1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Proving Simpsons rule
  1. Dec 15, 2015 #1
    Consider the ansatz
    [tex] \frac{1}{b-a}\int_a^bf(x)dx \approx \alpha_1f(a)+\alpha_2f(\frac{b-a}{2})+\alpha_3f(b)[/tex]
    We can determine the values of [itex]\alpha_1,\alpha_2,\alpha_3[/itex] by requiring the approximation to be exact for quadratic polynomials, which yeilds Simpsons rule.
    Why there is no loss of generality in assuming that [itex]a = -1[/itex] and [itex]b = 1[/itex]?
    2. Relevant equations
    3. The attempt at a solution
  3. Dec 15, 2015 #2
    Hi lampCable:
    Here is a hint.
    You can make a linear substitution y = px+q such that y(a) = -1 and y(b) = +1. Since f(x) is a quadratic polynomial in e, f(y) will also be a quadratic polynomial of y.
    Hope that helps.
    Regards,
    Buzz
  4. Dec 15, 2015 #3
    Ray Vickson
    Surely the middle term should be ##\alpha_2 f(\frac{a+b}{2})##?
    BTW: Simpson's rule is valid for cubics as well; that becomes clear upon taking a = -1 and b = 1, but only after you have found ##\alpha_1, \alpha_2, \alpha_3##.
  5. Dec 16, 2015 #4
    Yes, I'm quite sure that the middle term is correct. Or what do you mean?
    Yes, this is because the contribution from the odd [itex]x^3[/itex] term is zero, giving no further conditions on [itex]\alpha_1, \alpha_2, \alpha_3[/itex] (giving the same conditions as for [itex]f=x[/itex]). Right?
    Thank you for the hint. So, a suitable substitution is
    [tex]
    y = \frac{x-b}{b-a} + \frac{x-a}{b-a}.
    [/tex]
    This gives
    [tex]
    \frac{1}{b-a}\int_a^bf(x)dx = \frac{1}{2}\int_{-1}^1f\bigg{(}\frac{b(y-1)}{2}-\frac{a(y+1)}{2}\bigg{)}dy = \frac{1}{2}\int_{-1}^1g(y)dy \approx \alpha_1g(-1)+\alpha_2g(0)+\alpha_3g(1)
    [/tex]
    And so, by your argument, since [itex]f(x)[/itex] is a quadratic polynomial in [itex]x[/itex], then [itex]f\bigg{(}\frac{b(y-1)}{2}-\frac{a(y+1)}{2}\bigg{)}[/itex] and hence [itex]g(y)[/itex] are quadratic polynomials in [itex]y[/itex]. And the inequality above is therefore equivalent to the assumption that [itex]a=-1[/itex] and [itex]b=1[/itex] in the original ansatz.
    Correct?
  6. Dec 16, 2015 #5
    SteamKing
    Staff Emeritus
    I think Ray is talking here about Simpson's Second Rule.
    The problem you have to prove in the OP is also known as Simpson's First Rule, and it uses a quadratic interpolating polynomial to determine the coefficients, or Simpson's Multipliers, of the three ordinates.
    In Simpson's Second Rule, a cubic interpolating polynomial is used and four ordinates are required, with different multipliers, of course.
  7. Dec 16, 2015 #6
    Samy_A
    If the middle term is ##\alpha_2f(\frac{b-a}{2})##, you get ##\alpha_2g((1-(-1))/2)=\alpha_2g(2/2)=\alpha_2g(1)##.
    But @Ray Vickson is correct, the middle term should be ##\alpha_2f(\frac{a+b}{2})##, and that will give you ##\alpha_2g(0)##.
  8. Dec 16, 2015 #7
    Ray Vickson
    I cannot figure out what you are saying here? Are you saying that what YOU wrote is correct, or are you agreeing that what I wrote is correct?
  9. Dec 16, 2015 #8
    Ray Vickson
    No, I don't think so. The ordinary 3-point Simpson rule (designed so that it works on quadratics) also works on cubics. That is why the error analysis for Simpson's rule is proportional to ##(b-a)^4## instead of ##(b-a)^3##.
    The reason is simple: when you apply the 3-point Simpson rule to ##x^3## (on a symmetric interval ##[-a,a]##) the exact integral and the Simpson result agree exactly (both being 0). Non-symmetric intervals ##[a,b]## give the same result, but the arguments are messier and less revealing.
    For more on this, see, eg., https://en.wikipedia.org/wiki/Simpson's_rule .
  10. Dec 16, 2015 #9
    Oh, yes of course, I did not see my mistake. Thank you.
    I am sorry, I misunderstood what you said. You are definitely correct.
  11. Dec 16, 2015 #10
    SteamKing
    Staff Emeritus
    Well Simpson's First Rule numerical integration can be applied to integrate a number of different functions for which it was not explicitly derived. The error that you get when you do so may not be as small as with integrating a quadratic function, but people still use it, nevertheless.
    Simpson's First Rule is also called the 1-4-1 rule, after the multipliers. Simpson's Second Rule is the 1-3-3-1 rule, also after its multipliers.
    I'm a naval architect. Simpson's Rule used to be quite ubiquitous in my profession before computers. It was used to integrate quite a few curves where the shape had no known explicit representation except the ordinates measured from a drawing.
  12. Dec 16, 2015 #11
    Ray Vickson
    There is no error (except for roundoff) when integrating linear, quadratic or cubic functions using Simpson's 1-4-1 rule. Of course for other functions the use of 1-4-1 Simpson will generally involve an error ##E_S## bounded by
    [tex] |E_S| \leq \frac{h^4}{180} K \, (b-a)^4, [/tex]
    where ##h = (b-a)/n## and ##K = \max_{a \leq y \leq b} |f''''(y)|## is the maximum of the fourth derivative. Here, ##n## is the number of sub-intervals of ##[a,b]##, so the function ##f(x)## is evaluated at the ##(n+1)## equally-spaced points ##a = x_0 < x_1 < \cdots < x_n = b##.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Proving Simpsons rule
  1. Simpson's rule (Replies: 2)
  2. Simpson's Rule (Replies: 1)
  3. Simpson's Rule (Replies: 7)
Loading...
