Prove the Limit
Use the definition of limits to show that
[tex]lim _{x\rightarrow 2} \frac{1}{x^{2}} = \frac{1}{4}[/tex]
2. Relevant equations
[tex]\forall \epsilon > 0, \exists \delta > 0, x \in D, 0 < |x-2| < \delta \Rightarrow |\frac{1}{x^{2}} - \frac{1}{4}| < \epsilon [/tex]
3. The attempt at a solution
[tex]|\frac{1}{x^{2}} - \frac{1}{4}| < \epsilon \Rightarrow |\frac{4-x^{2}}{4x^{2}}| < \epsilon \Rightarrow \frac{|4-x^{2}|}{4x^{2}} < \epsilon [/tex]
[tex]Restrict: 1 < x < 3 \Rightarrow 4<4x^{2}<36 \Rightarrow \frac{1}{36} < \frac{1}{4x^{2}} < \frac{1}{4} \Rightarrow \frac{|4-x^{2}|}{36} < \frac{|4-x^{2}|}{4x^{2}} < \frac{|4-x^{2}|}{4} < \epsilon[/tex]
And now I'm stuck. I'm trying to find delta based on epsilon. Normally the problems come to a neat little solution, but |4-x2| is not |x-2| and trying to get it to equal |x-2| is where I'm having the trouble.
Any help is appreciated.
gabbagabbahey
[itex]|4-x^2|=|x^2-4|=|(x-2)(x+2)|=[/itex]____?
Yeah I got that far. I know that
[tex]|(x-2)||(x+2)| < 4\epsilon[/tex]
But that still leaves that (x+2) there (which I can remove the absolute value from since it has to be positive). I can't have delta dependent on x.
I'm probably missing something blatant and obvious right here.
gabbagabbahey
Well, you've restricted your domain to between 1 and 3, so..... __?__[itex]\leq|x+2|\leq[/itex]__?__ .....then simply choose epsilon to be greater than the upper bound of [tex]\frac{|x-2||x+2|}{4}[/tex]
ah, duh, thanks. 3 < |x+2| < 5 (since x+2 is positive with or without the absolute value)
So then
[tex]\frac{|x-2||x+2|}{4} \leq \frac{5*|x-2|}{4} < \epsilon [/tex]
Thus [tex]|x-2| < \frac{4}{5}\epsilon[/tex]
Thus if [tex]\delta = \frac{4}{5}\epsilon \Rightarrow |f(x) - \frac{1}{4}| < \epsilon[/tex]
Thanks so much.
lurflurf
2,417
120
1<x<3
implies
3<x+2<5
Want to reply to this thread?
"Prove the Limit" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Top Threads
