B Proton "pressure"
Sanborn Chase
I recently read the proton has an outward force of 10e35 Pascals with an equal inward force containing it. Can this be true?
32,683
8,554
Where did you read this?
1035 Pa * (radius of proton)3 = 400 MeV or roughly half the proton rest energy. If you want to define a "pressure of a proton", whatever that might mean, it has to be in that range.
Sanborn Chase
I'm fairly certain it was Phys.org. From whence cometh this "opposing pressure" to the proton's outward force?
127
76
cmb
674
I'm an engineer I would not put myself forward as a particle physicist. However, it is the common currency of physics that pressure is the energy of any field per unit volume; J/m^3 (and as a J = N/m so it is the same as N/m^2).
Whenever there is a non-zero 'field' then the field will have an energy and you can define a 'pressure' for it. Whether that means the same thing to you as, for example, a pressure of a gas in (or on) a sealed bottle might not be the same conceptual idea, but whichever way you approach it, pressure is energy per unit volume.
There is an energy field that holds protons and neutrons together; the strong nuclear force. The gluon is the mediating particle of the strong nuclear force proton field.
Sanborn Chase
Thanks for your response. I am a dilettante. Gluons sound fine to me, but the descriptions of them I've read don't seem to jive with the use of the Pascal as unit measure. Using that term I'm getting approx. 240x10E25 total area outward force on a "point" four nanometers in diameter. To have that EXACTLY balanced as in the current model is a stretch for me. Isn't the strong nuclear force a description of the binding force holding the nucleus together? Does it apply equally to the components of the nucleus? Don't we need a mediating force?
32,683
8,554
Four nanometers is not a scale you'll see anywhere in connection with the strong interaction.
There is nothing that would need fine tuning to be balanced.
It is, and to a good approximation it acts the same on all quarks in a nucleus.
Mediating between what?
cmb
674
Four nanometers is not a scale you'll see anywhere in connection with the strong interaction. There is nothing that would need fine tuning to be balanced.It is, and to a good approximation it acts the same on all quarks in a nucleus.Mediating between what?
Well, I was going on the content of wikipedia [https://en.wikipedia.org/wiki/Strong_interaction] which says the force holding the quarks together is the strong nuclear force, which is mediated by gluons.
"The strong interaction is observable at two ranges and mediated by two force carriers. On a larger scale (about 1 to 3 fm), it is the force (carried by mesons) that binds protons and neutrons (nucleons) together to form the nucleus of an atom. On the smaller scale (less than about 0.8 fm, the radius of a nucleon), it is the force (carried by gluons) that holds quarks together to form protons, neutrons, and other hadron particles. "
Every quantum field has mediating particles as force carriers, does it not?
32,683
8,554
That is correct but I don't see the connection to your previous question about "a mediating force". The strong interaction is mediated by gluons. Gluons are not a force, they are force carriers (similar to the photon).
Every interaction ("force") has.
cmb
674
Sorry, typo, I meant mediating particle.
Want to reply to this thread?
"Proton "pressure"" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
