Prove Inequality: 1 < √3 < 2 ⇒ 6 < 3^√3 < 7
  • MHB
  • Thread starter anemone
  • Tags
    Inequality
In summary, the problem states that if 1<\sqrt{3}<2, then 6<3^{\sqrt{3}}<7. This can be deduced by using a simple estimate to show that 3^{5/3}<3^{\sqrt{3}}<3^{7/4}. This is because 6=216^{1/3}<243^{1/3}=3^{5/3} and 3^{7/4}=2187^{1/4}<2401^{1/4}=7.
anemone
MHB
POTW Director
3,883
115
Deduce from the simple estimate that if \(\displaystyle 1<\sqrt{3}<2\), then \(\displaystyle 6<3^{\sqrt{3}}<7\).
Hi members of the forum,
This problem says the resulting inequality may be deduced from the simple estimate, but I was unable to do so; could anyone shed some light on how to deduce the intended result?
Thanks in advance.
Mathematics news on Phys.org
Re: Proving an inequality
\(\displaystyle 1\,<\,\sqrt3\,<\,2\)​
\(\displaystyle \Rightarrow\ -\frac12\,<\,\sqrt3-\frac32\,<\,\frac12\)
\(\displaystyle \Rightarrow\ 0<\,\left(\sqrt3-\frac32\right)^2\,<\,\frac14\)
\(\displaystyle \Rightarrow\ 0<\,\frac{21}4-3\sqrt3\,<\,\frac14\)
\(\displaystyle \Rightarrow\ \frac53<\,\sqrt3\,<\,\frac74\)
\(\displaystyle \Rightarrow\ 3^{5/3}<\,3^{\sqrt3}\,<\,3^{7/4}\)
Note that \(\displaystyle 6=216^{1/3}<243^{1/3}=3^{5/3}\) and \(\displaystyle 3^{7/4}=2187^{1/4}<2401^{1/4}=7\).
Hi Nehushtan, thanks to your simple explanation because it is now very clear to me! I appreciate it! :)
What is the meaning of "Prove Inequality: 1 < √3 < 2 ⇒ 6 < 3^√3 < 7"?
This statement is an inequality that states that the square root of 3 is greater than 1 but less than 2, and as a result, 3 raised to the power of the square root of 3 is greater than 6 but less than 7.
Why is it important to prove this inequality?
Proving this inequality helps to establish the relationship between the square root of 3 and 3 raised to the power of the square root of 3. It also allows us to make comparisons and draw conclusions about the values of these expressions.
What evidence is there to support this inequality?
This inequality can be proven using mathematical principles and properties, such as the properties of inequalities and the properties of exponents.
How can this inequality be proven?
This inequality can be proven by manipulating the expressions on both sides of the inequality using mathematical properties and principles until they are equivalent, and then showing that the inequality holds true.
What are the real-life applications of this inequality?
This inequality may have applications in fields such as engineering, physics, and statistics, where understanding the relationship between numbers and their expressions is important for solving problems and making predictions.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
