Proving something is a Group
  • Thread starter srfriggen
srfriggen
306
Prove that the set of all rational numbers of the form 3n6m, m,n[itex]\in[/itex]Z, is a group under multiplication.
For this problem I attempted to show that the given set has 1. an Identity element, 2. each element has an inverse, 3. Closure under multiplication, and 4. Associativity.
1. The identity element is 1
2. The inverse is 3-n6-m
3. Closure: the rationals are closed under multiplication, so closure holds, i.e.
(3m6n)(3k6l) = 3m+k6n+l.
4. Associativity: This is a property of the rationals and holds, i.e.
(3m6n[itex]\ast[/itex]3k6l)[itex]\ast[/itex]3p6q = 3m6n[itex]\ast[/itex](3k6l[itex]\ast[/itex]3p6q)
4. Associativity:
Answers and Replies
LCKurtz
Insights Author
774
I don't see a question here. It looks like you have the idea. But I would write the identity as 3060. And closure is not because the rationals are closed under multiplication, it is because rationals of the form 3m6n are closed under multiplication, which is what you showed. If it is to hand in I would show a bit more detail.
srfriggen
306
I guess my question would be, "Is this correct?"
I'm glad I was on the right path. I will certainly clean it up before handing it in. Thank you!
SammyS
Staff Emeritus
1,167
The following are in addition to the comments of LCKurtz.
For Closure:
Of course it's true that (3m6n)(3k6l) = 3m+k6n+l. This is true due to properties of rational numbers under multiplication, particularly the commutative and associative properties.
But, for this equation to demonstrate closure, the quantity on the right side of the equation needs to be of the form 3r6s, where r,s∈ℤ.
Why is it that 3m+k6n+l is of the desired form? It's because the integers are closed under addition.​
srfriggen
306
For Closure:
Can I just write, "m+k, n+l are integers, since the integers are closed under addition"? Or should I write m+k=r, where r is an integer since the integers are closed under addition.
SammyS
Staff Emeritus
1,167
It should be good enough to write, "m+k, n+l are integers, since the integers are closed under addition" .
I was merely trying to write a complete statement in my earlier post, with the r & s ..
Suggested for: Proving something is a Group
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
