Proving an Equation: Find Positive Integer x such that x^2=2x
  • Thread starter dumb_student
In summary: numbers between 0 - 6 : { 0,1,2,3,4,5,6}|{ 0,1,2,3,4,5,6}| = 7 so at least one odd would be 1/7? since we are picking 3 times does it mean the chance is:(1/7)(1/6)(1/5) = 1/(210)
dumb_student
Can some one show me how this is done?
Prove that there exists a positive integer x such that x^2=2x.
Just from the looks, I want to say this this is not possible, hence vacuous proof. I'm sure I'm wrong.
Try setting it up so you can factor it and find the possible values of x.
Thanks a bunch, I don't know why I did think of 2 :).
It's easy to see that x=2 is such an integer. Since 2 exists, it's proved.
Aww, you figured it out before I could type my answer. :(
Its all good :), I do have another one if you can help.
Use proof by contradictions to show that for any selection of 3 distinct integers between 0 and 6 that at least one of those numbers will be odd.
What?...
In between 0 and 6 means {1,2,3,4,5} otherwise the statement is false as {2,4,6} is a counter example.
The problem is not clearly stated due to the ambiguity of what "between 0 and 6" means. Does "between" here mean "strictly between", with the endpoints not included? Or does "between" here mean that the endpoints are included?
Robert1986 is assuming that the latter meaning is the one that was intended.
Easy (I think) ;)
If you divide the right side by 2 so it becomes x2/2 = x
Then you can put, for ex. 2
22/2 = 2
OR am I wrong? xD
Gliese123 said:
Easy (I think) ;)
22/2 = 2
OR am I wrong? xD
A little backwards...
Although the right answer has been mentioned above,
Assume x != 0
(I use != to mean does not equal)
then divide both sides by x!
x2 = 2x
Becomes
x2/x = 2x/x
Cancel the x's
and you get x = 2. This is a valid solution because x !=0.
What others have said is to subtract and factor
x2 = 2x
Subtract 2x from both sides
x2 - 2x = 2x - 2x
Simplify
x2 -2x = 0
Factor the x
x(x-2) = 0
Zero Product property tells us that either x = 0 or x - 2 = 0
So we have two solutions x = 0 and x = 2. Since 0 is not POSITIVE, our answer must be x = 2.
That's certainly a creative approach. Proof by contradiction, you should assume that there are no odd numbers between 0 and 6 and show that it leads to a logical contradiction like 2=6 or something.
This is NOT a probability problem. There is a "chance" of picking numbers is relevant only if we were picking numbers at random.
Even then, your calculations are wrong. The chance of picking any one number is 1/7, not "at least one odd". If you were to choose three numbers from {0, 1, 2, 3, 4, 5, 6}, without replacement, the probability they would all be even would be (4/7)(3/6)(2/5)= 4/35. Therefore the probability of "at least one odd" would be 1- 4/35= 31/35.
But again, probability has nothing to do with this. The problem was to show that, if pick three numbers from {1, 2, 3, 4, 5}, at least one must be odd. And that is obviously true because there are only two even numbers in that set.
1. How do I approach solving this equation?
To solve an equation of the form x^2=2x, you can use algebraic manipulation to get all terms with x on one side of the equation and constants on the other side. Then, you can factor out x and use the zero product property to find the values of x that make the equation true.
2. What are the possible values of x that satisfy this equation?
The equation x^2=2x has two solutions: x=0 and x=2. These are the only positive integer values that make the equation true.
3. Can I use a calculator to find the solution?
No, a calculator is not necessary to solve this equation. However, you can use a calculator to check your answer once you have solved the equation algebraically.
4. Are there any other methods for solving this equation?
Yes, you can also solve this equation by graphing both sides and finding the points of intersection. Additionally, you can solve it using the quadratic formula, although this may be more complex than necessary for this specific equation.
5. Can this equation be solved for non-integer values of x?
Yes, this equation can also be solved for non-integer values of x. In fact, there are an infinite number of real solutions to this equation, which can be found using methods such as calculus or numerical approximation.
