Prove that n(n^4 - 1) = 10Q
  1. Dec 5, 2016 #1
    • Thread moved from the technical forums, so no Homework Help Template is shown.
    For some values Q and n being integers, prove that n(n^4 - 1) = 10Q.
    So I've tried this with induction, but it gets pretty messy pretty quickly. So I can see that the LHS will be even no matter what, but I'm not sure where to go beyond this.
  3. Dec 5, 2016 #2
    Is induction compulsory for this question ?
    You essential need to prove that ##n(n^4 - 1)## is divisible by 10. Can you show the induction step ?
  4. Dec 5, 2016 #3
    Ray Vickson
    Your problem statements does not make much sense as written. Do you mean the following?
    "For all integers n >= 1, show that the integer n(n^4-1) is divisible by 10 (that is, has zero remainder when divided by 10".
  5. Dec 5, 2016 #4
    mfb
    2017 Award
    Staff: Mentor
    I would consider a few cases instead of induction.
  6. Dec 5, 2016 #5
    PeroK
    Factorising ##n^4-1## might not be a bad idea.
  7. Dec 5, 2016 #6
    How do I factorize it?
  8. Dec 5, 2016 #7
    Induction isn't compulsory, but it's for all n belonging to the natural numbers.
  9. Dec 5, 2016 #8
    $$x^n - y^n = (x-y)\left(\sum^{n-1}_{k =0} x^{n-1-k}y^k\right)$$
  10. Dec 5, 2016 #9
    mfb
    2017 Award
    Staff: Mentor
    Also known as "find (x-y) as factor and proceed from there". And it is not the last possible factorization step.
  11. Dec 5, 2016 #10
    PeroK
    If you let ##x = n^2## then ##n^4-1=x^2-1## and hopefully you know how to factorise that.
  12. Dec 5, 2016 #11
    ##n^4-1=(n^2-1)(n^2 + 1)##
  13. Dec 5, 2016 #12
    Mark44
    Staff: Mentor
    No. ##n^4 - 1 = (n^2 - 1)(n^2 + 1)##
  14. Dec 5, 2016 #13
    mfb
    2017 Award
    Staff: Mentor
    PeroK's version was a correct substitution. You did the factorization step but with the wrong variable.
  15. Dec 5, 2016 #14
    Did not see the substitution.:bow:
    Can you please delete my last post.
  16. Dec 5, 2016 #15
    Hmmm, so now I have ##n(n+1)(n-1)(n^2+1))## So it's pretty clear that anything here will be divisible by 3... Also I can see that whether the parity of n is either even or odd, the entire term will come out to even. So the term must be divisible by 6, but I'm not seeing how to get that number up to 10...
    Thanks to everyone so far, didn't even see the conjugate there.
  17. Dec 5, 2016 #16
    PeroK
    Why not just crunch through that modulo 10?
  18. Dec 5, 2016 #17
    I'm not sure what that means.
  19. Dec 5, 2016 #18
    PeroK
    Every number is equal to 0-9 modulo 10. Just check each of these possibilities. For example ##7^2+1=50## so ##n^2+1## is a multiple of 10 for every number that equals 7 modulo 10.
  20. Dec 5, 2016 #19
    OK, it took me a minute to figure out the modular arithmetic, but I do understand what you're saying.
    So pretty much by stating that all numbers are 0-9 mod 10, then checking each case, we can effectively run through all the natural numbers.
    For real, that helps a lot. Thanks.
  21. Dec 5, 2016 #20
    mfb
    2017 Award
    Staff: Mentor
    You already know that the expression is even, checking 0 to 4 to prove divisibility by 5 is sufficient.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Prove that n(n^4 - 1) = 10Q
Loading...
