Proving a subset relation
  1. Apr 18, 2015 #1
    for functions f: X -> Y and g: Y ->Z
    show that for all subsets C in Z , (g°f)^-1(C) ⊆ f^-1(g^-1(C)) (or find a counterexample)
    3. The attempt at a solution
    let z ∈ (g°f)^-1(C) such that (g°f)^-1(z) = x for some x∈X
    then
    z = (g°f)(x)
    z = g(f(x))
    g^-1(z) = f(x)
    f^-1(g^-1(z) = x for some x ∈ X
    so z ∈f^-1(g^-1(C))
    These types of proofs are very subtle and technical to me and I am not sure If I am assuming anything or if I have sufficiently proven what needed to be proven. I would greatly appreciate some feedback :)
  3. Apr 18, 2015 #2
    I'm not sure I follow your first line. I didn't think it was necessary to use two variables (x & z) but if you want to I think it should be
    x ∈ (g°f)-1(C) such that (g°f)-1(z) = x for some x ∈ X & z ∈ C
  4. Apr 18, 2015 #3
    I am not sure how to do it with one variable. =\ I am a little confused... should I change the last line to
    x∈f^-1(g^-1(C)) ???
  5. Apr 18, 2015 #4
    Mark44
    Staff: Mentor
    I don't think the statement is true. What if ##g \circ f## is invertible (which would mean that ##(g \circ f)^{-1}## exists), but f or g is not invertible?
  6. Apr 19, 2015 #5
    SammyS
    Staff Emeritus
    I'm pretty sure this is dealing with preimages (inverse images), not the images of inverse functions.
  7. Apr 19, 2015 #6
    I think I am lost lol
  8. Apr 19, 2015 #7
    Fredrik
    Staff Emeritus
    ##g^{-1}(C)## exists even when ##g^{-1}## doesn't. It's defined by ##g^{-1}(C)=\{y\in Y|g(y)\in C\}##.
  9. Apr 19, 2015 #8
    Fredrik
    Staff Emeritus
    This sentence doesn't make sense. I assume you meant "...be such that...". You should just start "let ##z\in(g\circ f)^{-1}(C)##". No need to add a "such that". Note that the z defined this way is an element of X, not Z, so the expression ##(g\circ f)^{-1}(z)## doesn't make sense.
    You just need to use the definition of the preimage of a set correctly. Here's the definition: If ##f:X\to Y## and ##S\subseteq Y##, then ##f^{-1}(S)=\{x\in X|f(x)\in S\}##. Note that this means that the following equivalence holds for all ##x\in X##.
    $$x\in f^{-1}(S)~\Leftrightarrow~ f(x)\in S.$$ I like to do these proofs as a sequence of implications. I would start by saying that the following implications hold for all ##x\in X##.
    $$x\in(g\circ f)^{-1}(C)~\Rightarrow~(g\circ f)(x)\in C~\Rightarrow~g(f(x))\in C~\Rightarrow~\dots$$ If you find that the sequence of implications ends with ##x\in f^{-1}(g^{-1}(C))##, you will have proved that ##(g\circ f)^{-1}(C)\subseteq f^{-1}(g^{-1}(C))##.
    Use \circ to produce the ##\circ## symbol.
  10. Apr 19, 2015 #9
    Right, but in his proof he seemed to use invertibility when he wrote ##(g\circ f)^{-1}(z)##.
  11. Apr 19, 2015 #10
    Mark44
    Staff: Mentor
    What I had in mind were a pair of functions f (f:X→Y) and g (g:Y → Z) where f was invertible and g wasn't, but ##g \circ f## was invertible.
  12. Apr 19, 2015 #11
    ok let me try again
    if x ∈ (g ο f)-1(C)
    then (g ο f)(x) ∈ C
    so g(f(x)) ∈ C
    and f(x) ∈ g-1(C)
    so x∈ f-1(g-1(C))
    if i understand what Mark44 is saying, then this proof will not work if g is not invertible (you cant get from the third to the fourth line) or if f is not invertible (you cant get from the fourth to the fifth line) . It seems that the way the problem is worded, the fact that (g ο f) is invertible is assumed?
  13. Apr 19, 2015 #12
    Actually, the proof you just gave is perfect and works without assuming invertible.
  14. Apr 19, 2015 #13
    is that because of the second variable before?
  15. Apr 19, 2015 #14
    Fredrik
    Staff Emeritus
    You seem to be asking if the new proof is perfect because the previous attempt involved a second variable. You probably meant to ask something else. But I agree that your proof is good. Since you didn't make any assumptions about x other than ##x\in(g\circ f)^{-1}(C)##, what you did proves that ##(f\circ g)^{-1}(C)\subseteq f^{-1}(g^{-1}(C))##. The proof of ##f^{-1}(g^{-1}(C))\subseteq (g\circ f)^{-1}(C)## is similar.
  16. Apr 19, 2015 #15
    edit: actually never mind. I didn't mean that it was wrong to use a second variable, just that I didn't bother.
  17. Apr 19, 2015 #16
    I think what I meant is... did the problem with invertibility arise because of the second variable?
    Btw thank you all for your time and help
  18. Apr 19, 2015 #17
    I had the same proof that you got in post #11 & I don't think the invertibility had anything to do with the second variable, I think it just made it a bit more complicated than necessary.
  19. Apr 19, 2015 #18
    The problem was that you wrote ##(f\circ g)^{-1}(z)##. The way you used it, is that it is one single element. But it's not, unless the function is invertible. In general, it is a set of elements, not just one.
  20. Apr 19, 2015 #19
    ahh ok I get it now. Thank you all.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Proving a subset relation
  1. Prove a subset (Replies: 15)
  2. Relations and Subsets (Replies: 1)
  3. Proving a subset (Replies: 4)
Loading...
