Prove integral of complex exp
  • Thread starter freezer
freezer
76
Prove that the integral of a complex exponential over an integer number of periods is zero.
[itex] \int_{0}^{T_{0}}e^{j (2\pi /T_{0}) kt} dt = 0 , k = integer[/itex]
I am never sure how to work a proof. In this case, i can see that it would be true but not sure how you go about "proving" it. That the area from 0 to 1/2 T0 would zero out the area from 1/2 T0 to T0. Can someone point me to a good example on how to work this type of proof? or help me through this one?
[itex]\frac{1}{e^{j(2\pi /T_{0})k}}e^{j(2\pi /T_{0})kt} \mid ^{0}_{T_{0}}[/itex]
Answers and Replies
13,012
I would start with substitution to get rid of the variable T0, and consider the case k=1 first.
You can split the integral in two parts and show that they are equal apart from their sign.
freezer
76
So would you just say consider T0 = 1, but i would worry that would be like saying that since 2+2 = 4 and 2*2 = 4 therefor addition and multiplication are the same...
freezer
76
[itex]\frac{e^{j(2\pi /T_{0})kT_{0}}}{j(2\pi/T_{0})k}- \frac{e^0}{j(2\pi/T_{0})k}[/itex]
[itex]e^j\theta = cos\theta +j sin\theta [/itex]
[itex]\frac{cos(2\pi k)+j sin(2\pi k)}{j(2\pi /T_{0})k} - \frac{1}{j(2\pi /T_{0})k}[/itex]
[itex]cos(2\pi k) = 1[/itex]
[itex]j sin(2\pi k) = 0[/itex]
[itex] \frac{1}{j(2\pi /T_{0})k} - \frac{1}{j(2\pi /T_{0})k} = 0[/itex]
Is this sufficient?
Dick
26,263
619
Is this sufficient?
Yes, that's exactly what you want. Though it is true that ##e^{j 2 \pi k}=1## for k an integer, right? Probably no need to go through the sines and cosines.
13,012
Hmm right, my idea was more complicated than necessary. You can simply compute the integral.
No, it is like saying T0/T0=1 for all real T0 (apart from 0). A sound mathematical proof that T0 does not influence the result.
Suggested for: Prove integral of complex exp
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
