What is the true nature of an object: beyond its properties?
  • Thread starter madness
  • Tags
    Properties
In summary: I'm not sure what you are asking. If you are asking if an object can exist without its properties, the answer is seemingly no. But again, what would this hypothetical object be like? I don't see how it could exist without properties. If you are asking if a set of properties is all that is necessary for an object to exist, then I would say no. There must be something more to it.In summary, an object or entity can be said to have certain properties, but it does not exist independently of these properties. These properties may manifest as a set of variables or behaviors, but there must be something more to an object's existence than these properties.
madness
815
70
An object or entity can be said to have certain properties, eg height, mass, position etc. But does the object exist independantly and beyond these properties, or is a set of properties all that can be said to exist? If we try to imagine what an object is actually like without the distortions it goes through from object to observer (our senses and consciousness may show a very different picture from the reality) all we are left with is a set of properties. Colours are simply different wavelengths of light being absorbed and reflected, and even things such as shape may be an invention of our consciousness to help us to understand our surroundings (a square will always have four equal sides and angles but what we see when we look at a square is invented). So is there more to an object's existence than a set of properties? If not, what is it that has these properties?
objects are substances actualizations or parts of spacetime
I cannot imagine that properties are materiel beings. But if they are not, how can it be possible that a set of properties is a material being?
So at least a material object has to be something more than a set of properties. That could be a substance, something that is identical with itself while its properties are changing. Or it could be an actualization as proposed by Rosenberg (see in the Rosenberg threads chapter 9) and perhaps also by Whitehead. (Then effective properties are possibilities/determinables that are constraint by an actualization to determinate values.) A third possibility is that an object is something that occupies some spacetime.
I didnt say that an object is a material being, what I mean is that what we consider to have material existence or substance may be reduced to a set of properties, or at least we have no empirical evidence that anything further than these properties exists. Where in existence do you see this "something that is identical with itself while its properties are changing"? I see no evidence for this in nature, in fact I would argue that everything in existence is in a constant state of flux or change. Unfortunately I don't know of Rosenberg or Whitehead's views so I can't comment. I see occupying spacetime as a property rather than evidence of material existence.
In my opinion you are pointing to, among other things, a major gap in physical theory. As far as I can tell, there is no "bottom line" where you find something that just is or uncaused which might serve as the foundation of existence. Instead, the closest anyone gets to a bottom line substance-wise is a set of variables (properties) which are most likely to manifest, or a description which does things, but has no existential qualities itself.
This paradox may be most exhibited in the mass-energy dynamic. Mass offers what is most sustantial about the universe, yet if we convert mass to it's more basic form you get energy. Is energy a substance? No. Energy is a way to measure the changes that occur when mass is converted to energy.
So in the end, what we get for the foundation of creation is a set of behaviors and properties and variables, but no enduring substance which will hold up things no matter what sort of changes go on.
Just to address this first question, is it even coherent to speak of an object independent of its properties? What would an object with no properties be like? It would seem analagous to a word with no definition, no sense or reference; in other words, a word that isn't a word at all. Even if we just called this base substance "ineffable" or "insensible," are not these properties nonetheless? Isn't the quality of being a substance itself a property in the first place?
I think this is sometimes known in philosophy as the 'problem of attributes'. It seems to show that our day to day concept of 'objects' is incoherent and that there is no such thing as an object. If so then physicalist theories of matter and cosmogeny are naive and we need to develop a more sophisticated theory of matter and cosmogeny. Perhaps something like Buddhism or Taoism, in which objects are explained as being empty of substance. Cosmologists now speculate that the universe may have been created from as little as an ounce of matter, and this isn't so far from none at all.
Yes otherwise we have nonexistence again. If there is a base substance it must have properties, and all the observed properties of "forms" of this base substance would be expressed potentials of base substance properties.
Do you have empirical evidence that properties exist? I do not have more evidence for the existence of objects as I have for the existence of properties.
I think "object" is a primitive concept and accept loseyourname's argument
The question is how to characterize this object. Object can be understood either as a substance or as an event.
