Decoherence and Determinism: Understanding the Role of Randomness in Proper Mix
  • Thread starter kye
  • Tags
    Randomness
In summary, decoherence is deterministic and not random (probabilities). Random or probabilities only occurred in proper mix? Why. Is it not possible to calculate exactly the wavelets and waveforms of the wave functions to tell how exactly the decohering interference occur and from there determine why it is in certain state (deterministic)? Why not?Its saying the mathematical form of the state of an improper mixture and a proper mixture is exactly the same, namely ∑ pi |bi><bi|, where the |bi> are eigenvectors of the observable corresponding to the observation being made. A proper mixture is the states |bi><bi| randomly selected and presented for observation. The state is
kye
168
In decoherence.. it is said that it is in an improper mixed FAPP (for all purposes) which is the same as collapse. Are you saying that decoherence is deterministic and not random (probabilities)? Random or probabilities only occurred in proper mix? Why. Is it not possible to calculate exactly the wavelets and waveforms of the wave functions to tell how exactly the decohering interference occur and from there determine why it is in certain state (deterministic)? Why not?
Its saying the mathematical form of the state of an improper mixture and a proper mixture is exactly the same, namely ∑ pi |bi><bi|, where the |bi> are eigenvectors of the observable corresponding to the observation being made. A proper mixture is the states |bi><bi| randomly selected and presented for observation. The state is there prior to observation, and since it is an eigenvector of the observable will not be changed by the observation. The probability of getting |bi> is the corresponding pi. Collapse never occurs - everything is honkey-dorey - QM - no issues. The state of an improper mixture is created by decoherence and is exactly the same. There is no way to tell the difference. If it was a proper mixture collapse would have actually occurred. That is what is meant by apparent collapse - it looks exactly the same - but really isn't.
Its all in the paper I have posted about it innumerable times:
http://philsci-archive.pitt.edu/5439/1/Decoherence_Essay_arXiv_version.pdf
See section 1.2.3
BTW the jig is up here - I can't explain the math in layman's terms - if the math is beyond you - sorry you will need to learn it to understand it.
Thanks
Bill
See section 1.2.3
Thanks
Bill
I prefer the terminology that decoherence solves the "pointer basis" problem.
What I find confusing about the "apparent collapse" language, especially the claim that it is interpretation free is that in the naive textbook interpretation, collapse is how definite outcomes are produced. Decoherence cannot produce definite outcomes, so without an interpretation to produce definite outcomes, decoherence is not equivalent to collapse for all practical purposes, since there are no definite outcomes. In contrast, in the many-worlds interpretation, there are definite outcomes without collapse, and there is only apparent collapse, so in the many-worlds interpretation it does seem that decoherence is as good as collapse for all practical purposes.
The standard formalism, which decoherence uses, produces definite outcomes so decoherence doesn't have to explain it.
Why it does that is the problem of definite outcomes - only some interpretations answer that eg MWI.
If you don't want to believe decoherence explains collapse FAPP, go ahead, you are not the only one. Its simply my and many others view.
Added Later:
Just to elaborate further, a proper mixed state has definite outcomes because its assumption is a particular outcome is randomly selected.
Thanks
Bill
See section 1.2.3
Thanks
Bill
Hi Bill, is the paper shared above peer reviewed? It doesn't appear in arxiv (is it rejected.. why didn't it appear there)... how many percentage of physicists believe that paper is valid or how could one exclude possibility of author's bias or some subtle misconception?
It's, as it states, an essay reviewing standard stuff - its not really anything new - simply a write-up in one place.
It's contains the same stuff as Schlosshauer's standard textbook:
https://www.amazon.com/dp/3540357734/?tag=pfamazon01-20
But if you are worried get Schlosshauer's textbook - its where I learned it from.
Thanks
Bill
If Decoherence were true, why hadn't Bohr, Schroedinger, Born, Heisenberg, Pauli, von Neumann, Einstein thought of it? Why only Zurek? And why is there no Nobel Prize for Zurek (seriously) if he beat all of them?
