Prove that v dot a= uu'
jumboopizza
the question is simply asking to prove that if speed is constant than velocity and acceleration vectors are perpendicular to each other. it also says as hint to differentiate v dot v= u^2.....
V=velocity A=acceleration u=speed t=time
i suppose knowing the vector dot product properties would be useful to have around,so heres some:
V dot V= [v]^2(magnitude)
derivative of vector dot products:
d(a dot b)/du= da/du dot b+ a.db/du
acceleration is= the derivative of Velocity with respect to time
ok so ive used the hint and tried to differentiate V dot V= u^2 and i get
dv/dt dot V+V dot dv/dt= du/dt u^2= 0 since speed is constant
2V dot dv/dt=0
now im not sure if this is representinvg acceleration or not the 2v dv/dt or if its the rate of change in speed or whatever, if its acceleration then wouldnt it be 2A=0, but now it doesnt make sense since acceleration cant be 0 so i know theres a mistake somewhere...
my other idea was to use V dot V=[V]^2 which is one of the dot product properties
and then the magnitude of the velocity would be the speed wouldnt it?
dv/dt [V]^2=0
anyways im lost,so can someone please help?
Answers and Replies
gabbagabbahey
2V dot dv/dt=0
dv/dt [V]^2=0
acceleration (a vector!) is the time derivative (rate of change) of the velocity vector, so [itex]\mathbf{v} \cdot \frac{d \mathbf{v} }{ dt } = \mathbf{v} \cdot \mathbf{a} = 0[/itex]
Under what conditions will two vectors have a dot product of zero?
jumboopizza
ok thats what i thought dv/dt= A but its not necessarily 0, if they( vector V and Vecotor A) are perpendicular to eachoter the dot product would be zero...
ok so V dot A=0
so when i first derived V dot V= u^2 and got to dv/dt V+V dv/dt= u^2 du/dt=0
du/dt is the rate of change of speed correct? so if the first derivative of u is =0
would't u'= equal zero?
V dot A= uu' -------------> V dot A= u(0)?
jumboopizza
or is it better to make V dot V= [V]^2
sqrt [V]^2= sqrt u^2 ---------> [v]= u
d[v]/dt [v]= du/dt u = 0 --------> d[v]/dt = [a] magnitude of the acceleration
gabbagabbahey
It is better to use [itex]v^2= |\mathbf{v}|^2[/itex] than [itex]u^2[/itex], since [itex]\mathbf{v}\cdot\mathbf{v} = |\mathbf{v}|^2[/itex] follows from the definition of dot product, and by definition, the speed is the magnitude of the velocity.
Suggested for: Prove that v dot a= uu'
  • Last Post
  • Last Post
  • Last Post
