Prove that the Given Equation is an (Trig) Identity
In summary, to prove that sin2A / (1-cos2A) = tanA is an identity, one can use the half angle formulas for sine and cosine and manipulate the right hand side to arrive at tanA. Additionally, it is important to square both sides of the equation in order to ensure that it holds true for all values of A.
TbbZz
37
Prove that the Given Equation is an Identity:
Code:
sin2A
------       =       cotA
1 - cos2A
sin(A+B) = sinAcosB + cosAsinB
cos(A+B) = cosAcosB - sinAsinB
tan(A+B) = (tanA + tanB) / (1 - tanAtanB)
sin2A = 2sinAcosA
cos2A = cos[tex]^{}2[/tex]A - sin[tex]^{}2[/tex]A
tan2A = 2tanA / 1 - tan[tex]^{}2[/tex]A
I tried changing sin2A to sin(A+A) and arrived at 2sinAcosA at the top.
I also tried changing 1 - cos2A to 1 - cos[tex]^{}2[/tex]A - sin[tex]^{}2[/tex]A, but then I arrived at having a 0 in the denominator.
I'm really not sure where to start in trying to prove the identity. I understand that I should not touch the cotA on the right hand side, but no matter what I do to rewrite the left side I can't seem to arrive at the cotA.
I would appreciate it if someone could point me in the right direction. Thank you in advance for the assistance.
Okay so you know the identity cos2A=(cosA)^2-(sinA)^2, as you've written above.
Remember (sinA)^2+(cosA)^2=1 ?
Try substituting (cosA)^2 from the second equation into the first, then rearrange to find the denominator. Use sin2A=2sinAcosA for the numerator, and you should be okay! Hope this helps; i'll give more help if needed
Thanks for the help Rudipoo, your assistance is appreciated. I successfully solved this problem and another one.
However, I am having difficulty on the problem after that. It is similar, but I can't seem to figure it out. I'm attaching a picture of my work so far.
I'm not sure what to do next or whether I'm heading in the right direction in the first place.
Again, thanks in advance for the help.
Do you know that [tex] tan(x/2)= \sqrt{\frac{1- cos(x)}{1+ cos(x)}}[/tex]
(If not, you can prove it by writing tan(x/2)= sin(x/2)/cos(x/2) and using the half angle formulas for sine and cosine.)
Once you have [tex]\sqrt{\frac{1- cos(x)}{1+ cos(x)}}[/tex]
multiply both numerator and denominator of that fraction by 1- cos(x).
Remember, you're trying to PROVE that tan(x/2) = sinx/(1+cosx), so don't start the proof by writing this!
I would suggest by writing down the right hand side (i.e. sinx/(1+cosx)) because this looks intuitively like it can be simplified, and then manipulate this to find it equal to tan(x/2)
My method was to use half angle formulae on sinx and cosx - these are same as double angle formula, but swap x for x/2. For sinx, you have only one option as before, and use this in the numerator. For cosx, because you're looking for a tan function, use an identity such that it includes just cosine terms, so you end up with a sine over a cosine.
Hope this helps, and if you need more clues, give me a message.
In fact, I don't really think that this is an identity. Since the LHS can take negative value (say, when x = -2), whereas the RHS is always non-negative.
It should be an identity once you square both sides. :)
Thanks for the help HallsofIvy, Rudipoo, and VietDao29. I was able to solve the problem correctly using your advice.
What does it mean to prove an equation is a trig identity?
Proving an equation is a trig identity means showing that it is true for all values of the variables involved, regardless of their specific values. This is done by using trigonometric properties and algebraic manipulation.
What are some common trig identities used in proofs?
Some common trig identities used in proofs include the Pythagorean identities, double-angle identities, half-angle identities, and sum and difference identities.
What steps are involved in proving an equation is a trig identity?
The first step is to simplify both sides of the equation using known trig identities. Then, use algebraic manipulation to transform one side of the equation into the other. Finally, check that the equation holds true for all values of the variables involved.
Why is it important to prove an equation is a trig identity?
Proving an equation is a trig identity helps to verify the validity of the equation and shows that it holds true for all possible values of the variables involved. This is important in mathematics and science, where accurate and reliable equations are necessary for making predictions and solving problems.
What are some tips for successfully proving a trig identity?
Some tips for proving a trig identity include starting with the more complex side of the equation, using multiple identities and algebraic manipulation, and being organized and systematic in your approach. It is also helpful to have a good understanding of basic trigonometric principles and properties.
  • Precalculus Mathematics Homework Help
