Prove V= (C*1) directsum W
  • Thread starter xitoa
xitoa
Let V=Cn and 1 be all ones vector 1 = e1 + ... +en. Let W be the subspace of V spanned by those vectors of the form [tex]\lambda[/tex]e1 + [tex]\lambda[/tex]e2 + ... + [tex]\lambda[/tex]en such that [tex]\lambda[/tex]1 + ... + [tex]\lambda[/tex]n= 0 [tex]\in[/tex] C. Prove that there is a direct sum decomposition
V=(C*1) [tex]\oplus[/tex] W
as complex vector spaces.
How should I approach this problem?
Answers and Replies
micromass
Staff Emeritus
Insights Author
22,129
3,302
What did you already try?
xitoa
Okay, so I have a few questions:
1) i think i could say that W is linearly dependent? since [tex]\lambda[/tex]1 + [tex]\lambda[/tex]2 + ... + [tex]\lambda[/tex]n = 0 [tex]\in[/tex] C
2) I'm not quite sure about what it means that 1=e1 + ... + en
Does it mean that each en is something like <1,0,0...,0>, <0,1,0,...,0>, etc?
3) Also, im still foggy on how direct sums work...say: two subspaces U and W exist in V(that are out of the context of this problem).
U and V are a direct sum if (is it iff?)
1. U[tex]\wedge[/tex]W = {0} (zero vector)
2. U+W=V
So, if they satisfy those two conditions, its a direct sum?
4) To help prove that V is a direct sum, could I say that Cn is the zero vector?
ystael
352
Some of the things you say suggest that you're confused about really basic things.
One doesn't say that a subspace is "linearly dependent". A list of vectors (finite list, when doing finite-dimensional linear algebra, which you are) is "linearly independent" or "linearly dependent". In any case, the fact that the equation defining [tex]W[/tex] is "the sum of the coordinates is zero" has nothing to do with any kind of linear dependence property; a list of vectors is linearly dependent when there is a linear combination of vectors in the list that comes out to the zero vector.
In any case this has nothing to do with your problem.
[According to the definitions, every nontrivial subspace of a vector space is a "linearly dependent set" of vectors; that's why this isn't useful and we don't say it.]
[tex]\mathbf{\mathrm{e}}_j[/tex] is conventionally defined to be the vector with a 1 in the [tex]j[/tex]th place and 0 elsewhere. This equation is meant to tell you what [tex]\mathbf{1}[/tex] is (that it's the vector with 1 in every coordinate), not what the [tex]\mathbf{\mathrm{e}}_j[/tex] are.
U and Ware a direct sum if (is it iff?)
1. U[tex]\cap[/tex]W = {0} (zero vector)
2. U+W=V
Yes, this is a correct definition for "[tex]V[/tex] is the (internal) direct sum of [tex]U[/tex] and [tex]W[/tex]."
This makes no sense whatsoever. [tex]\mathbb{C}^n[/tex] is the vector space in which all of this problem takes place. It is an [tex]n[/tex]-dimensional complex vector space and there is no way in which you can "say that it is the zero vector".
You need to prove two things, taken from the definition you quote in your third point:
(a) that [tex]\mathbb{C}\mathbf{1} \cap W = \{0\}[/tex], and
(b) that [tex]\mathbb{C}\mathbf{1} + W = \mathbb{C}^n[/tex]. This second point means to prove that every vector of [tex]\mathbb{C}^n[/tex] can be expressed as the sum of a vector in [tex]\mathbb{C}\mathbf{1}[/tex] and a vector in [tex]W[/tex].
xitoa
Thanks for replying, I think i meant to ask if [tex]\mathbb{C}^n[/tex] contains the zero vector. ie the 0 vector is an element of [tex]\mathbb{C}\mathbf{1}[/tex] ?
ystael
352
Yes, [tex]\mathbb{C}^n[/tex] contains the zero vector (as every vector space must), and yes, [tex]\mathbb{C}\mathbf{1}[/tex] contains the zero vector, because [tex]\mathbf{0} = 0\mathbf{1}[/tex]. However, your use of "i.e." indicates an implication which does not hold: the (true) fact that [tex]\mathbf{0} \in \mathbb{C}^n[/tex] does not directly imply (or indeed have anything to do with) the (true) fact that [tex]\mathbf{0} \in \mathbb{C}\mathbf{1}[/tex].