And about the C60 or C70 Buckyball. Is there no possibility it could still be explained by collapse? Maybe regional/sectional collapse that we mistook for decoherence? Maybe Bohr could still explain it by collapse if he were alive today?
Bas Hensen's essay http://philsci-archive.pitt.edu/5439/1/Decoherence_Essay_arXiv_version.pdf is basically sound. It is based largely on Schlosshauer's book https://www.amazon.com/dp/3540357734/?tag=pfamazon01-20 that bhobba linked to above. I haven't read Schlosshauer's book, but Hensen's essay seems consonant with Schlosshauer's article in Reviews of modern Physics http://arxiv.org/abs/quant-ph/0312059.
There is much superb work that is not recognized by a Nobel Prize. Also, other physicists have worked on decoherence. For example, it is used to explain why some molecules are chiral, for which Schlosshauer references Harris and Stodolsky's 1981 paper, and Zeh's 2000 paper.
Decoherence is undoubtedly correct, but it does not favour one interpretation over another. It is most powerful in the many-worlds interpretation, where it seems quite convincing in explaining the appearance of collapse. In the Copenhagen interpretation (by which I mean the naive textbook interpretation), decoherence does not remove the need for collapse, but it goes some way to explaining why a classical apparatus may be outside one Heisenberg cut (or von Neumann cut), but inside another.
of course, there are, objective reduction models.
http://plato.stanford.edu/entries/qm-collapse/
http://www.perimeterinstitute.ca/videos/recent-developments-collapse-models
"they explain why measurements always have definite outcomes, distributed according to the Born probability rule".
Remember Bohr was able to refute Einstein great attempt to bypass HUP by a complicated setup. Maybe objection reduction models can be converted into pure Bohr reasoning? How.. section by section collapse?.. or maybe Bohr explaining since collapse is only on paper and not actually there existing, the calculations can show collapse even for C60? How would Bohr explain the Buckyball experiments if he were alive today? Or there is not another human as incredibly genius as Bohr?
The GRW theory is not equivalent to quantum mechanics. It is beyond the standard model, and predicts violations of quantum mechanics.
It wasn't only Zureck - there were many others.
It basically actually started with MW and developed from there.
It takes time for ideas to ferment and percolate.
Thanks
Bill
Well put.
And indeed decoherence really is very elegantly applied to MW. It is also extremely valuable in Consistent Histories leading to its alternate name - Decoherent Histories.
But there are people like Ballentine, while in no way denying decoherence, you can't really because the formalism implies it, believe its of zero value as far as interpretations go.
Thanks
Bill
Thanks
Bill
Does decoherence disprove Bohr's division into quantum and classical world or does Bohr still have surprises up his sleeve? His objections are powerful. For example, he countered Einstein EPR argument by saying distances didn't matter because it was one big experiment setup. Could he explain the buckyball experiment by saying it didn't show otherwise and there is still divisions between the classical and quantum world simply because the wave function doesn't exist in the objects but just an operation we perform on paper, isn't this what also some still believed? Or do 100% of physicists agree that the buckyball experiment disprove Bohr's division of quantum and classical world?
There is no division - everything is quantum and this was Bohr's mistake:
http://scitation.aip.org/content/aip/magazine/physicstoday/article/58/11/10.1063/1.2155755
'Bohr’s version of quantum mechanics was deeply flawed, but not for the reason Einstein thought. The Copenhagen interpretation describes what happens when an observer makes a measurement, but the observer and the act of measurement are themselves treated classically. This is surely wrong: Physicists and their apparatus must be governed by the same quantum mechanical rules that govern everything else in the universe. But these rules are expressed in terms of a wavefunction (or, more precisely, a state vector) that evolves in a perfectly deterministic way. So where do the probabilistic rules of the Copenhagen interpretation come from?
