Prove hyperbolic function
  • Thread starter DryRun
DryRun
http://s1.ipicture.ru/uploads/20111203/B1Ax1OcU.jpg
Frankly, i've been sitting starring at that problem for long enough, and it just can't be solved through the direct use of the standard hyperbolic identities. I need a hint.
Answers and Replies
3,297
Use induction.
DryRun
That's a long shot... I just started this topic so i'm very new to it and i have no idea what induction means either. Can you elaborate a little?
Curious3141
2,850
87
Really? Have you tried expressing cosh x and sinh x in terms of e^x and e^(-x)?
No need for induction. This is a simple direct proof. And induction only covers non-negative integral n, whereas you can more easily prove the general result for all complex n directly.
3,297
See our proofs FAQ: https://www.physicsforums.com/showthread.php?t=523874 [Broken] for a discussion on induction.
To make it simpler, try and set n=2. Can you prove it for n=2?
Dick
26,263
619
No, no induction needed. Just put in the definition of cosh and sinh in terms of exponentials.
dextercioby
Insights Author
13,138
689
Indeed, induction seems the most elegant proof.
DryRun
Alright, what is induction??
3,297
Read the link I posted above. Or check your textbook.
Curious3141
2,850
87
Have you tried the direct method? Start by expressing sinh and cosh as exponentials, then it's just algebra!
DryRun
First, i've expressed the L.H.S into two parts:
(coshx + sinhx)^n and (coshx - sinhx)^n
For the first one:
(coshx + sinhx)^n = e^(nx)
For the second one:
(coshx - sinhx)^n = e^(-nx)
I am aware that i somehow need to bring that power n down, but can't see how.
3,297
Now do the same with the RHS
DryRun
For the R.H.S. i split it into 2 parts:
(cosh nx + sinh nx) and (cosh nx - sinh nx)
(cosh nx + sinh nx) = [e^(nx) + e^(-nx)]/2 + [e^(nx) - e^(-nx)]/2 = [e^(nx)]/2
(cosh nx - sinh nx) = [e^(nx) + e^(-nx)]/2 - [e^(nx) - e^(-nx)]/2 = [e^(-nx)]/2
OK, i see it now. They are both the same. It did not occur to me that i had to tinker with the R.H.S also, as normally, i should have been able to get the R.H.S. using only the L.H.S.
Related Threads on Prove hyperbolic function
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
