Prove Existence of Real Number
  • Thread starter knowLittle
  • Tags
    Existence
In summary, a real number is a value that represents a quantity on a continuous number line and can be positive, negative, or zero. The existence of real numbers can be proven using methods such as Dedekind cut or Cauchy sequence, which show that there are no gaps in the number line. Rational numbers can be expressed as a fraction of two integers, while irrational numbers cannot. All real numbers are also complex numbers, which are written in the form a + bi. The existence of real numbers is crucial in mathematics as they allow accurate representation and manipulation of quantities in the real world, and are used in various mathematical concepts such as calculus, geometry, and statistics.
knowLittle
312
a.) Prove ## \exists x, x \in \mathbb{R} | x^3 -x^2 = 5##
I know that x = 2.1163, but how do I find this without a calculator?
b.) Prove that ## \not \exists x, x \in \mathbb{R} | x^4 - 2x^2 +2 =0##
x^2 ( x-1 )=5 for part a)? =====================
b.)
I find it easier. If x =0, then it's false.
## x^2 ( x^2 -2 )+2 = 0 \\ x^2 \geq 0 \\ x =1 \vee -1 \\ 1(-1) +2 =1 \neq 0 ##
Then since x is only greater than 1, it is false that x exists that satisfies the equation.
What do you think?
You're not asked to find its value, only to prove such a number exists.
b.)
What do you think?
Have you typed the question correctly? Should it say [itex]\nexists[/itex]?
I cannot even begin to follow your reasoning. Why must x be 1 or -1?
Try applying the usual formula for solving quadratics.
I said 1 or -1 because I was trying the base case after 0, but yeah let me try the quadratic formula.
Can I do this to the quadratic equation? :
## x^4 - 2x^2 +2 = 0 \\ (x^2)^2 - 2(x^2) +2 =0 \\ ##
And, I solve for ## x^2 = -1 +- \sqrt{-1}##
So is there a real x satisfying that? If not, why not?
## \not\exists x | x \in \mathbb{R}, ## since ## x = \sqrt{x^2} = \sqrt{ -1 +- \sqrt{-1} }, x \in \mathbb{C}##
##x \in \mathbb{C}## does not prove it is not in ##\mathbb{R}##.
Work backwards. Suppose x is real. What does that tell you about x2?
Likes 1 person
Try using the intermediate value theorem.
Try completing the square with ##x^2## as the variable.
Likes 1 person
Thanks, Kurtz!
## (x^2 - 1)^2 = -1 ##, since the square of any number is always non-negative, it is impossible that x is real.
b.)
What do you think?
What tools are you allowed to use? Calculus makes these easy.
In (a), let ##f(x) = x^3-x^2##. We have ##f(0) = 0 < 5## but ##f(x) \to \infty## for ##x \to \infty##, so ##f(x_0) > 5## for some large-enough ##x_0##. By continuity there is an ##x \in(0,x_0)## giving ##f(x) = 5##.
For (b), look at ##f(x) = x^4 - 2 x^2 = x^2(x^2-2)##. This a quadratic in ##y = x^2##, whose minimum is at ##y = 1##, giving ##f_{\min} = f(1) = -1>-2##. Therefore, it is impossible to find any ##x## giving ##f(x) = -2##.
Likes 1 person
Are you familiar with Descartes' Rule of Signs? It gives a very quick solution here.
Treat that as a quadratic equation in ##x^2## and consider the discriminant.
What is the definition of a real number?
A real number is a value that represents a quantity along a continuous number line. It can be positive, negative, or zero.
How can we prove the existence of real numbers?
The existence of real numbers can be proven using the Dedekind cut or Cauchy sequence methods. These methods involve showing that there is no gap or break in the number line, and that every point can be identified with a unique real number.
What is the difference between rational and irrational numbers?
Rational numbers are those that can be expressed as a fraction of two integers, while irrational numbers cannot be expressed in this form. Examples of irrational numbers include pi and the square root of 2.
Are all real numbers also complex numbers?
Yes, all real numbers are also complex numbers. A complex number is a number that can be written in the form a + bi, where a and b are real numbers and i is the imaginary unit (√-1).
Why is the existence of real numbers important in mathematics?
The existence of real numbers is crucial in mathematics as it allows us to accurately represent and manipulate various quantities in the real world. Real numbers are used in a wide range of mathematical concepts, including calculus, geometry, and statistics.
  • Precalculus Mathematics Homework Help
