Homework Help: Prove m + m/1
  1. May 20, 2007 #1
    disregardthat
    Prove that if m is a positive rational number, then:
    m + 1/m = integer
    Only when m = 1
    2. Relevant equations
    Don't know any
    3. The attempt at a solution
    That's the problem, I don't know where to start. I have tryed a few things, but none of them works out for me.
    I don't know much of proofs and such, the problem I have is always where shall I start? Do you have any tips?
    EDIT: The topics name is not correct, the correct question is in the topic
  3. May 20, 2007 #2
    radou
    If m is a positive rational number, then m = p/q, for some natural numbers p and q. Hence, you have p/q + q/p = integer => p/q & q/p are integers. Now, what does that mean?
  4. May 20, 2007 #3
    D H
    Staff Emeritus
    Just because the sum of two numbers is an integer does not mean the two numbers themselves are integers. This final step needs further justification.
  5. May 20, 2007 #4
    disregardthat
    I was at that stage:
    a/b + b/a = integer
    But I couldn't state that this only works when m=1
    Is it ok to say: a and b is integers, if a is more that 1, we would have a decimal number in b/a and an integer in a/b, if b is more than one, we would have a decimal number in a/b and an integer in b/a.
    Since m must be positive, and that we can't divide by 0, m must be 1 to get an integer.
  6. May 20, 2007 #5
    D H
    Staff Emeritus
    How would you express a/b+b/a as a fraction? What are the conditions that this fraction be an integer?
    Edited to add:
    Now put this back in the context of the original problem, which is to prove m+1/m is an integer only if m is 1.
  7. May 20, 2007 #6
    radou
    a/b + b/a is not an integer if a doesn't divide b or if b doesn't divide a (or both). So, for a/b + b/a to be an integer, a must divide b, and b must divide a.
  8. May 20, 2007 #7
    D H
    Staff Emeritus
    radou, you just gave out the answer. Not a good idea in the homework section ...
  9. May 20, 2007 #8
    radou
    Hm, I'd let Jarle decide about that.
  10. May 20, 2007 #9
    Dick
    This is all true, except that the sum of two nonintegers can be a integer. So it's not so clear and I don't think the answer is given away yet. You'll want to clear the fractions in a/b+b/a=1 and assume a and b are relatively prime.
  11. May 21, 2007 #10
    disregardthat
    I don't know how to prove it, I tryed, but I can't
  12. May 21, 2007 #11
    Dick
    I'm not sure what you mean by 'shortened'. I would write it as a^2+b^2=a*b. Is this relation possible if a and b have no common divisors?
  13. May 21, 2007 #12
    HallsofIvy
    I'm a bit unclear as to whether the problem is to show that m+ 1/m is an integer or (m+1)/m is an integer only if m= 1.
    If it is the first case, I don't think you need to worry about "divisors". Since the difference of two integers is an integer, if m+ 1/m= n, an integer, then 1/m= n- m is an integer. What does that tell you?
  14. May 21, 2007 #13
    D H
    Staff Emeritus
    Halls, it looks like you assumed that m is an integer. It is a rational.
  15. May 21, 2007 #14
    Dick
    You can assume a and b have no common divisors, right? Otherwise you could just simplify the fraction. This mean one of a or b has a prime divisor that does not divide the other. Suppose p divides a but not b. How many of the terms in a^2+b^2=a*b are divisible by p? How many are not? Is there anything wrong here?
  16. May 21, 2007 #15
    D H
    Staff Emeritus
    Dick, you arrived at [itex]a/b+b/a=1[/itex] in post #9 and then used that in posts #11 and #14. However, you do not know [itex]a/b+b/a=1[/itex]. The given condition is that [itex]a/b+b/a=n[/itex], where [itex]a, b, n \in \mathbb N[/itex]. So the problem becomes one of showing that [itex]a^2+b^2=nab[/itex] only has solution if [itex]a=b=1[/itex].
  17. May 21, 2007 #16
    Dick
    Ooooops. Sorry! Same argument, though.
  18. May 21, 2007 #17
    That should read "only has solution if [itex]a=b[/itex]"
  19. May 21, 2007 #18
    radou
    Nah, it should read "only has solution in the set of integers".
    Boy, what a thread. :tongue2:
  20. May 21, 2007 #19
    a and b may both be integers and yet not be a solution. a = b is crucial. a and b were chosen from the set of integers.
  21. May 21, 2007 #20
    radou
    I was referring to n, but nevermind.
Loading...
