Homework Help: Prove that {x∈ℤ : 2|x} ∩ {x∈ℤ : 9|x} ⊂ {x∈ℤ : 6|x}
  1. Jan 31, 2016 #1
    Prove that {x∈ℤ : 2|x} ∩ {x∈ℤ : 9|x} ⊂ {x∈ℤ : 6|x}.
    It means that the intersection of the two sets is subset of the set containing integers that are divisible by 6.
    3. The attempt at a solution
    Basically I need to show that if an integer is divisible by 2 and 9, then it's also divisible by 6.
    Proof:
    let. x=2*9*n=18*n=(6*3*n)∈{x∈ℤ : 6|x} (n∈ℤ)
    Q.E.D.
    However, I don't think it's that simple.
  3. Jan 31, 2016 #2
    Samy_A
    You think wrong: it is correct. :oldsmile:
  4. Jan 31, 2016 #3
    Ok, thanks :oldsmile:
  5. Jan 31, 2016 #4
    Dick
    Actually, it's correct but needs some justification. Suppose I said x is divisible by 2 and 6. You would be wrong to say that x=2*6*n and conclude that's it's divisible by 12. You need to say something about prime numbers.
  6. Feb 1, 2016 #5
    Let's summarize the proof.
    I have already shown that if x is even, then the statement is true.
    If x is a prime, additive inverse of a prime or ±1, then {x∈ℤ : 2|x} ∩ {x∈ℤ : 9|x} = the empty set. And the empty set is a subset of every set. In addition, all primes are odd.
    Therefore {x∈ℤ : 2|x} ∩ {x∈ℤ : 9|x} ⊂ {x∈ℤ : 6|x} holds for all x∈ℤ.
  7. Feb 1, 2016 #6
    Samy_A
    I'm a little lost here. The statement "If x is a prime, additive inverse of a prime or ±1, then {x∈ℤ : 2|x} ∩ {x∈ℤ : 9|x} = the empty set" is meaningless, or overuses the symbol "x".
    What Dick meant was (I think) that you should explain more in detail why you can write x=2*9*n in your original proof. He gave as an example that this would not work for 2 and 6.
  8. Feb 1, 2016 #7
    Dick
    Right, that's what I meant. x being prime isn't an issue, it's something about 2 and 3 being prime.
  9. Feb 1, 2016 #8
    Is it about prime factors? 2*3*3*n? How should I modify the original proof?
  10. Feb 1, 2016 #9
    Samy_A
    Not by much, as both Dick and myself said it is correct.
    What you haven't explicitly explained is the following:
    Take x ∈{y∈ℤ : 2|y} ∩ {y∈ℤ : 9|y}.
    That says that x=2*a and x=9*b, where a and b are integers.
    How do you conclude from this that x=2*9*n (n an integer)? We saw that for the pair 2,6 that doesn't work.
  11. Feb 1, 2016 #10
    Isn't that obvious? I still dont get it.
    x=2*a and x=9*b
    So a=9 and b=2, because x is an integer.
  12. Feb 1, 2016 #11
    Samy_A
    It is rather obvious, but the point was that you didn't state why.
    Let's assume I don't get it: I don't see why x=2*a and x=9*b implies x=2*9*n (a, b, n integers). How would you explain it to me?
    This is not correct.
  13. Feb 1, 2016 #12
    If x is divisible by 2 and 9, then x must be product of at least 2 and 9.
  14. Feb 1, 2016 #13
    Samy_A
    Why?
    Just start from x=2*a=3*b (a,b integers).
    EDIT: sorry, that whas a typo, as above it should have ben x=2*a=3*3*b
  15. Feb 1, 2016 #14
    x=2*a=3*b
    a=3b/2
  16. Feb 1, 2016 #15
    Samy_A
    Let's try this: we have as before x=2*a=9*b.
    Do you think that b can be an odd integer? And why?
  17. Feb 1, 2016 #16
    Dick
    The basic theorem you want to apply here is called "unique prime factorization". Samy A suggests an alternative trick way to do it. But I think you should work with the theorem. Unless you don't know it, in which case the trick is good.
  18. Feb 2, 2016 #17
    Samy_A
    I agree, and I assume he knows the theorem. But it looks as if he sees the theorem as so obvious that he doesn't actually states it.
  19. Feb 2, 2016 #18
    let x=2*3*3*n=6*3n?
Have something to add?
Draft saved Draft deleted
