Prove Bernoulli's inequality
In summary: I'll take that at face value and show my preferred approach for the general case (a lot nicer than wikipedia in my view):for real ##p \geq 1## and ##h \in(-1,\infty)## we have ##1 +ph \leq (1 +h)^p## the right side is always positive so we only need to put effort into proving the case where the left hand side is positive. in which case we can take pth roots and seek...
r0bHadz
194
Prove bernullis inequality: If h>-1 then (1+h)^n ≥ 1+ nh
How can I prove something that is false for h =1 n<1 ?
##n## is a natural number. So even if you consider ##n=0## to be a natural number, then it is the only one smaller than one. But ##(1+h)^0=1 \geq 1+0 \cdot h## is true. Prove it for ##n=1,2,3,\ldots##
Likes r0bHadz
(1+h)^n ≥ h^n +1
because (1+h)^n will be at least h^n + xh^(n-1)+...+1
I believe h^n + 1 ≥ nh+1
all I would have to do is show x^y ≥ xy and the proof would be done. Do you think my method is sound?
r0bHadz said:
(1+h)^n ≥ h^n +1
I think you are saying that
$$(1+h)^n = 1 + nh +\frac{1}{2} n(n-1) h^2 + \frac{1}{3!} n(n-1)(n-2) h^3 + \cdots + h^n \geq 1 + nh$$ Certainly, this argument is obviously true when ##h \geq 0## (because we just drop a number of non-negative terms to get to ##1+nh##). However, the reasoning breaks down when ##-1 < h < 0##.
The final result is still true in that case, but it needs a different type of argument.
Likes Delta2 and fresh_42
The usual proof of this inequality is by induction on n. The proof by induction works even if ##h>-1\Rightarrow h+1>0##.(while your proof at post #3 works only if ##h>2## (to be more precise your method works for some p ##1<p<2## such that ##h>p##.)
This was the first proof by induction that I was taught , I remembered my high school years now.
Likes SammyS
Delta2 said:
The usual proof of this inequality is by induction on n. The proof by induction works even if ##h>-1\Rightarrow h+1>0##.(while your proof at post #3 works only if ##h>1##.)
Right: induction is great at an elementary level. A different (calculus-based) method shows the result to be true if ##h >-1## and ##n \geq 1## is real. However, I guess this would not be appropriate in a "pre-calculus" forum.
Likes Delta2
if we constrain ##n\geq 1## to be rational, then the result follows from basic ##\text{GM}\leq \text{AM}## (proven by one of many elementary means). However to consider irrational values, some kind of analytic tools end up being needed, naturally.
edit:
for avoidance of doubt ##\text{GM}\leq \text{AM}## in its full power with real weights gives the proof here over real ##n\geq 1##. The issue is that you need to use analytic tools (limits or better: convexity of exponential function) to prove this more general form of ##\text{GM}\leq \text{AM}## which I think is beyond the scope for OP right now.
I am interested in your calculus based method that proves it for ##n## real (and ##h>-1##). Can you give any hint?
Likes r0bHadz
I think the logarithm plus power series could work, but there has to be a more elegant solution with the mean value theorem or so.
Likes r0bHadz
After I looked at Wikipedia's entry for Bernoulli's inequality, I think a way to prove it is to consider the function ##f(h)=(1+h)^n-1-hn## and prove that this function is increasing using derivatives, that is prove that ##f'(h)\geq 0##. Then the result will follow from ##h>-1\Rightarrow f(h)\geq f(-1)=n-1\geq 0##
EDIT: Turns out that this ##f(h)## is increasing for ##h>0## and is decreasing for ##-1<h<0## but because ##f(0)=0## the method still works.
Likes r0bHadz and fresh_42
Sorry forgot to press "solved" guys. Doing this with induction on n took me 1 minute. I don't know why the author didn't specify that n is a natural number but I guess its assumed. I'll look into other ways of doing this problem as I advance inshaAllah
Likes SammyS
in which case we can take pth roots and seek to prove the equivalent ##(1 +ph)^\frac{1}{p} \leq 1 +h##.
So we have
##(1 +ph)^\frac{1}{p}##
## = (1 +ph)^\frac{1}{p}\cdot 1##
## = (1 +ph)^\frac{1}{p}\cdot 1^\frac{p-1}{p}##
## \leq \frac{1}{p} (1 +ph) + \frac{p-1}{p}(1)##
## = 1 +h##
by ##\text{GM} \leq \text{AM}##
(you just need analytic tools to prove the strong form of this geometric vs arithmetic mean inequality)
Likes Delta2
## = 1 +h##
This proof has been brought to you by Hölder & Young.
(Sorry, I just need a mnemonic to remember this better and Hölder & Young sounded so funny in this context.)
it is true that I used ##p## in a nod to Hölder's Inequality and these are Hölder conjugates in the exponents. That said, one doesn't actually need to know Hölder's Inequality (or Young) to get this -- I think Cauchy would have gotten it by just playing around with ##\text{GM} \leq \text{AM}##.
So we have
## = 1 +h##
My personal preference would be to note that for any real ##n > 1## the function ##f(h) = (1+h)^n## is strictly convex on the set ##(-1,\infty)##, so ##f(h) > f(0) + f'(0) h ## for any ##h \neq 0, h > -1.## This requires a little bit of fairly elementary material on convexity; in this case we need to know that for a convex function ##f(h),## the tangent line to the graph of ## y = f(h)## lies on or below the graph at all legitimate ##h \neq 0##, and lies strictly below if ##f## is strictly convex.
1. What is Bernoulli's inequality?
Bernoulli's inequality is a mathematical inequality that states that for any real number x greater than or equal to -1 and any positive integer n, (1+x)^n ≥ 1+nx.
2. Who discovered Bernoulli's inequality?
Bernoulli's inequality was discovered by Swiss mathematician Jacob Bernoulli in the late 17th century.
3. What is the significance of Bernoulli's inequality?
Bernoulli's inequality is an important tool in mathematical analysis and is used in many areas of mathematics, including calculus, number theory, and statistics. It also has applications in physics and engineering.
4. How is Bernoulli's inequality proved?
Bernoulli's inequality can be proved using mathematical induction. The base case (n=1) is trivial, and then the inductive step involves showing that if the inequality holds for some integer k, then it also holds for k+1. This completes the proof by induction.
5. What are some real-life examples of Bernoulli's inequality?
Bernoulli's inequality can be applied to compound interest calculations, where the interest rate is greater than 0. It can also be used to prove the AM-GM inequality, which is used in statistics to find the arithmetic mean of a set of numbers. Additionally, Bernoulli's inequality is used in the proof of the binomial theorem, which has applications in probability and combinatorics.
