Proton being accelerated
A proton (mass m = 1.67x10^-27 kg) is being accelerated along a straight line at 2.0x10^15 m/s^2 in a machine. The proton has an initial speed of 2.4x10^7 m/s and travels 2.5 cm.
(a) What is its speed?
(b) What is the increase in its kinetic energy?
3. The attempt at a solution
Is it ok to have no idea where to begin?
I know F=ma, and that V=Vo+1/2at... but I can't see how that helps.
Help me begin?
LowlyPion
3,055
I know F=ma, and that V=Vo+1/2at^2... but I can't see how that helps.
Help me begin?
You just need two equations.
Kinetic energy.
And an equation that relates Velocity, distance and acceleration.
https://www.physicsforums.com/showpost.php?p=905663&postcount=2
no lowly pion you are wrong what he needs is the other SUVAT equations namely.
S=0.5(u+v)t then rearrange to get V
(u is intitial velocity)
then you put that into the the kenetic energy equation
KE=0.5mv^2
then you have got your anser
LowlyPion
3,055
KE=0.5mv^2
And what is the time the proton is in the machine?
Kinetic energy.
So, using v^2 = v_0^2 + 2a(Delta x), I can find the final velocity I think. For the delta x part, would it be (2.5 - 0)?
And can I use KE= 1/2mv^2 to find the kinetic energy? If so, wouldn't I use the final velocity found in part a for "v"?
Thanks.
LowlyPion
3,055
Thanks.
Yes the V2 = Vi2 + 2ax should do you well.
Part b) is looking for ΔKE. So you are needing to calculate the final KE and subtract the initial.
Ahhhh so I do change in KE=m(v_f)^2 - m(v_i)^2 , right?
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