In each case there will be properties that determine or constitute the object character of the object. I propose that non-relational i.e. intrinsic properties constitute the objects.
I find this discussion a bit trivial but maybe I'm missing something.
If that were the case, then you could conceive of an object that has no properties, by thinking of an object and subtracting one property at a time until you're left with... with what?
Any object must have properties, and any properties must belong to some object.
The object! It comes to existence together with its properties.
This is very much like the question of what is left of an onion once you peel off all the layers, and the answer is clearly "the onion is the layers".
What the problem of objects and properties tell us is that our understanding of the world is plagued by false distinctions. Another classic case is the chicken and egg problem: some people argue the chicken came first, others argue it was the egg, but to me the only real possibility is that they both appeared together, since the egg contains a chicken as much as a chicken contains an egg.
The last post seems contradictory to me. You say there is not more to an object's existence than a set of properties, then you say that there is an object which these properties belong to. Does this really make sense?
The onion is the layers, but the term onion is merely a word to describe all the layers of the onion put together in a certain way, so with the onion analagous to the object and the layers analagous to the properties, nothing which is separate or other than properties exist, and hence, there can be no object which these properties belong to.
As to the post before, I do think there is empirical evidence for the existence of properties. We define what we experience in terms of properties, blue things have the property of being blue, things that exist have the property that they exist etc., and we can see that all around us. My point is that when we really analyse things, the property of blueness is all that exists, the property does not adhere to any physical thing which cannot itself be reduced to a set of properties.
A property cannot exist on its own.
An object cannot exist without a property.
Property is intrinsic to objective existence.
Property is not a necessity or condition to existence. Property is a fact of existence. They are inseparable and intrinsic.
Thus if an object is said to have size, shape, mass, energy etc these attributes (properties) are intrinsic to the object in its present state. If the state of the object changes its properties change. If its properties change its state changes.
Question: Is the state of an object a property of that object?
(As a complete aside, my favorite value topic, color. If color is a property of and object is it not then intrinsic to that object? Sorry, I know it is off topic. I just couldn't help but make the connection as color was mentioned.)
I think Royce already addressed this, but I'll try to answer it from another perspective.
"Object" refers to the whole, "property" refers to independent aspects of the whole - parts. The whole cannot be said to exist in the absence of the parts that constitute it, but it's also correct to say that all parts belong to the whole, which is really just saying they are related to each other.
No, it isn't. The onion is the layers arranged in a particular combination known as... an onion.
You are almost there. "Onion" is merely a word, but so is "layers". Onion and layers, object and properties, they are just different ways of thinking about the same thing. Each way of thinking focus on different aspects of the "thing", but as I said, the distinction is artificial and only serves to help us think.
Not right. The layers "belong" to each other, and that relationship is called "onion".
Royce, I agree a property can't exist on its own, nothing can exist on its own. Properties exist in relation to other properties, which when grouped together we call an object. A pointlike fundamental particle, such as a quark, may have spin, charge, mass etc., but can we say a quark is more than a name given to this collection of properties? I would say not. An object cannot exist without a property because the properties are the object. I agree on the whole with what you are saying but I still deny the existence of anything more than properties in an object.
Johann, the onion is the layers arranged in a particular order, but this is where the metaphor fails, I don't see how properties can be arranged in different orders or combinations, they merely exist, Leibniz argued that if two objects have the exact same properties, they are in fact the same object. The properties may be contingent upon each other, but this does not mean they "belong" to each other. In fact I could argue that being contingent upon each other is a property in itself, in which case the properties have properties of their own, or more correctly, can be divided into more basic sets of properties (probably an infinite amount of times). This is just confusing though (I think that last bit might be wrong, I couldn't work it out when I tried to think it through).
