• Support PF! Buy your school textbooks, materials and every day products Here!
Prove -|x|</x</|x|
1. Homework Statement
Prove -|x|</x</|x|
2. Homework Equations
3. The Attempt at a Solution
We are trying to prove -|x|</x</|x| (less than or equal to)
This means that we need to show that x>/ -|x| and x</ |x|.
Let x be a real number.
Assume |x|=x if x>0 and -x if x<0
I'm not sure were to go from here, as I cannot use actual values to prove it. Could someone please show me what to do?
Thank you very much
Answers and Replies
1,341
Case 1:
[tex]-|x| \leq x[/tex]
[tex]-x \leq -x \leq x[/tex]
So it's obvious that case 1 holds..
Can you see where to go form there?
Thank you very much
Could you please explain to me how you got that? Would I do the same thing for |x|?
Thank you
1,341
It's just basic a absolute value identity, and yes you would^^
Thank you
After I do that, would that complete the proof?
|x|>x
x>x or -x>x
In order to prove that |x|</a if and only if -a</x</a where a>/0, would I do the same thing as in the previous problem?
Thank you
HallsofIvy
41,732
893
The simple way to do it is to use the definition: |x|= x if [itex]x\ge 0[/itex], -x is x< 0.
If x[itex]\ge[/itex] 0, then [itex]-|x|\le x\le |x|[/itex] becomes [itex]-x\le x\le x[/itex]. Isn't that obvious?
If x> 0, then [itex]-|x|\le x\le |x|[/itex] becomes [tex]x\le x\le -x[/itex]. Isn't that obvious?
Thank you very much
Thank you
1,631
Th
there is a typo here, it should read i guess x<0. I just wanted to point it out.
Thank you very much
Regards
Related Threads for: Prove -|x|</x</|x|
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
