Homework Help: Prove Pascals formula
  1. May 30, 2007 #1
    Prove "Pascals formula"
    Show that (k)+(k+1)+......+(n) = (n+1) it's supposed to be combinations
    (k) (k ) (k) (k+1)
    That's the question in my math book. I guess you need to use Pascals triangle and Pascals formula but unfortionately I dont know how to implement them here.
  3. May 30, 2007 #2
    please define what are these notations
    what is the meaning of (k) ???
  4. May 30, 2007 #3
    AKG
    lalbatros, he means show that:
    [tex]{{k}\choose{k}} + {{k+1}\choose{k}} + \dots + {{n}\choose{k}} = {{n+1}\choose{k+1}}[/tex]
    The second line of (k)'s and the (k+1) is supposed to line up underneath the stuff on the previous line. I'm about to hit the space bar 10 times. I just hit it 10 times, I see a big gap between "times." and "I just" but when I post this message, you'll only see one space.
    Elruso, use Pascal's triangle on the right side of your equation together with induction.
  5. May 30, 2007 #4
    Well, n=1,2,3,4.......... and k=1,2,3,4...............
  6. May 30, 2007 #5
    AKG
    I don't know what your point is. Do induction on n. The base case is the trivial fact that [itex]{{k}\choose{k}} = {{k+1}\choose{k+1}}[/itex].
  7. May 30, 2007 #6
    VietDao29
    Are you sure the problem is copied correctly? I think I should have read:
    [tex]\left( \begin{array}{c} k \\ k \end{array} \right) + \left( \begin{array}{c} k + 1 \\ k \end{array} \right) + \left( \begin{array}{c} k + 2 \\ k \end{array} \right) + ... + \left( \begin{array}{c} k + n \\ k \end{array} \right) = \left( \begin{array}{c} k + n + 1 \\ k + 1 \end{array} \right)[/tex]
    As AKG's pointed out, you need a Proof By Induction. Proof By Induction requires 3 steps, i.e:
    Step 1: Start with n = 0, or 1, or 2, or whatever according to what the problem asks you to do (in this case, you should choose n = 0), to see if it's correct.
    Step 2: Assume the statement is true for k = n.
    Step 3: prove that if it holds true for k = n, then it would also hold true for k = n + 1.
    Can you go from her? :)
