Proving Convergence with Cauchy Sequence Method
In summary, To show that a sequence is Cauchy, you must prove that |a_m - a_n| approaches 0 as m and n approach infinity independently. Using the given property, |a_{n+2} - a_n| can be expressed as the sum of |a_{n+2} - a_{n+1}| and |a_{n+1} - a_n|. This pattern continues for higher indices, allowing for the use of induction to show the general case. Therefore, (s_n) is a Cauchy sequence and converges.
JamesF
Hello all. I'm having trouble on the following homework problem. It seems like it should be easy, but I'm just now sure how to approach it
Let [tex](s_n)[/tex] be a sequence st [tex]|s_{n+1} - s_n | < 2^{-n}, \forall n \in \mathbb{N}[/tex]
show that [tex](s_n)[/tex] converges
well I thought the easiest way to prove it would be to show it's a Cauchy sequence and therefore convergent, but perhaps that's the wrong approach. What's a good starting point for a problem like this?
A good starting point is to show it's Cauchy. But you already knew that. Just do it. Cauchy means |s_n-s_m|<epsilon for n and m greater than N. The maximum difference between s_n and s_m involves summing a lot of large powers of 1/2. Use the triangle inequality.
To show that a sequence is Cauchy you must show that [itex]|a_m- a_n|[/itex] goes to 0 as m and n go to infinity independently (in particular, you cannot assume that m= n+1).
But [itex]|a_{n+2}- a_n|\le |a_{n+2}- a{n+1}|+ |a{n+1}- a_n|[/itex], [itex]|a_{n+3}- a_n|\le |a_{n+3}- a_{n+2}|+ |a_{n+2}- a{n+1}|+ |a{n+1}- a_n|[/itex], etc.
You can use the given property on each of those and use induction to show the general case.
But
[tex]|a_{n+2}- a_n|\le |a_{n+2}- a{n+1}|+ |a{n+1}- a_n|[/tex]
[tex]|a_{n+3}- a_n|\le |a_{n+3}- a_{n+2}|+ |a_{n+2}- a{n+1}|+ |a{n+1}- a_n|[/tex], etc.
asaaaa
1. What is the definition of a Cauchy sequence?
A Cauchy sequence is a sequence of numbers in which the terms become closer and closer together as the sequence progresses. In other words, for any given positive number, there exists a point in the sequence after which all subsequent terms are within that distance of each other.
2. How do you prove a sequence is Cauchy?
To prove a sequence is Cauchy, you must show that for any given positive number, there exists a point in the sequence after which all subsequent terms are within that distance of each other. This can be done by using the definition of a limit and proving that as the terms in the sequence get closer together, they eventually get within the given distance of each other.
3. What is the importance of proving a sequence is Cauchy?
Proving a sequence is Cauchy is important because it is a necessary condition for a sequence to be convergent. In other words, if a sequence is Cauchy, then it will converge to a limit. This is a fundamental concept in real analysis and is used in many mathematical proofs and applications.
4. What are some common techniques used to prove a sequence is Cauchy?
Some common techniques used to prove a sequence is Cauchy include the triangle inequality, the squeeze theorem, and the Cauchy criterion. These techniques involve manipulating the terms of the sequence and showing that they eventually get within a given distance of each other.
5. Can a sequence be both Cauchy and divergent?
No, a sequence cannot be both Cauchy and divergent. This is because a Cauchy sequence is defined as one in which the terms get closer and closer together as the sequence progresses, while a divergent sequence is one in which the terms do not have a limit and may become infinitely large or small. So, a sequence cannot be both convergent and divergent at the same time.
