Homework Help: Proving a Linear System
  1. Apr 14, 2010 #1
    let ui , ci [tex]\in[/tex] Rn
    and
    A [tex]\in[/tex] Mn(R) be such that AciT = uiT , i=1,2,...,n
    Suppose u1,u2,....,un are linearly independent. Show that
    c1,c2,....,cn are linearly independent
    2. Relevant equations
    N/A
    3. The attempt at a solution
    i was just learning the eigenvalue, eigenvector, but i didn't have any clue how to relate to this or this really related to eigen?
    can someone help me
  3. Apr 14, 2010 #2
    Mark44
    Staff: Mentor
    I hope you don't mind, but I changed the names of your c vectors to v. c is almost always used for constants, while u, v, w, etc are used for vectors.
    Since u1, u2, ..., un are linearly independent, the equation c1u1 + c2u2 + ... + cnun = 0 has only one solution for the constants c1, c2, ... , cn. (What is that solution?)
    Now, what can you say about the equation c1Av1 + c2Av2 + ... + cnAvn = 0?
  4. Apr 14, 2010 #3
    one solution which ci= 0 , i = 1,2,....,n
    right? i'm still not sure how to state that because, i remembered there are only one solution, but how to state that it is "only one solution"
    this one, since
    AviT = uiT
    implies
    ui = viAT
    implies
    c1v1AT + c2v2AT + ... + cnvnAT = 0
    has only one solution ci = 0 , i=1,2,...,n
    implies
    v1AT , v2AT ,...., vnAT are linear independent
    am i right?? did i over complicating things?
    if i right,
    i only show v1AT , v2AT ,...., vnAT are independent
    how to show
    v1 , v2 ,...., vn are independent
  5. Apr 14, 2010 #4
    can i make like this?
    implies
    (c1v1 + c2v2 + ... + cnvn)AT = 0
    implies
    c1v1 + c2v2 + ... + cnvn = 0
    implies
    im sorry if i do over complicating things and annoy you much. T_T
  6. Apr 15, 2010 #5
    Mark44
    Staff: Mentor
    Right. Just say that this solution is the only solution because it is given that the vectors are linearly independent.
    I guess you took the transpose of each side. Not sure that this is worth doing. I would say that you can leave off the T's for transpose.
    Yes, a little, but you have the main idea. Instead of saying this:
    you can instead say this:
    All you have done is replace ui in the first equation with Avi in the second equation. Since the first equation has only one solution (the trivial solution c1=c2=...=cn=0), then so does the second equation.
  7. Apr 15, 2010 #6
    hoho, thankyou very much mark44, hmm now only bugging me is the other question .. Let me try my best.
    before that, can you tell whether A is invertible or not?
  8. Apr 15, 2010 #7
    Mark44
    Staff: Mentor
    A is invertible.
    If A were not invertible, then the dimension of the nullspace of A would have to be at least 1. That means that for at least one vector vi, Avi = 0.
    Since you are given that Avi = ui, and the u vectors are linearly independent, none of them can be zero, hence Avi [itex]\neq[/itex] 0 for i = 1, 2, ..., n.
    That's not the complete proof, but it should give you the idea.