Considerable progress has been made in recent years toward the resolution of the problem, which I cannot go into here. It is enough to say that neither Bohr nor Einstein had focused on the real problem with quantum mechanics. The Copenhagen rules clearly work, so they have to be accepted. But this leaves the task of explaining them by applying the deterministic equation for the evolution of the wavefunction, the Schrödinger equation, to observers and their apparatus. The difficulty is not that quantum mechanics is probabilistic—that is something we apparently just have to live with. The real difficulty is that it is also deterministic, or more precisely, that it combines a probabilistic interpretation with deterministic dynamics.'
Decoherence is a major part of that considerable progress.
Thanks
Bill
Thanks
Bill
This assumes the states are real and there in the objects. But in Bohr's view. Everything is really classical, probability only came about in calculations and only occurred in ensembles. I talked with a physics professor. He laugh off the idea of interpretations. He said it's all about eigenvalues and eigenfunction and state vectors and this is what we can know about objects.
Can others who still support Bohr here share why Bohr may still be right? Note decoherence is inspired from Bohmian and Many Worlds and these two are trying to make the quantum understandable or conformed to the thoughts and bias of the human mind. Maybe everything is really still classical and probability and wave functions are just to compute probabilities of occurences. If this is true, does this refute decoherence?
That's got nothing to do with anything.
I think you need to understand Copenhagen and exactly what later interpretations like Consistent Histories did to fix up it's issues, which in the great scheme of things were in fact relatively minor.
Lubos, although for me he can come across as bit closed minded on occasion, although usually correct, and often interesting, explains this fairly well:
http://motls.blogspot.com.au/2011/05/copenhagen-interpretation-of-quantum.html
Thanks
Bill
Thanks
Bill
I read the lubus paper and understood it fully. Bottomline is. Docoherence is only interesting for Bohmian and Many Worlds. It is not important for Copenhagen because since collapse is not real in the objects. May as well just accept Collapse. Decoherence just makes it more complicated. In the Buckyball experiment, we can say that collapse occur regionally for each interaction with the environment. Unless you are saying that this is not possible and the language of decoherence is required 100%?
That really has me perplexed:
Measurement devices are classical
The fifth rule says that the measurement devices follow the rules of classical physics. This is another source of misunderstandings.
The Copenhagen school surely didn't want to say that quantum mechanics couldn't be applied to large systems. Indeed, many people from the Copenhagen school were key researchers who helped to show that quantum mechanics works for large systems including molecules, bubble chambers, solids, and anything else you can think of.
Instead, this rule was meant as a phenomenological rule. If you measure something, you may assume that the apparatus behaves as a classical object. So in particular, you may assume that these classical objects - especially your brain, but you don't have to go up to your brain - won't ever evolve into unnatural superpositions of macroscopically distinct states.
Is that true? Is that a sign of a problem of the Copenhagen interpretation?
It is surely true. It's how the world works. However, one may also say that this was a point in which the Copenhagen interpretation was incomplete. They didn't quite understand decoherence - or at least, Bohr who probably "morally" understood what was going on failed in his attempts to comprehensibly and quantitatively describe what he "knew".
However, once we understand decoherence, we should view it as an explicit proof of this fifth principle of the Copenhagen interpretation. Decoherence shows that the states of macroscopic (or otherwise classical-like) objects whose probabilities are well-defined are exactly those that we could identify with the "classical states" - they're eigenstates of the density matrix. The corresponding eigenvalues - diagonal entries of the density matrix in the right basis - are the predicted probabilities.
Because the calculus of decoherence wasn't fully developed in the 1920s, the Copenhagen school couldn't have exactly identified the point at which the classical logic becomes applicable for large enough objects. However, they were saying that there is such a boundary at which the quantum subtleties may be forgotten for certain purposes and they were damn right. There is such a (fuzzy) boundary and we may calculate it with the decoherence calculus today. The loss of the information about the relative phase of the probability amplitudes between several basis vectors is the only new "thing" that occurs near the boundary.
Again, this point was the only principle of the Copenhagen interpretation that was arguably "incomplete" but their proposition was definitely right! To make this point complete, one didn't have to add anything new to quantum mechanics or distort it in any way. One only needs to make the right calculation of the evolution of the density matrix in a complicated setup. In that way, one proves that they always treated the measuring devices in the right way even though they couldn't fully formulate a fully quantum proof why it was the right way.
