Prove (0,1)=[0,1]
  • Thread starter kathrynag
Yeah I read what you wrote above, but I'm unsure how to fix it.
f(1/n)=[tex]\frac{1}{n-1}[/tex]
y=[tex]\frac{1}{n-1}[/tex]
y(n-1)=1
yn-y=1
yn=1+y
y=1/n+y/n
y-y/n=1/n
y(1-1/n)=1/n
HallsofIvy
41,833
956
I have no idea what you are trying to do. You have repeatedly said that you are trying to prove "[0, 1]= (0, 1)" which can't be proved- it isn't true.
You have repeatedly said this problem has nothing to do with "cardinality" but are trying to find a "one-to-one, onto" function between the two sets which, if there is one, would prove cardinality not equality.
I think the problem is lazy notation here.
The OP doesn't mean [0,1] = (0,1) or else the simple counter-example 1 [tex]\in[/tex] [0,1] but 1 [tex]\notin[/tex] (0,1) proves it to be false; they likely mean [0,1] [tex]\approx[/tex] (0,1). (A is equivalent to B)
The proof for this is to prove their cardinality is the same. The proof of equivalence simply requires a one-to-one correspondence between (0,1) and [0,1]. (as has been said before, this is the proof for cardinality).
Ok, so does for the function f(1/n)={1.1/2,1/3,1/4,1/5....} imply onto becuase onto means f(A)=B where the A=(0,1) and the B=(0,1]?
  • #31
598
I got everything except for proving that [0,1) is equivalent to (0,1], proving that (0,1) is equivalent to [0,1].
I'm a little confused on these 2 steps.
  • #32
598
I still can't quite grasp this.
I sort of have an idea about this one.
If A=[0,1), B=(0,1] and C=[0,1], then A=C-x1contained in C and B=C-x2
contained in C
A and B are equivalent because they both are C-some x. Is this somewhat
right? Cause this seems to make sense to me.
  • #33
HallsofIvy
41,833
956
"Equal" has a specific meaning: A= B if and only if the symbols "A" and "B" represent exactly the same thing. "Equivalent" varies: A is equivalent to B using some given equivalence relation. What equivalence relation are you using?
The obvious one would be "have the same cardinality" but you have assured us that is not the case!
Also, originally you were look at (0,1) and [0,1] and now you have changed to [0, 1) and (0, 1]. Is this a new problem?
If you are trying to prove they are the same cardinality, , looking at 1/n, 1/(n+1), 1/(n+2), etc. will do no good because the numbers you necessarily form a countable set and none of (0,1), [0,1], [0,1), nor (0,1] are countable.
Look at my original response, #8.
  • #34
598
No same problem. These are the last 2 steps. Proving [0,1) is equivalent to (0,1] and then proving (0,1) is equivalent to [0,1]
  • #35
HallsofIvy
41,833
956
That's the hard way to do it! And, as I said before, what you are doing, looking at numbers of the form 1/n, is of no use because the integers are countable and none of these sets are countable.
As I said a long time ago, to define a one-to-one, onto function from [0,1] to (0,1)define f(x)= x for x any irrational number between 0 and 1, write all rational numbers in (0,1) in a list, r1, r2, etc. then define f(0)= r1, f(1)= r2, f(rn)= rn+2.
  • #36
598
The hard way to do it is the way I was told to do it with proving [0,1) is equivalent to (0,1].
  • #37
179
kathrynag already stated a bijection between (0, 1) and (0, 1] in the very first post of this thread. (It doesn't take too much effort from that to conclude there is a bijection between (0, 1) and [0, 1].) Her problem is showing that it is one-to-one and onto.
I suggest practicing showing that simpler functions are bijections, such as f : R -> R defined by f(x) = 5 - x^3, so that you understand the form of the proof.
  • #38
598
f(a)=5-a^3
f(b)-5-b^3
5-x^3=5-b^3
a^3=b^3
a=b
Thus 1-1
y=5-x^3
-y+5=x^3
x=(-y+5)^1/3
x includes all real numbers. Thus onto.