It seems that when you really analyse the existence of something it breaks down into nothingness. Maybe the Buddha was right
Maybe he was. According to him all objects have no substance, but only phenomenal properties. At first glance this appears an incoherent assertion, for in this case how can anything exist? The answer is, according to the Buddha et al, that what is fundamental, what gives rise to objects and/or our notion of objects, is not itself an object. It is 'something' which has all properties and no properties, depending on how we conceive of it. Conceptually this is a contradiction, which is why we cannot conceive of it. From this follows the ubiquitous assertion of mystics that the Ultimate must be approached and known non-conceptually. In Buddhism this kind of deep analysis of the nature of objects and properties, starting with the sort of questions that Madness asked at the start here, is an intrinsic part of meditative practice.
Since everything is ultimately made of energy, whether strings or point particles such as quarks; and, energy has no substance and we don't know what it is or how it came to be then obviously the Buddha was right.
However objects exist regardless of what they are made of. Just as we don't know what energy is we don't know what objects are only there properties. Actually that is all that we know or can know about anything physical. That does not make the object its properties. Nor does it make properties an object.
Properties are values in the real and philosophical sense. Value has no substance; but, substance has value just another way of saying that properties have no objective existence but objective existences have properties.
A quark is a quark; but, all quarks are not the same. They have different properties that distinguish different types of quarks from other types of quarks; yet, quarks do not exist independently, only in pairs.
A quark is a quark; but, what is a quark; and, what is it that determines its properties?
Minced onion... cooked onion... onion rings...
Philosophers have a strange way of making obvious trivialities sound like great insights. What you said above reads to me as "if two objects are the same object, then they are in fact the same object". :zzz:
Of course Leibniz's statement sounds like great insight precisely because it's based on a false distinction between "properties" and "object".
I used "belong" in a very loose sense. You really have to understand what I mean by a false distinction to see my point.
That is because analysis is something you should do to language, not to reality. Ultimately your problem is simply one of understanding the meaning of the words "property" and "object".
Well, at least his ideas seem very popular around here.
Johann, I said that is where the metaphor fails, you can arrange the layers of an onion any way you want, but an onion isn't really a property, properties cannot be arranged in different ways because they don't physically exist or occupy space, I was simply using Leibniz's quote to show this in a different way. I see no reason why reality should not be analysed.
madness said:
I said that is where the metaphor fails...
Metaphors are vague by nature. They are not meant to explain anything, but to inspire a particular thought that can't easily be communicated.
An onion is not meant as a metaphor for a property, it's meant as a metaphor for an object. I didn't choose onions arbitrarily; the metaphorical meaning of onions is quite well-known amongst English speakers. Even the Beatles wrote a song based on it.
Ironically, you also concluded that objects don't exist, so what really does exist? That alone should make a bell ring.
The problem of false distinctions is not an easy one to solve, because the solution often has very little to do with the problem itself. You think you have a question that can't be answered, or that can only be answered in a strange way, and it does seem that way from your perspective. However, there is another perspective from which the question is nonsense. I'm not trying to answer your question, just trying to show it is nonsense, but that requires you to contemplate a different perspective.
Consider a similar problem: if people in China (or whatever country is across the globe from you) are upside-down compared to us, how come they don't fall off the earth? That's a silly problem, but one seriously entertained by young children. The point is, until you understand what makes things fall, you can't understand why the problem is silly.
Back to objects and properties. What is it that you have to understand to make the distinction between objects and properties look silly? It's a difficult thing to explain, which is why I chose a metaphor, but it's not a difficult thing to understand once you "get it". There is no mystery whatsoever.
Perhaps I could offer you the argument that even objects that do not exist also have properties. Not only that, but "existence" itself is just another property. For instance, unicorns are white, have four legs, tails, and of course a single horn on top of their heads. Now at least in this case you can be absolutely sure that there's no underlying, "real" object behind the properties that define a unicorn. All you have to do now is realize that, in that respect, there's no difference between unicorns and, say, horses, except the the latter has one extra property the former lacks ("existence")
That is your major misconception and the reason you end up confused. Analysis is something you do to ideas, not to things that are not ideas. You can analyze "reality" only to the extent that reality is an idea, but you can't get past that. If you try, you will inevitably reach the erroneous conclusion that reality doesn't exist.