End of quote
Decoherence is needed in Copenhagen to fix up the issue it had with dividing the world into classical and quantum.
Copenhagen was basically correct, and in the great scheme of things it was minor, but it was a problem, and it needed fixing.
IMHO modern interpretations like Decoherent Histories and my Ignorance Ensemble Interpretation that incorporate it from the outset are better. But that's just a matter of elegance and personal taste - its got nothing to do with its validity.
Thanks
Bill
End of quote
IMHO modern interpretation like Decoherent Histories and my Ingnorance Ensemble Intepretation that incorporate it from the outset are better. But that just a matter of elegance and personal taste - its got nothing to do with its validity.
Thanks
Bill
The question is. Do 100% of physicists agree with Lubus? Or is it Lubus own thoughts or ideas?
If 100% of physicists agree with Lubus and Decoherence is totally true. Why not give Nobel Prize to Zurek, Zeh, Joos? 3 people can get Nobel for the same prize. In the Higgs. Only 2 or 3 get them inspite of having 8 people originally working on it. Likewise in decoherence, 2 or 3 can be nominated. Why hasn't this occurred? When this occurred, then I'd be convince Decoherence is fully accepted and not just some esoteric viewpoints of some physics elite. Maybe it's possible some just don't care about it that is why the Nobel committee is not persuaded with it?
You should have figured out by now in the area of interpretations agreement does not exist.
Unless someone conducted some kind of survey there is no way to answer that, except to say Copenhagen is a widely held interpretation and many physicists such as Susskind in his lectures presents this kind of view.
Chat to the Nobel prize committee about that. But maybe its because many physicists view interpretations as philosophical waffle, not fundamental discoveries that Nobel prizes are awarded for.
Bell was probably an exception - he would have almost certainly got one had he lived - and correctly so IMHO - but then again his theorem was confirmed by experiment.
Ether way I suspect, correctly IMHO, the mods will shut this thread down because its basically going nowhere, so this will be my last contribution to it.
Thanks
Bill
Thanks
Bill
Ok. My only request is if others have encountered physicists who still fully support Bohr that there is division between classical and quantum world and decoherence is not really accurate or even extra baggage. Please share it in another thread. I'd like to hear their views. Thanks.
1. What is the concept of decoherence and how does it relate to determinism?
Decoherence refers to the process by which a quantum system interacts with its environment, causing it to lose its quantum properties and behave in a classical, deterministic manner. This means that the outcome of a system can be predicted with certainty, rather than being determined by random chance.
2. How does randomness play a role in proper mixing of particles?
In quantum mechanics, particles can exist in a superposition of states, meaning they can be in multiple states simultaneously. Proper mixing occurs when these particles interact with their environment and lose their quantum properties, resulting in a mixture of particles with definite states. This process is inherently random and is known as the collapse of the wavefunction.
3. Can decoherence and determinism coexist in quantum systems?
Yes, decoherence and determinism can coexist in quantum systems. While the process of decoherence causes particles to behave in a deterministic manner, the superposition of states still exists at the quantum level. It is only when the system is observed or measured that the randomness of the collapse of the wavefunction comes into play.
4. What are some real-world applications of understanding decoherence and determinism?
Understanding decoherence and determinism is crucial in fields such as quantum computing, where the interference of quantum states can lead to errors. By controlling and minimizing decoherence, scientists can improve the reliability and accuracy of quantum computers. These concepts also have applications in quantum cryptography and quantum teleportation.
5. How do scientists study and measure the effects of decoherence?
Scientists use various techniques such as interferometry and quantum state tomography to study and measure the effects of decoherence. These methods involve manipulating and controlling the quantum states of particles and observing how they interact with their environment. By studying the effects of decoherence, scientists can gain a better understanding of the role of randomness in proper mixing and its implications in quantum systems.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
