Prove ABC^TA^-1=CB
Main Question or Discussion Point
Hi all,
I have a suspicion this may be obvious but have lookd and can't seem to obtain the correct answer,
Can somone please explain the steps required to prove
ABC^TA^-1=CB
where C^T is the transpose of C and A^-1 the inverse of A. Matrices B and A are covariance matrices and thus may be considered symmetric if that helps
Thanks in advance for some direction
Answers and Replies
10,446
I don't think your requirements are sufficient. Consider A=1, B=[1,2;2,1], C=[0,0;1,0], for example. BC^T = [0,1;0,2], but CB = [0,0;1,2].
Thanks for the reply, on a second look I now have:
AB^TC^-1BA=AB^TC^-1CAB^TC^-1
Which I can break down to:
AB^TC^-1BA=AB^TAB^TC^-1
is there anyway I can re-order the RHS to equal the left?
Thanks in advance
10,446
Assuming A and B are invertible, this can be simplified to
C^-1BA=AB^TC^-1
As both A and B are symmetric, B^T=B and AB=BA (you can check this with the definition of matrix multiplication). Define D=AB and E=C^(-1). D is symmetric as well.
Therefore, your equation is equivalent to ED=DE for symmetric D and invertible E. But this is wrong, for example for D=[1,2;2,1] and E=[1,1;0,1].
Or, with the original matrices:
A=1, B=[1,2;2,1], C=[1,-1;0,1] violates the equation.
Thanks for the quick response, Apologies however A and C are symmetric B is not does this chaneg anything
I am attempting to work through a derivation and the step attached requires the above mentioned to hold, any suggestions appreciated
14.63 to 14.64, should be an easy substitution but I can't get there
no one ??
Related Threads on Prove ABC^TA^-1=CB
  • Last Post
9K
