Pseudo arc-length continuation
  • Thread starter HellRaiZer
In summary, the algorithm presented does not seem to work as described. The equation given does not seem to work correctly.
HellRaiZer
Hi...
I'm searching for info on pseudo arc-length continuation algorithm, but i can't find something that can guide me from the ground up.
I found a presentation which describes an iterative algorithm for calculating dx and dl, but it doesn't seem to work. I don't know how to calculate the last element in the right hand side vector. The equation from the presentation (i don't have the link any more, but i can search it again if you want) is:
(lamda_k - lamda_prev)^2 + |x_k - x(lamda_prev)|^2 - arc^2
How should i calculate arc?
If anybody has a comment / paper / tutorial / anything that describes the method in detail, i'd very glad to hear it.
Thanks in advance and forgive my english.
HellRaiZer
Thanks for the link, but unfortunatelly I've already seen it and it is a bit confusing. I'm looking for something more in the form of pseudo code. Not a complete library. I already have a Newton solver for calculating the function before the turning point (where the Newton coverges) and I'm looking for a way for turn it into pseudo arc-length solver, in case to overcome the turning point singularity.
My problem is that i don't know which values must be kept fixed, which of them correspond the previous iteration and which are for the next! I've seen a lot of different ways to formulate the problem, and I'm a bit confused.
Can somebody explain how exactly should i construct the augmented matrixs and the right hand side vector?
Thanks again.
HellRaiZer
I believe...
Assuming steady state continuation...
The system to solve should be just the righthand side evaluated at the steady state (fixed state [tex]x^*[/tex] and parameters [tex]\eta[/tex]) - [tex]f(x^*,\eta)=0[/tex].
For simple bifurcations, eg. fold and Hopf, you need the characteristic evaluated at the appropriate eigenvalues, using the eigenvector (not the determinant), and a condition on this eigenvector...
If you're near the turning point and don't converge, you have to adjust the length of the projection step or search back through the points you've already found and eg. take a bisection of the last two pairs of points, computed the new projection from these points.
Hi, have you find the answer of your question?
What is pseudo arc-length continuation?
Pseudo arc-length continuation is a numerical method used in scientific computing to solve systems of nonlinear equations. It is a type of continuation method that allows for the solution of a problem by varying a parameter, often referred to as the "continuation parameter".
Why is pseudo arc-length continuation useful?
Pseudo arc-length continuation is useful because it allows for the solution of complex nonlinear problems that cannot be solved analytically. It also provides a more efficient and accurate way to find solutions compared to other methods such as direct substitution or iteration.
How does pseudo arc-length continuation work?
Pseudo arc-length continuation works by finding a solution to a nonlinear problem at a particular value of the continuation parameter, then using this solution as a starting point to find solutions at nearby values of the parameter. This process is repeated until the desired solution is found.
What types of problems can be solved using pseudo arc-length continuation?
Pseudo arc-length continuation can be used to solve a wide range of problems, including systems of nonlinear equations, boundary value problems, and eigenvalue problems. It has applications in various fields such as physics, engineering, and economics.
What are the limitations of pseudo arc-length continuation?
While pseudo arc-length continuation is a powerful method, it does have some limitations. It may fail to find a solution if the problem is highly nonlinear or if the continuation parameter is chosen poorly. Additionally, it can be computationally expensive for problems with a large number of equations or unknowns.
