Proving of complex number
  • Thread starter loy
loy
Given that, x+yi=3/[2+cos θ+i(sin θ)] , prove that x^2+y^2=4x-3
r^2=x^2+y^2
since we know that x=r sinθ , y=r cosθ,
i multiply r on the right hand side to equal 3r/[2r+x+yi], then multiply its comjugate (2r+x)-yi to equal (3rx+6r^2 -3ryi) / [(2r+x)^2 + y^2] . then i equal the imaginary part on left handside, yi= -3ryi/[(2r+x)^2 + y^2],
(2r+x)^2 + y^2 = -3r,
4r^2+x^2+ 4rx +y^2 = -3r, from the Relevant equations,
5r^2+4rx= -3r ,divide both sides by r
5r=-4x-3,
r=-(4x+3)/5,
x^2+y^2= [-(4x+3)/5]^2, until here, i dont know how to proceed the question... anyone can help me?
Answers and Replies
HallsofIvy
41,847
966
r^2=x^2+y^2
We know that if θ is the angle the line from 0 to x+ yi makes with the positive real axis. Is that given? You don't mention it in the statement of the problem.
If that is true then the right side is simply 3/(2+ x+ iy) and it would seem reasonable to multiply both sides by 2+ x+ iy giving (x+ iy)(2+ x+ iy)= 2x+ 2iy+ x^2+ ixy+ ixy- y^2= 3. That is NOT, in general, x^2+ y^2= 4x- 3.
5r=-4x-3,
r=-(4x+3)/5,
loy
not given , my lecturer just gave me the question as i've written above.
So, what should I assume?
SammyS
Staff Emeritus
1,045
But you did assume that x=r sinθ and y=r cosθ , so what Halls said about θ is true.
An alternate way to solve this problem, with no assumptions is to rationalize the denominator of [itex]\displaystyle \ \ \frac{3}{2+\cos(\theta)+i\sin(\theta)}\ \ [/itex] and identify x and y by equating real parts and equating imaginary parts.
Then compare x2 + y2 with 4x-3 .
loy
how to do equating the parts? they are cos and sin there.
SammyS
Staff Emeritus
1,045
Rationalize the denominator of [itex]\displaystyle \ \ \frac{3}{2+\cos(\theta)+i\sin(\theta)}\ \ [/itex] to determine what is the real part and what is the imaginary part.
Since that's equal to x + iy, then you have x is equal to the real part, and y is equal to the imaginary part.
loy
you mean multiply the conjugate of 2+cos(θ)+isin(θ) in order to find the x and y?
SammyS
Staff Emeritus
1,045
Just so there's no misinterpretation, I mean:
Multiply [itex]\displaystyle \ \ \frac{3}{2+\cos(\theta)+i\sin(\theta)}\ \ [/itex] by [itex]\displaystyle \ \ \frac{2+\cos(\theta)-i\sin(\theta)}{2+\cos(\theta)-i\sin(\theta)}\ \ [/itex] in order to find the x and y .
loy
thanks dude , i found the answer!
hey
I could not get the solution
I multiply and divide the RHS with its conjugate 2+cos∅-isin∅ which arrives at
6+3cos∅+isin∅ 6+3cos∅+isin∅
(2+cos∅)^2 +sin^2∅ 4+4cos∅+cos^2∅+sin^2∅
How to equate the LHS
SammyS
Staff Emeritus
1,045
hey
Use [ code] [ /code] tags to write such fractions.
Code:
    6+3cosθ+isinθ                         6+3cosθ+isinθ
(2+cosθ)^2 +sin^2∅                      4+4cosθ+cos^2θ+sin^2θ
Don't forget, sin2(θ) + cos2(θ) = 1 .
yeah i know sin2(θ) + cos2(θ) = 1 .
but even then i'm stuck, can u help me further
It should be 6 + 3 Cosθ - i 3 Sinθ.
3 is missing in i Sinθ
Anyway, I kept getting 9 / (5+4Cosθ) for (x + iy)(x - iy)
loy
the solution is like this
= [3(2+Cosθ)- 3 Sinθ i] / [(2+cos θ)^2 + (sin θ)^2]
So, from LHS, we get
x=3(2+Cosθ)/ [(2+cos θ)^2 + (sin θ)^2] while
y=3 Sinθ/ [(2+cos θ)^2 + (sin θ)^2]
On LHS: x^2+y^2
=[9(2+Cosθ)^2+9Sinθ^2]/ [(2+cos θ)^2 + (sin θ)^2]^2
=9/[(2+cos θ)^2 + (sin θ)^2]
since the denominator and numerator has a common factor (2+cos θ)^2 + (sin θ)^2
On RHS: 4x-3
= 4*{3(2+Cosθ)/ [(2+cos θ)^2 + (sin θ)^2]} - 3
={24 + 12cosθ-3[(2+cos θ)^2 + (sin θ)^2]}/[(2+cos θ)^2 + (sin θ)^2]
={24+12cosθ-12-12cosθ-3cos2(θ)-3sin2(θ)}/[(2+cos θ)^2 + (sin θ)^2]
={24+12cosθ-12-12cosθ-3*(sin2(θ) + cos2(θ))}/[(2+cos θ)^2 + (sin θ)^2]
which is equal to the LHS
It is proven.
Head bang.
It did not strike that I can use L.H.S = R.H.S.
I tried to get 4x-3 from x^2 + y^2.
x^2+y^2 can be derived from (x + iy)(x-iy), then tried to simplify the x^2+y^2 to 4x-3.
Thank you very much Loy! Good day
loy
welcome dude !
Related Threads on Proving of complex number
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
J
  • Last Post
  • Last Post
  • Last Post
