Prove a subset
judahs_lion
56
Show that W ={(x,y,z) : x +2y +3z =0} is a subspace of R3. By finding a subset S of W such that span(S) = W.
Ab = X?
I don't have an attempt because i'm completely lost where to start . Can someone point me in the right way please.
Answers and Replies
radou
3,120
Start with the definition of a subspace. Obviously every element of W is in R^3, so W is a subset (set!) of R^3. Now, what is the easiest subspace "test"?
judahs_lion
56
So prove that is its
Independent
Closed Under Addition
Closed Under Scalar Multiplication?
How to I find S?
Fredrik
Staff Emeritus
420
The equation defines a plane, so you need to find two linearly independent vectors in that plane.
judahs_lion
56
Is this system correct?
(x, y, z) = y(-2,1,0) +z(-3,0,1)
So S would be <(-2,1,0),(-3,0,1)>
Fredrik
Staff Emeritus
420
Yes, that appears to be correct. But I don't like the <,> notation. Does your book or teacher write the span that way?
8,173
Those vectors work. I would write it as S = {<-2, 1, 0>, <-3, 0, 1>}. This set of vectors spans W. Now what you need to do is to show that W is a subspace of R3.
Something you said earlier in this thread deserves comment:
Independent
The first one you listed is not a test for showing that a set is a subspace of some vector space. The vectors in a basis have to linearly independent, and have to span some subspace.
What is the test you missed?
judahs_lion
56
Contains the zero vector?
judahs_lion
56
How do I test for the zero vector?
8,173
Does W contain the zero vector? It's a very easy test.
judahs_lion
56
I was think of testing S for zero vector.
So for (x, y, x) =(0,0,0)
0 + 2(0) +3(0) = 0 Checks out.
Proper test? So for being so needy, math is a weak point of mine.
8,173
Sure, that's another way to do it.
Your set W represents a plane in three-dimensional space. This plane contains the origin, which you can tell by noticing that (0, 0, 0) is a solution of the equation x + 2y + 3z = 0.
Set S contains two vectors that lie in the plane. It doesn't contain the zero vector. You want to test set W to see whether it (W) contains the zero vector.
Since there are two vectors, and neither is a multiple of the other, they are linearly independent. Since the plane is two dimensional, and you have two linearly independent vectors, the two vectors span the plane, which means that every vector in the plane is a linear combination of the vectors you found. Instead of noticing that (0, 0, 0) is a point on this plane, you instead found that 0*<-2, 1, 0> + 0*<-3, 0, 1> = <0, 0, 0>, which says that the zero vector is in W (or equivalently, that (0,0,0) is on the plane).
judahs_lion
56
Thank you
judahs_lion
56
the matrix of { 1+x^2, x +x^3} = [1,0;0,1;1,0;0,1] ?
Fredrik
Staff Emeritus
420
If a set is closed under linear combinations, it automatically contains the zero vector. So checking if it contains 0 is only useful in some cases when you're trying to prove that a set isn't a subspace.
Suggested for: Prove a subset
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