Firstly, I meant to say layer, not onion. Secondly, I didn't say properties don't exist, I said they don't physically exist. The difference between a horse and a unicorn is that a horse occupies space and time. You have still given no satisfactory reason why reality should not be analysed. I have not reached the conclusion that reality doesn't exist, I have reached the conclusion that objects don't exist as more than a set of properties, and I see no reason to accept this as erroneous.
It looks to me like you are asking whather or not matter can be distinquish from it s properties( something that appears to the sense-perceptions).
If we consider the universe as a closed system of matter-energy, then it properties can only be observe by an external observer that is not in the universe. How do you find such an observer, i don t know. we cannot be consider an observer, because we are part of the universe.
That is not exactly what I meant because I don't see properties as strictly sense related. The property of having a certain mass or occupying a certain volume of space for example, are not sense perceptions.
However I completely agree with your point that we cannot objectively observe a universe which we ourselves are a part of. Perhaps that is why we can never fully understand our universe, and why problems such as the questions I have asked arise.
Isn't it a logical consequence then that objects don't physically exist?
Of course not. It's perfectly obvious that objects don't physically exist :rolleyes: .
If they existed, unicorns would occupy space and time as much as horses. Your analysis is bogus. The difference between a horse and a unicorn is that one exists and the other does not.
I didn't say it should not be analyzed, I said analysis is done to concepts and not to reality itself. That is why scientists have to do experiments; more often than not, correct analysis of concept yields false conclusions about reality.
Well, it was not I who said this:
"It seems that when you really analyse the existence of something it breaks down into nothingness"
Of course if you believe nothing exists, then reality is nothing and it still "exists", whatever the heck that is supposed to mean other than a silly play with words.
There are plenty of philosophical viewpoints that don't accept the existence of physical objects. My analysis is not bogus, the only difference between a horse and a unicorn is that one occupies space and time and the other doesn't, if you take this to mean that one exists and the other doesn't then that's your choice.
When alalysing the concepts based on reality, you are in effect analysing reality, so long as the concepts pertain to reality. This analysis will only yield false results if the physical theories being analysed do not pertain to reality, in which case you aren't analysing reality anyway
Can 2 objects have the same property? and if they did then they would have to take up the same space and the same time (Which is perceveably impossible). If they totally shared the same property. So, every object has its own unique properties. You can't strip and object of its properities you strip it of its existence.
I find myself in a funny position. All the questions asked here on this thread seem to have an obvious (to me, anyway) 'answering' hypothesis. That y'all don't see this indicates the general background is of classical physics. Classical physics is no longer able to satisfactorily describe newly found 'reality'. The tools are insufficient. Physics must include consciousness, and QM is including consciousness and hence redefining reality for all other branches of science. Just read the Science Journals in 10-15 years.
The old world views go kicking and screaming. T'was not easy realizing that the Earth was not the center of the universe!
I'm not going to attempt to lay it all out here as I have done so many places before. But it will lead those with the unanswered questions in the right direction if y'all ask the questions about your dreams at night. Where do the (dream) tables (qualities) go when you awaken? What set everything into 'motion' and 'time' and 'existence' within that dream? What is the real difference (at a foundational level) between all things within that dream? Even physics tells us that it cannot determine any exact place where one 'thing' leaves off, and another 'thing' begins. Seperating one 'thing' from another 'thing' is a mental acceptence (lazy acquiescence) as a 'given' of the sensory and mental illusion that 'things exist' independent of mind and senses. The mysics, the metaphysicists, the 'enlightened' have told us for millennia of the 'oneness' of all, of the 'illusory nature'.
Your classic assumption that your senses and mind will or can lead you to some form of 'objective' reality is error. It will not. Objective Truth, whether it does or does not exist, cannot be sensorily determined. We can never know if there is anything actually in front of our noses. When your whole universe consists of mental constructs and concepts and memory held together by thought, all within your mind, you can never know if there ever actually is anything 'out there'. You can never even know if there IS an 'out there', 'out there'. There certainly needn't be! Time, space, matter, strings, bananas, leptons, dimensionality, myself, personality, EVERYTHING in your universe has it's 'existence' within mind only. Ever notice that there are no scientific 'proofs'? Nothing can be absolutely 'proven'. Under 'highest magnification' QM tells us, as do the sages and mystics, that Consciousness is the Ground of all Being. Not 'things'.