xitoa
So, in my proof, I should state [tex]\mathbb{C}\mathbf{1}[/tex] contains the zero vector because [tex]\mathbf{0} = 0\mathbf{1}[/tex], so that V is a direct sum of C1 and W?
ystael
352
That's only the smallest part of the proof: to prove that [tex]\mathbb{C}\mathbf{1} \cap W = \{\mathbf{0}\}[/tex], it is not enough to prove that [tex]\mathbf{0} \in \mathbb{C}\mathbf{1}[/tex] and [tex]\mathbf{0} \in W[/tex]! And then you still need to show that [tex]\mathbb{C}\mathbf{1} + W = \mathbb{C}^n[/tex].
xitoa
W and C1 are both subspaces of V (which is [tex]\mathbb{C}^n[/tex])
So doesn't that mean that[tex]\mathbb{C}\mathbf{1} + W = \mathbb{C}^n[/tex] is true?
sheepover
I'm also working on this problem. To me it seems like the only way V=(C*1) [tex]\oplus[/tex] W can be true is if all coordinates in W=0. I'm not sure how to show this, or why it is even true. Can anyone please help?
ystael
352
I'll answer your questions as best I can, but you are misunderstanding some really basic ideas, and I think you would be better served by in-person tutoring.
To prove that two sets [tex]A, B[/tex] are equal, you prove that they have the same elements, or equivalently that each is contained in the other: "[tex]A = B[/tex]" is equivalent to "[tex]A \subset B[/tex] and [tex]A \supset B[/tex]" and also to "[tex]x\in A[/tex] if and only if [tex]x\in B[/tex]".
Here you are trying to prove that [tex]\mathbb{C}\mathbf{1} + W = \mathbb{C}^n[/tex]. You are correct to observe that [tex]\mathbb{C}\mathbf{1}[/tex] and [tex]W[/tex] are both subspaces of [tex]\mathbb{C}^n[/tex]. Since [tex]\mathbb{C}\mathbf{1} + W[/tex] is the set [tex]\{v + w \mid v \in \mathbb{C}\mathbf{1}, w \in W\}[/tex] and [tex]\mathbb{C}^n[/tex] is closed under addition (being a vector space), this proves that [tex]\mathbb{C}\mathbf{1} + W \subset \mathbb{C}^n[/tex].
You still need to prove the other direction, that [tex]\mathbb{C}\mathbf{1} + W \supset \mathbb{C}^n[/tex]; in words, that every vector in [tex]\mathbb{C}^n[/tex] lies in [tex]\mathbb{C}\mathbf{1} + W[/tex], that is, every vector in [tex]\mathbb{C}^n[/tex] is the sum of a vector in [tex]\mathbb{C}\mathbf{1}[/tex] and a vector in [tex]W[/tex].
ystael
352
You can't show this because it is false. To see why it can't be true, think about the dimensions. What are the dimensions of [tex]V = \mathbb{C}^n[/tex] and [tex]\mathbb{C}\mathbf{1}[/tex]? How does the dimension of a direct sum relate to the dimensions of the summands? What does that tell you about the dimension of [tex]W[/tex]?
sheepover
C^n is a dimension of order n, so does that mean W must be a dimension of order n as well? I'm not exactly sure what this means.
This is what I was trying to do:
If we want to prove C*1 (intersect) W = {0}
pick (a1, ..., an) such that (a1,..., an) is an element of C*1 (intersect) W.
because (a1,..., an) is an element of W --> (a1+...+an) = 0 (which is an element of C)
Now, my teacher wrote something like this:
because (a1, ..., an) is an element of C*1, all coordinates are equal.
then, if a1 = ... = an, it follows that a1 = ... = an=0
therefore, C*1 (intersect) W = {0}
But I can't figure out how he got there.
sheepover
Also, I can't figure out a way to do this :frown: I'm really struggling with this problem.
Suggested for: Prove V= (C*1) directsum W
  • Last Post
  • Last Post
23K
  • Last Post
  • Last Post
