = 51 cm^3
    (delta p)/(3.9g/cm^3) = .2/772.2 + 51/196.35 = 1.014 g/cm^3
    1.014 g/cm^3 ((1kg/m^3)/(10^-3 g/cm^3) = 1014 kg/m^3
    this seems way to high. I was given an online manuel on how to calculate propagation of error but my calculations always seem off.
    To Dr Transport I do not believe have never seen of been taught that method.
  6. Sep 9, 2007 #5
    I think this is the mistake:
    looking at the quantity without pi, call it x = r^2*h:
    (delta x/62.25) = 2(.1/2.5)+(.1/10) = 0.09
    delta x = 0.09*62.5 = 5.625
    So the error in pi*r^2*h is 3.14*deltax = 17.67
    so delta v = 17.67