Consciousness touching on Chaos brings us our waking dream of 'reality'.
Becoming lucid during your night dream will certainly alter the parameters of your 'enjoyment' of that dream. Beastie chases you and you can now soar into the sky! Turn it into a frog? Many 'rules' no longer apply. Other 'rules' can be bent.
Now, the trick is to become lucid in your waking dream. Imagine the possibilities.
"There is serenity in Chaos,
Seek ye first the Eye of the Hurricane!"
The problem is that if define an object as the sum of its properties, then
there cannot be two objects with the same properties , and there cannot
be persisiting objects (because as soon as any of the properties of an
object changes, it becomes a different object).
You can bite the bullet (for instance, agreeing with Leibni.z that there must
be an infinite amount of fine detail separating one apparently indistinguishable
object to another). You can solve the problem by fiat, insisting that
there is a "substance" that solves all the problems. Or...
http://www.geocities.com/peterdjones/space_rel.html
Materiality is a property ?
But change, as opposed to difference, requires something enduring:
http://www.geocities.com/peterdjones/met_time.html
That wouldn't follow (ulness you think the set in question is the empty set).
Not only can two apparently 'seperate' 'objects' have the exact same 'qualities', one 'single' object can occupy two quantitatively different and distinct locations at the same time. From the micro to the macro, there has long been evidence, even empirically quantifiably and qualitatively in any well equipt lab. Superlocation.
So two apparently different objects can have the same properties as they are, on a deeper level of consciousness, just one 'item', in (apparently) two places at once.
  • #31
Got any hard evidence for this claim?
  • #32
Is this a trick question?
If you are really interested, perhaps you'll Google 'bilocation' for some 'introductory information. On the 'micro-level', in the lab, you'll find the 'hardest' (what I think that you mean by 'hard'. Some people mean 'hard' to indicate 'hard' for them to 'accept', as a challenge...') evidence there. But you will find a whole netful of other 'types of evidence', such as anecdotal. I realize that 'anecdotal evidence' is rather 'anathema' to certain types of minds. That does not mean that there is not some validity somewhere. If you do an honest search, really read the relevant info. and try to understand, you'll have no problem, I guess...
In the end, we seem to still 'believe' what we must.
1. What is the difference between an object's properties and its true nature?
An object's properties refer to its observable characteristics, such as size, shape, color, and texture. These properties can be measured and described using scientific methods. On the other hand, an object's true nature refers to its underlying essence or fundamental qualities that make it what it is. This may include its composition, structure, and behavior at a molecular or atomic level.
2. Can an object's true nature be known or understood?
It is a subject of philosophical debate whether an object's true nature can be fully known or understood. Some argue that our understanding is limited by our perception and scientific tools, while others believe that there is an ultimate truth or reality that can be discovered through further scientific inquiry.
3. How does an object's true nature affect its properties?
An object's true nature determines its properties. For example, the arrangement of atoms and molecules in a substance will determine its physical and chemical properties. Changes in an object's true nature can also lead to changes in its properties, such as when a substance undergoes a chemical reaction.
4. Can an object's true nature change over time?
Yes, an object's true nature can change over time. This can happen through natural processes, such as erosion or decay, or through human intervention, such as manufacturing or genetic modification. These changes can also result in changes in the object's properties.
5. How do scientists study an object's true nature?
Scientists use a variety of methods and tools to study an object's true nature. These may include microscopic techniques, such as electron microscopy, to examine the structure of an object at a molecular level. They may also use spectroscopy to analyze the composition of an object and its chemical bonds. Additionally, scientists may conduct experiments and simulations to understand how an object's true nature influences its properties and behavior.
  • Other Physics Topics
9K
  • Beyond the Standard Models
  • Quantum Interpretations and Foundations