Then how do i work around proving [0,1) is equivalent to (0,1]?
Like I thought about using f(x)=1-x because f(0)=1 and f(1)=0 but then that would be a mpping and that's not quite right.
  • #39
598
Ok could I still use C=[0,1]
Then A=C-x element of C
B=C
but B=C-null set
null set is an element of C
so A=C- some elemnt of C=B?
  • #40
598
Ok I know [0,1) is equivalent to (0,1] by f(x)=1-x
Now I'm having trouble finding a similar function for (0,1) equivalent to [0,1]
  • #41
598
Ok, I found something else. 2 sets A and B are equivalent iff there is a 1-1 function from A onto B.
  • #42
Vid
401
After reading this topic, I am completely speechless.
  • #43
179
This would make a lot more sense to us if equivalent is replaced with cardinally equivalent.
f(a)=5-a^3
f(b)-5-b^3
5-x^3=5-b^3
a^3=b^3
a=b
Thus 1-1
y=5-x^3
-y+5=x^3
x=(-y+5)^1/3
That is right, so use this method to show that the function you stated in your first post is a bijection between (0, 1) and (0, 1]. The proof will be longer because that function is case-defined.
You already have f(x) = 1 - x, a bijection between [0, 1) and (0, 1], which is easier to show.
If you also have a bijection between [0, 1) and [0, 1], then that implies (0, 1) and [0, 1] are cardinally equivalent. If you want a single bijection between (0, 1) and [0, 1], think about how you can "combine" the 3 functions.
  • #44
598
Well, the book says nothing about cardinally equivalence, so i would assume my professor would not expect me to use that term.
Ok, so (0,1) and (0,1]
For f(x)=x, we get 0 and 1
For f(1/n)=1/(n-1), we get {1/1/2,1/1,1/4....}
Thus, (0,1]
[0, 1) and [0, 1]
For this I use {0}U(0,1) because I already know (0,1) is a bijection to (0,1]. Thus we have a bijection to [0,1].
Ok, for (0,1) equivalent to [0,1].
Let f(x)=x for all elemnt not of the form 1/n
Then we get the points (0,1)
Thne for all other points let f(x)={0}U 1/(n-1)
  • #45
179
Thus, (0,1]
You don't get 1 from f(x) = x.
Also, what about all other points not in {0, 1, 1/2, 1/3, 1/4, ...}?
[0, 1) and [0, 1]
Right idea, but you need to say it precisely because [tex]\{0\} \cup (0, 1) \ne (0, 1][/tex]. Do you mean given a bijection [tex]f : (0, 1) \rightarrow (0, 1][/tex], define [tex]g : [0, 1) \rightarrow [0, 1][/tex] by g(0) = 0, and g(x) = f(x) for [tex]x \in (0, 1)[/tex]?
This is not an element of [tex]\mathbb{R}[/tex].
  • #46
598
Yeah, but from f(x)=x I get all points not of the form 1/n.
All other points not in {0,1,1/2,1/3,1/4....} are in f(x)=x
Yeah, i guess setting g(0)=0 and g(x)=f(x) would work.
So then let f:(0,1)-->(0,1] and let g:(0,1)-->[0,1]
Let f(x)=g(x) for all x in (0,1) and let g(1)=0?
  • #47
179
Close. 0 is not in the range of f. I mentioned 0 only because you mentioned 0.
g(1) cannot be defined because the domain of g is (0, 1).
  • #48
598
Ok, 0 is not even in f.
Is this part correct? I know there needs to be some number to equal 0 right?
Let g(x)=f(x)=?
  • #49
HallsofIvy
41,833
956
If If f:(0,1)-->(0,1] then there is NO "x" left over to give f(x)= 0. That's the whole point.
  • #50
598
Ok I understand that.
Related Threads on Prove (0,1)=[0,1]
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
16K
